查看: 4673|回复: 0
基于51单片机+LM35的温控系统Proteus仿真程序设计
由LM35温度传感器采集信息,当输出低于15时电机开始转动,并通过LCD1602显示温度
  1. #include <reg51.h>
  2. #include <intrins.h>
  3. #include <stdio.h>
  4. #include <math.h>
  5. #define INT8U        unsigned char
  6. #define INT16U        unsigned int
  7. sbit SDO = P1^3;        //串行数据输出引脚
  8. sbit SCK = P1^5;        //串行时钟引脚
  9. sbit CONV = P1^7;        //转换控制引脚
  10. sbit RS = P2^0;  //寄存器选择线
  11. sbit RW = P2^1;         //读/写控制线
  12. sbit EN = P2^2;         //使能控制线
  13. sbit moto=P3^2;
  14. //-----------------------------------------------------------------
  15. // 延时
  16. //-----------------------------------------------------------------
  17. void delay_ms(INT16U ms)
  18. {
  19.         INT8U i;
  20.         while(ms--) for(i = 0; i < 120; i++);
  21. }
  22. //-----------------------------------------------------------------
  23. // 忙等待
  24. //-----------------------------------------------------------------
  25. void Busy_Wait()
  26. {INT8U LCD_Status;                                                //液晶状态字节变量
  27.         do
  28.         { P0=0XFF;
  29.                 EN=0;RS=0;RW=1;
  30.                 EN=1;LCD_Status=P0;
  31.                 EN=0;
  32.         } while (LCD_Status & 0x80);                        //液晶忙继续循环
  33. }
  34. //-----------------------------------------------------------------
  35. // 写LCD命令
  36. //-----------------------------------------------------------------
  37. void Write_LCD_Command(INT8U cmd)
  38. {
  39.   Busy_Wait();
  40.         EN=0;RS=0;RW=0;
  41.         P0=cmd;
  42.         EN=1;_nop_();EN=0;
  43. }
  44. //-----------------------------------------------------------------
  45. // 发送数据
  46. //-----------------------------------------------------------------
  47. void Write_LCD_Data(INT8U dat)
  48. {
  49. Busy_Wait();
  50.         EN=0;RS=1;RW=0;
  51.         P0=dat;
  52.         EN=1;_nop_();EN=0;
  53. }
  54. //-----------------------------------------------------------------
  55. // LCD初始化
  56. //-----------------------------------------------------------------
  57. void Initialize_LCD()
  58. {
  59.   Write_LCD_Command(0x38); delay_ms(1);
  60.         Write_LCD_Command(0x01); delay_ms(1);
  61.         Write_LCD_Command(0x06); delay_ms(1);
  62.         Write_LCD_Command(0x0C); delay_ms(1);
  63. }
  64. //-----------------------------------------------------------------
  65. // 显示串字符
  66. //-----------------------------------------------------------------
  67. void LCD_ShowString(INT8U r, INT8U c,INT8U *str)
  68. {INT8U i = 0;
  69.         code INT8U DDRAM[] = {0x80,0xC0};
  70.         Write_LCD_Command(DDRAM[r] | c);
  71.         for ( i = 0; str[i] && i < 16 ;i++)
  72.           Write_LCD_Data(str[i]);
  73.         for (; i < 16; i++)
  74.           Write_LCD_Data(' ');
  75. }
  76. float f_volt;int i_volt;
  77. //-----------------------------------------------------------------
  78. // 读取LTC1864模数转换值(16位,2字节)
  79. //-----------------------------------------------------------------
  80. INT16U Read_ADC()
  81. {
  82. INT8U i;INT16U dat=0x00;
  83. SCK=1;
  84. CONV=0;CONV=1;
  85.         _nop_();_nop_();_nop_();_nop_();
  86.         CONV=0;
  87.         for(i=0;i<16;i++)
  88.         {SCK=0;_nop_();SCK=1;
  89.          dat=(dat<<1)|SDO;
  90.         }
  91.         SCK=0;
  92.         return dat;
  93. }
  94. void delay_time(unsigned int t)
  95. {while(t--);
  96. }
  97. INT8U disp_buff[]="wendu: 000.0oC";
  98. void disp_format(INT8U d,INT8U *a)
  99. { a[0]=d/10+0x30;a[1]=d%10+0x30; //???????
  100. }
  101. void disp_dotformat(INT8U d,INT8U *a)
  102. { a[0]=d/10+0x30;a[2]=d%10+0x30; //???????
  103. }
  104. void disp(int dd)
  105. { INT8U gao,di;
  106.         if(dd<0)
  107.    {dd=-dd;disp_buff[6]='-';}
  108.   else
  109.         {disp_buff[6]=' ';
  110.   }
  111.           di=dd%100;
  112.           disp_dotformat(di,disp_buff+9);
  113.     gao=dd/100;
  114.           disp_format(gao,disp_buff+7);
  115. }
  116. void UART_init(void)
  117. {
  118.     SCON = 0x50;
  119.
  120.     TMOD = 0x20;
  121.     TH1 = 0xFD;
  122.     TL1 = 0xFD;
  123.
  124.     TR1 = 1;
  125. }
  126.
  127. ……………………
  128. …………限于本文篇幅 余下代码请从51黑下载附件…………
温控系统.zip (114.05 KB, 下载次数: 88)
