查看: 3356|回复: 0
基于51单片机的数字键盘模块+Protues仿真
部分代码:
  1. #include<AT89X52.h>
  2. #include <intrins.h>
  3. #define Delaynop(){_nop_();_nop_();_nop_();_nop_();}
  4. sbit RS=P2^0;
  5. sbit RW=P2^1;
  6. sbit EN=P2^2;
  7. void Delayms(unsigned int ms);
  8. bit LCD_Busy();
  9. void LCD_Pos(unsigned char);
  10. void LCD_Wcmd(unsigned char);
  11. void LCD_Wdat(unsigned char);
  12. char code Title_Text[]={"--Phone Code--  "};
  13. unsigned char code Key_Table[]={'1','2','3','4','5','6','7','8','9','*','0','#'};
  14. unsigned char Dial_Code_Str[]={"             "};
  15. unsigned char KeyNo=0xff;
  16. int tCount=0;
  17. //毫秒级延时函数
  18. void Delayms(unsigned int x)
  19. {
  20.   unsigned char i;
  21.   while(x--)
  22.   {
  23.     for(i=0;i<120;i++);
  24.   }
  25. }
  26. //显示字符串
  27. void Display_String(unsigned char *str,unsigned char LineNo)
  28. {
  29.   unsigned char k;
  30.   LCD_Pos(LineNo);
  31.   for(k=0;k<16;k++)
  32.   {
  33.     LCD_Wdat(str[k]);
  34.   }
  35. }
  36. //检查1602是否处于忙装填
  37. bit LCD_Busy_Check()
  38. {
  39.   bit Result;
  40.   RS=0;
  41.   RW=1;
  42.   EN=1;
  43.   Delaynop();
  44.   Result=(bit)(P0 & 0x80);
  45.   EN=0;
  46.   return Result;
  47. }
  48. //向1602写入指令的函数
  49. void LCD_Write_Command(unsigned char cmd)
  50. {
  51.   while(LCD_Busy_Check());  //检查是否处于忙状态
  52.   RS=0;
  53.   RW=0;
  54.   EN=0;
  55.   _nop_();
  56.   _nop_();
  57.   P0=cmd;   //写入指令
  58.   Delaynop();
  59.   EN=1;
  60.   Delaynop();
  61.   EN=0;
  62. }
  63. //向1602写数据
  64. void LCD_Wdat(unsigned char dat)
  65. {
  66. while(LCD_Busy_Check());  //检查是否处于忙状态
  67. RS=1;
  68. RW=0;
  69. EN=0;
  70. P0=dat;                   //写入数据
  71. Delaynop();
  72. EN=1;
  73. Delaynop();
  74. EN=0;
  75. }
  76. //初始化1602
  77. void Init_LCD()
  78. {
  79.   LCD_Write_Command(0x38);Delayms(5);
  80.   LCD_Write_Command(0x01);Delayms(5);
  81.   LCD_Write_Command(0x06);Delayms(5);
  82.   LCD_Write_Command(0x0c);Delayms(5);
  83. }
  84. //设置显示位置
  85. void LCD_Pos(unsigned char pos)
  86. {
  87.   LCD_Write_Command(pos|0x80);
  88. }
  89. /*
  90. //T0的中断服务子函数
  91. void T0Deal()interrupt 1
  92. {
  93. TH0=-600/256;
  94. TL0=-600%256;
  95. if(++tCount==200)
  96. {
  97.   tCount=0;
  98.   TR0=0;
  99. }
  100. }
  101. */
  102. //按键扫描函数,返回值为对应的按键编码
  103. unsigned char GetKey()
  104. {
  105. unsigned char i,j,k=0;
  106. unsigned char KeyScanCode[]={0xef,0xdf,0xbf,0x7f};   //行列扫描的行列码
  107. unsigned char KeyCodeTable[]={
  108. 0xee,0xed,0xeb,0xde,0xdd,0xdb,0xbe,0xbd,0xbb,0x7e,0x7d,0x7b};
  109. P3=0x0f;
  110. if(P3!=0x0f)       //如果有按键被按下
  111. {
  112.   for(i=0;i<4;i++)    //依次进行扫描
  113.   {
  114.     P3=KeyScanCode[i];
  115.     for(j=0;j<3;j++)
  116.     {
  117.       k=i*3+j;                //计算对应的按键编码
  118.       if(P3==KeyCodeTable[k])
  119.       {
  120.         return k;             //返回按键编码
  121.       }
  122.      }
  123.   }
  124. }
  125. else
  126. {
  127.   return 0xff;                  //或者返回0xff
  128. }}
全部资料51hei下载地址:
新建文件夹.zip (75.13 KB, 下载次数: 22)
