查看: 3956|回复: 0
单片机+74LS165拓展按键 Proteus仿真程序
ID:224782 发表于 2020-3-18 14:03 | 显示全部楼层 |阅读模式
三个IO口驱动两片74LS165,拓展为16位按键。附件包括Proteus仿真文件及源程序。
  1. #include <reg52.h>
  2. #define uint16 unsigned int
  3. #define uint8 unsigned char
  4. sbit HC165_nPL = P3 ^ 5;
  5. sbit HC165_CK  = P3 ^ 6;
  6. sbit HC165_OUT = P3 ^ 7;
  7. unsigned int HC165(void)
  8. {
  9.     unsigned char i;
  10.     unsigned int Temp, Temp1, Temp2;
  11.     HC165_CK = 1;
  12.     HC165_nPL = 0;        //HC165读按键
  13.     HC165_nPL = 1;        //暂停HC165读按键
  14.     Temp1 = 0;
  15.     if(HC165_OUT == 1)
  16.         {
  17.                 Temp1 |= 0x01;
  18.         }
  19.     for(i = 0;i < 7;i++)
  20.     {
  21.         HC165_CK = 0;
  22.         HC165_CK = 1;
  23.         Temp1 <<= 1;
  24.         if(HC165_OUT == 1)
  25.         {
  26.             Temp1 |= 0x01;
  27.         }
  28.     }
  29.         HC165_CK = 0;
  30.     HC165_CK = 1;
  31.         Temp2 = 0;
  32.     if(HC165_OUT == 1)
  33.         {
  34.                 Temp2 |= 0x01;
  35.         }
  36.         for(i = 0;i < 7;i++)
  37.     {
  38.         HC165_CK = 0;
  39.         HC165_CK = 1;
  40.         Temp2 <<= 1;
  41.         if(HC165_OUT == 1)
  42.         {
  43.             Temp2 |= 0x01;
  44.         }
  45.     }
  46.     HC165_CK = 0;
  47.
  48.         Temp = (Temp2 << 8) + Temp1;
  49.     return(Temp);
  50. }
  51. void main( )
  52. {
  53.         uint16 num;
  54.
  55.         while(1)
  56.         {
  57.                 num = HC165( );
  58.
  59.                 switch(num)
  60.                 {
  61.                         case 0xfffe: P1 = 0xfe; P2 = 0xff; break;
  62.                         case 0xfffd: P1 = 0xfd; P2 = 0xff; break;
  63.                         case 0xfffb: P1 = 0xfb; P2 = 0xff; break;
  64.                         case 0xfff7: P1 = 0xf7; P2 = 0xff; break;
  65.                         case 0xffef: P1 = 0xef; P2 = 0xff; break;
  66.                         case 0xffdf: P1 = 0xdf; P2 = 0xff; break;
  67.                         case 0xffbf: P1 = 0xbf; P2 = 0xff; break;
  68.                         case 0xff7f: P1 = 0x7f; P2 = 0xff; break;
  69.                         case 0xfeff: P1 = 0xff; P2 = 0xfe; break;
  70.                         case 0xfdff: P1 = 0xff; P2 = 0xfd; break;
  71.                         case 0xfbff: P1 = 0xff; P2 = 0xfb; break;
  72.                         case 0xf7ff: P1 = 0xff; P2 = 0xf7; break;
  73.                         case 0xefff: P1 = 0xff; P2 = 0xef; break;
  74.                         case 0xdfff: P1 = 0xff; P2 = 0xdf; break;
  75.                         case 0xbfff: P1 = 0xff; P2 = 0xbf; break;
  76.                         case 0x7fff: P1 = 0xff; P2 = 0x7f; break;
  77.                         default: break;
  78.                 }
  79.         }
  80. }
74LS165按键.zip (82.88 KB, 下载次数: 59)
