查看: 3270|回复: 4
单片机1602显示电子时钟Proteus仿真程序
ID:716109 发表于 2020-3-26 12:03 | 显示全部楼层 |阅读模式
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. sbit LCD_RS = P2^0;
  5. sbit LCD_RW = P2^1;
  6. sbit LCD_EN = P2^2;
  7. sbit LED = P2^4;
  8. bit new_s=0, g = 0,k=0;
  9. char t0, sec = 00, min = 00, hour = 00;
  10. char code LCD_line1[] = "GOOD MORNING!";
  11. char code LCD_line2[] = "Timer: 00:00:00 ";
  12. char Timer_buf[] = "00:00:00";
  13. void delay(uint z)//延时
  14. {
  15.     uint  x, y;
  16.     for(x = z; x > 0; x--)
  17.                 for(y = 100; y > 0; y--);
  18. }
  19. void W_LCD_Com(uchar com)   //写指令
  20. {
  21.     LCD_RS = 0;
  22.                 LCD_RW = 0;
  23.                 P3 = com;
  24.     LCD_EN = 1;
  25.                 delay(5);
  26.                 LCD_EN = 0;
  27. }
  28. void W_LCD_Dat(uchar dat)//写数据
  29. {
  30.     LCD_RS = 1;
  31.         LCD_RW = 0;
  32.         P3 = dat;
  33.     LCD_EN = 1;
  34.         delay(5);
  35.         LCD_EN = 0;
  36. }
  37. void W_LCD_STR(uchar *s)  //写字符
  38. {
  39.     while(*s)  W_LCD_Dat(*s++);
  40. }
  41. void W_BUFF(void) //显示
  42. {
  43.                 Timer_buf[0] = hour / 10 + 48;
  44.                 Timer_buf[1] = hour % 10 + 48;
  45.                 Timer_buf[3] = min / 10 + 48;
  46.                 Timer_buf[4] = min % 10 + 48;
  47.                 Timer_buf[6] = sec / 10 + 48;
  48.                    Timer_buf[7] = sec % 10 + 48;
  49.                    W_LCD_Com(0xc0 + 7);
  50.                 W_LCD_STR(Timer_buf);
  51. }
  52. uchar read_key(void)//扫描按键
  53. {
  54.     uchar  x1, x2;
  55.     P1 = 255;
  56.     x1 = P1;
  57.     if (x1 != 255) {
  58.       delay(100);
  59.       x2 = P1;
  60.       if (x1 != x2)
  61.         return 255;
  62.       while(x2 != 255)
  63.         x2 = P1;
  64.       if      (x1 == 0xfe)  return 0;
  65.       else if (x1 == 0xfb)  return 1;
  66.       else if (x1 == 0xfd)  return 2;
  67.       else if (x1 == 0xf7)  return 3;
  68.       else if (x1 == 0xef)  return 4;
  69. else if(x1==0xdf)return 5;
  70.     }
  71.     return 255;
  72. }
  73. void Init()
  74. {
  75.     LCD_RW = 0;
  76.     W_LCD_Com(0x38); //显示模式
  77.                 delay(50);
  78.
  79.                 W_LCD_Com(0x0c);
  80.     W_LCD_Com(0x06);//显示光标移动位置
  81.     W_LCD_Com(0x01);//清屏
  82.     W_LCD_Com(0x80);//第一行
  83.                 W_LCD_STR(LCD_line1);
  84.     W_LCD_Com(0xC0);//第二行
  85.                 W_LCD_STR(LCD_line2);
  86.     TMOD = 0x01;   //T0定时方式1
  87.     TH0 = 0x3c;
  88.         TL0= 0xB0;
  89.     TR0 = 1;
  90.     ET0 = 1;
  91.     EA = 1;
  92. }
  93. void CountDown()
  94. {
  95.   if (k)
  96. while(!(sec==0&&min==0&&hour==0))
  97. {
  98.          if(new_s==1)
  99.         {
  100.            sec--;
  101.            new_s=0;
  102.            sec %=60;
  103.            if(sec<0)
  104.                    sec=58-sec;
  105.         if(sec==59)
  106.                 {
  107.                         min--;  min %=60;
  108.                         if(min<0&&hour!=0&&hour>0)
  109.                                 min=58-min;
  110.                   if(min==59)
  111.                           {
  112.                                   hour--; hour %= 24;
  113.
  114.                           }
  115.
  116.            }
  117.
  118.
  119.         W_BUFF();
  120.       }
  121.           }
  122.           k=0;
  123. }
  124. void main()
  125. {
  126.     uint i, j;
  127.     uchar Key;
  128.     Init();
  129.     while(1)
  130.         {
  131.       if (new_s)
  132.            {
  133.             new_s=0;sec++;  sec %= 60;
  134.         if(!sec)
  135.                 {
  136.                 min++;  min %= 60;
  137.           if(!min)
  138.                   { hour++; hour %= 24;}
  139.
  140.            }
  141.
  142.
  143.         W_BUFF();
  144.       }
  145.           Key = read_key();
  146.       switch(Key) {
  147.       case  0: g = 1; break;
  148.       case  1: if(g) {min++;  min %= 60;  W_BUFF(); break;}
  149.       case  2: if(g) {hour++; hour %= 24; W_BUFF(); break;}
  150.       case  3: g = 0; break;
  151.                 case 4:k=1;CountDown();break;
  152.     }
  153.
  154.                 }
  155. }
  156. void timer0(void) interrupt 1
  157. {
  158.                 TH0 = 0x3c;
  159.                 TL0= 0xB0;
  160.     t0++; t0 %= 20;  //20次
  161.     if(t0 == 0){new_s = 1; LED = ~LED;}
  162.     if(g)  LED = 0;
  163.
  164.
  165. }
电子时钟.zip (72.96 KB, 下载次数: 59)
一、 项目要求
1. 能用LED显示时间,以“时:分:秒”的形式;2. 能通过拨动按键达到调时的目的;3. 能实现倒计时功能。二、 项目开发环境1. 硬件环境:Windows 102. 软件环境:Protues 8.6              Keil uVision4三、 项目分析1. 显示时间使用的LED可以使用LM016L,时间显示的原理可以使用定时器,定时器定时满1S,秒加1,判断秒大于59时,分加1,并且秒清0;判断分大于59时,时加1,并且分清0;判断时大于23时,时清0。主程序流程图:3. 倒计时设计当时间设定完成后,从当前时间开始倒计时,当秒小于0时,分减1,秒置59,当分小于0时,时减1,分置59,当时小于0时,从00:00:00开始正计时。四、 设计与实现1. 设计思路1) 首先要将时间显示部分的逻辑原理理清楚并画出仿真图,考虑按键进去,并写出时间显示部分的核心代码;2) 将按键的各个功能理清楚,以及按键控制的逻辑思路,编写出完整的代码,并进行仿真。3) 考虑增添倒计时功能,在原有的基础上增加一个按键,修改仿真图,并编写倒计时函数代码,最后仿真调试。2. 设计和实现的主要内容1) 设计实现一个以“时:分:秒”形式显示的电子时钟,使用4个按键实现:开始计时,设置时,设置秒,完成时间设置功能,最后增添按键实现倒计时功能。
五、 总结
本次课程设计仿真电子时钟,相对来说,电路比较简单,没有那么复杂,仿真图中需要注意的LM016L这个LED显示器件的工作原理,LM016L是1602的一种,它是以ASCII码为编码方式,不注意的话,可能会造成乱码。LM016L在写入显示地址时要求最高位D7恒定为高电平1,所以实际写入的数据应该加上80H,它在显示字符时光标自动右移,无须人工干预,它的VL为液晶显示器对比度调整端,我们在仿真中为它接入一个滑动变阻器。对于本次课程设计,其重点在与理清其中的逻辑思路,再来编写代码,使得整个课程设计条理清晰。
本次课程设计让我对本学期所学的单片机是识进行了一次整合,对AT89C51单片机的认识更加的清晰明了。让我对单片机有关的硬件设计产生了浓厚的兴趣,特别时有关定时计数器的部分。
本次设计使用了Keil uVision4和Proteus 8 Professional软件,让我对这两个软件的运用更加熟练,更加得心应手。让我认识到了自己本身的不足以及问题解决的方法,让我认识到了实践与理论结合的重要性。
ID:573789 发表于 2020-6-9 15:23 | 显示全部楼层
牛逼顶
ID:723220 发表于 2020-8-30 10:13 | 显示全部楼层
能不能发一下只有四个按钮和排阻只有8个引脚的程序
ID:723220 发表于 2020-9-1 10:53 | 显示全部楼层
为什么会突然卡退,程序到最后算是写完了吗?
ID:723220 发表于 2020-9-5 20:15 | 显示全部楼层
在吗,可不可以回复一下,程序运行卡退怎么修改
