查看: 12799|回复: 15
基于stm32的智能窗帘Proteus仿真设计
ID:511094 发表于 2020-3-27 13:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "stm32f10x.h"
  2. #include "bsp-lcd1602.h"
  3. #include "delay.h"
  4. #include "sys.h"
  5. #include "adc.h"
  6. void L298_GPIO( void )
  7. {
  8.         GPIO_InitTypeDef GPIO_InitStructure;
  9.
  10.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  11.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
  12.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  13.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  14.         GPIO_Init(GPIOC, &GPIO_InitStructure);
  15. }
  16. void OPEN(void)        //left moto is runing, but right moto is brake
  17. {
  18.         GPIO_SetBits(GPIOC,GPIO_Pin_5);
  19.         GPIO_ResetBits(GPIOC,GPIO_Pin_4);
  20.         GPIO_ResetBits(GPIOC,GPIO_Pin_3);
  21.         GPIO_ResetBits(GPIOC,GPIO_Pin_2);
  22.         GPIO_SetBits(GPIOC,GPIO_Pin_1);
  23.         GPIO_SetBits(GPIOC,GPIO_Pin_0);
  24. }
  25. void CLOSE(void)        //right moto is runing, but left moto is brake
  26. {
  27.         GPIO_ResetBits(GPIOC,GPIO_Pin_5);
  28.         GPIO_ResetBits(GPIOC,GPIO_Pin_4);
  29.         GPIO_SetBits(GPIOC,GPIO_Pin_3);
  30.         GPIO_ResetBits(GPIOC,GPIO_Pin_2);
  31.         GPIO_SetBits(GPIOC,GPIO_Pin_1);
  32.         GPIO_SetBits(GPIOC,GPIO_Pin_0);
  33. }
  34. void STOP(void)        //right moto is runing, but left moto is brake
  35. {
  36.         GPIO_SetBits(GPIOC,GPIO_Pin_5);
  37.         GPIO_SetBits(GPIOC,GPIO_Pin_4);
  38.         GPIO_SetBits(GPIOC,GPIO_Pin_3);
  39.         GPIO_SetBits(GPIOC,GPIO_Pin_2);
  40.         GPIO_SetBits(GPIOC,GPIO_Pin_1);
  41.         GPIO_SetBits(GPIOC,GPIO_Pin_0);
  42. }
  43. int main(void)
  44. {
  45. int a,b,c,d;
  46.         float temp;
  47.
  48.         delay_init();                     //延时函数初始化
  49.         LCD1602_Init();
  50.     ADC1_GPIO_Config();
  51.         L298_GPIO();
  52.     ADC_Config();
  53.         LCD1602_ShowStr(0,0,"  Auto curtain ",15);
  54.         LCD1602_ShowStr(0,1,"Light:",6);
  55.
  56.         while(1)
  57.         {
  58.                 b=ADC_GetConversionValue(ADC1);
  59.                 temp=b*(3.4/4096)*10;
  60.                 //表示光线太弱
  61.                 if( temp < 8 )
  62.                 {
  63.                         LCD1602_ShowStr(7,1,"Low ",4);
  64.                         OPEN();
  65.                 }
  66.                 else
  67.                 {
  68.                         if( temp < 25)                                //光线合适
  69.                         {
  70.                                 LCD1602_ShowStr(7,1,"OK  ",4);
  71.                                 STOP();
  72.                         }
  73.                         else                                                //光线太强
  74.                         {
  75.                                 LCD1602_ShowStr(7,1,"High",4);
  76.                                 CLOSE();
  77.                         }
  78.                 }
  79. //                a=temp/1;
  80. //                c=temp*10;
  81. //                d=c%10;
  82. //                LCD_ShowNum(11,0,a);
  83. //                LCD_ShowNum(13,0,d);
  84.         }
  85. }
基于stm32的智能窗帘仿真设计.7z (285.11 KB, 下载次数: 637)
收藏收藏22 分享淘帖 顶顶1 踩踩
ID:724710 发表于 2020-4-27 10:31 | 只看该作者
原理图显示有错误,控制距离远近显示屏有时不变化,相应的电机不转动
ID:368810 发表于 2020-5-20 10:36 | 只看该作者
楼主,程序那个文件夹里哪个是主程序啊,用什么软件打开?
ID:368810 发表于 2020-5-20 15:19 | 只看该作者
灵敏度比较低,应该在程序里修改可以提高灵敏度
ID:368810 发表于 2020-5-22 17:03 | 只看该作者
楼主,程序应该是有问题,proteus时间运行了20多秒后屏幕上的字会消失,再过一会调整光敏元件电机没有反应
ID:368810 发表于 2020-5-22 17:07 | 只看该作者
而且在proteus时间的第6或第7秒时,屏幕的字从auto curtain会变为K  uto curtain,不知道是什么原因,我用的是proteus8.6版本
ID:772082 发表于 2020-6-15 11:59 | 只看该作者
keil v5 mdk可以打开
ID:780927 发表于 2020-6-16 14:59 | 只看该作者
请问有电路原理图吗?
ID:606520 发表于 2020-6-17 18:43 | 只看该作者
我能说,到现在我都不知道用什么软件写程序,这个模拟软件是啥?
ID:774546 发表于 2020-6-29 03:45 来自触屏版 | 只看该作者
temp那里怎么算的啊,是什么意思啊
ID:440028 发表于 2021-12-30 14:55 | 只看该作者
#include "delay.h"
#include "sys.h"
#include "adc.h"
int main(void)
int a,b,c,d;
        float temp;
        LCD1602_Init();
    ADC1_GPIO_Config();
        L298_GPIO();
    ADC_Config();
                //表示光线太弱
                if( temp < 8 )
                        LCD1602_ShowStr(7,1,"open ",4);
                        OPEN();
                                STOP();
                        else                                                //光线太强
                                LCD1602_ShowStr(7,1,"close",4);
                                CLOSE();
//                a=temp/1;
//                c=temp*10;
//                d=c%10;
ID:440028 发表于 2021-12-30 14:56 | 只看该作者
好像两个程序都一样,你俩怎么都差不多,都在51黑里
ID:1039715 发表于 2022-7-16 16:02 | 只看该作者
你可以试一下把这个Auto curtain 和light 放到while(1)里面试一下
ID:1048726 发表于 2022-11-3 18:55 | 只看该作者
所以是有错误吗
ID:1054785 发表于 2022-11-30 10:53 来自触屏版 | 只看该作者
我想问问如果需要实现该功能电机需要选哪样的
ID:1054785 发表于 2022-12-6 13:59 来自触屏版 | 只看该作者
窗帘开关找不到,关键词是啥
