查看: 2232|回复: 0
求这个单片机红外遥控程序的详细注释
ID:626338 发表于 2020-3-27 16:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
10黑币
#include<reg51.h>
#include<intrins.h>
sbit key1=P2^0;  //亮
sbit key2=P2^1;  //灭
sbit key3=P2^2;  //加
sbit key4=P2^3;  //减
sbit key5=P2^4;  //5min
sbit key6=P2^5;  //10min
sbit key7=P2^6;  //20min
sbit LED=P1^1; //发射指示灯
sbit out=P1^0; //红外发射管
uchar i,a,num1;
void init()//初始化
        key1=1;
        key2=1;
        key3=1;
        key4=1;
        key5=1;
        key6=1;
        key7=1;
void delay(uchar aa)
        uchar bb,cc;
        for(bb=aa;bb>0;bb--)
                for(cc=200;cc>0;cc--);
void delayms(uchar aa)//延时程序
        for(a=aa;a>0;a--)
                _nop_();
                _nop_();
                _nop_();
                _nop_();
                _nop_();
                _nop_();
                _nop_();
                _nop_();
void khz(uchar aa)//发射38KHZ的程序
        for(a=aa;a>0;a--)   //这个for语句可以得到准确的26.3波特率
                        out=0;
                        i=7;                //低了17us
                        while(i>0)i--;                //   38kHZ
                        out=1;
                                //高了9us      17+9=26us   比26.3快了一点
        //khz(116);//3.028ms   精确的时间
        //khz(64);//2.006ms
        //khz(40); //1.052ms
        //delayms(125);//2.012ms      这里是一些的时间介绍
        //delayms(65);//1.054ms
        //delayms(93);//1.5ms
void fashu(uchar num)
        khz(116);//发射3ms 38khz
        delayms(125);
        for(num1=8;num1>0;num1--)
                khz(40);
                if(num&0x01)
                        delayms(93);//delay 1.5ms
                        delayms(65);//delay 1ms
                num=num>>1;
        khz(20);
void tishi()
          LED=0;
                delay(50);
                LED=1;
                delay(50);
                LED=0;
                delay(50);
                LED=1;
void keyscan()//按键
        if(key1==0)
                _nop_();_nop_();_nop_();_nop_();
                if(key1==0)
                        while(!key1);
                        fashu(0xff);
                        tishi();
        if(key2==0)
                if(key2==0)
                        while(!key2);
                        fashu(0xdd);
                        tishi();
        if(key3==0)
                if(key3==0)
                        while(!key3);
                        fashu(0xcd);
                        tishi();
        if(key4==0)
                if(key4==0)
                        while(!key4);
                        fashu(0xbb);
                        tishi();
                if(key5==0)
                if(key5==0)
                        while(!key5);
                        fashu(0xfb);
                        tishi();
        if(key6==0)
                if(key6==0)
                        while(!key6);
                        fashu(0xdf);
                        tishi();
                if(key7==0)
                if(key7==0)
                        while(!key7);
                        fashu(0xef);
                        tishi();
        init();
                keyscan();
