查看: 2912|回复: 0
这是STM32F103超声波OLED显示实验(库函数版)
ID:419916 发表于 2020-3-30 01:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "delay.h"
  2. #include "sys.h"
  3. #include "oled.h"
  4. #include "bmp.h"
  5. #include "stm32f10x_tim.h"
  6. #include "GPIOLIKE51.h"
  7. #define HCSR04_PORT     GPIOB
  8. #define HCSR04_CLK      RCC_APB2Periph_GPIOB
  9. #define HCSR04_TRIG     GPIO_Pin_11
  10. #define HCSR04_ECHO     GPIO_Pin_10
  11. #define TRIG_Send PBout(11)
  12. #define ECHO_Reci PBin(10)
  13. //?????
  14. u16 msHcCount = 0;
  15. //???4??
  16. void hcsr04_NVIC()
  17. {
  18. NVIC_InitTypeDef NVIC_InitStructure;
  19. NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  20. NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
  21. NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  22. NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  23. NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  24. NVIC_Init(&NVIC_InitStructure);
  25. }
  26. //IO???? ??????
  27. void Hcsr04Init()
  28. {
  29.     TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  30.     GPIO_InitTypeDef GPIO_InitStructure;
  31.     RCC_APB2PeriphClockCmd(HCSR04_CLK, ENABLE);
  32.
  33.     GPIO_InitStructure.GPIO_Pin =HCSR04_TRIG;
  34.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  35.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  36.     GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
  37.     GPIO_ResetBits(HCSR04_PORT,HCSR04_TRIG);
  38.
  39.     GPIO_InitStructure.GPIO_Pin =   HCSR04_ECHO;
  40.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  41.     GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
  42.     GPIO_ResetBits(HCSR04_PORT,HCSR04_ECHO);
  43.
  44.
  45.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  46.
  47.     TIM_DeInit(TIM2);
  48.     TIM_TimeBaseStructure.TIM_Period = (1000-1);
  49.     TIM_TimeBaseStructure.TIM_Prescaler =(72-1);
  50.     TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  51.     TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  52.     TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  53.
  54.     TIM_ClearFlag(TIM4, TIM_FLAG_Update);
  55.     TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE);
  56.     hcsr04_NVIC();
  57.     TIM_Cmd(TIM4,DISABLE);
  58. }
  59. //?????4
  60. static void OpenTimerForHc()
  61. {
  62.    TIM_SetCounter(TIM4,0);
  63.    msHcCount = 0;
  64.    TIM_Cmd(TIM4, ENABLE);
  65. }
  66. //?????4
  67. static void CloseTimerForHc()
  68. {
  69.    TIM_Cmd(TIM4, DISABLE);
  70. }
  71. //???4???
  72. void TIM4_IRQHandler(void)
  73. {
  74.    if (TIM_GetITStatus(TIM4, TIM_IT_Update) != RESET)
  75.    {
  76.        TIM_ClearITPendingBit(TIM4, TIM_IT_Update  );
  77.        msHcCount++;
  78.    }
  79. }
  80. //?????4????
  81. u32 GetEchoTimer(void)
  82. {
  83.    u32 t = 0;
  84.    t = msHcCount*1000;
  85.    t += TIM_GetCounter(TIM4);
  86.    TIM4->CNT = 0;
  87.    delay_ms(50);
  88.    return t;
  89. }
  90. //?????4????????
  91. float Hcsr04GetLength(void )
  92. {
  93.    u32 t = 0;
  94.    int i = 0;
  95.    float lengthTemp = 0;
  96.    float sum = 0;
  97.    while(i!=5)
  98.    {
  99.       TRIG_Send = 1;
  100.       delay_us(20);
  101.       TRIG_Send = 0;
  102.       while(ECHO_Reci == 0);
  103.       OpenTimerForHc();
  104.       i = i + 1;
  105.       while(ECHO_Reci == 1);
  106.       CloseTimerForHc();
  107.       t = GetEchoTimer();
  108.       lengthTemp = ((float)t/58.0);//cm
  109.       sum = lengthTemp + sum ;
  110.
  111.     }
  112.     lengthTemp = sum/5.0;
  113.     return lengthTemp;
  114. }
  115. int main(void)
  116. {        u8 t;
  117.                 delay_init();         //延时函数初始化
  118.                 NVIC_Configuration();          //设置NVIC中断分组2:2位抢占优先级,2位响应优先级         LED_Init();                             //LED端口初始化
  119.     Hcsr04Init();
  120.           OLED_Init();                        //初始化OLED
  121.                 OLED_Clear()          ;
  122.                 /*
  123.                  OLED_ShowString(30,0,"OLED TEST");
  124.                 OLED_ShowString(8,2,"ZHONGJINGYUAN");
  125.                 OLED_ShowString(20,4,"2014/05/01");
  126.                 OLED_ShowString(0,6,"ASCII:");
  127.                 OLED_ShowString(63,6,"CODE:");
  128.                 t=' ';
  129.                 OLED_ShowCHinese(0,0,0);//中
  130.                 OLED_ShowCHinese(18,0,1);//景
  131.                 OLED_ShowCHinese(36,0,2);//园
  132.                 OLED_ShowCHinese(54,0,3);//电
  133.                 OLED_ShowCHinese(72,0,4);//子
  134.                 OLED_ShowCHinese(90,0,5);//科
  135.                 OLED_ShowCHinese(108,0,6);//技
  136.                 */
  137. //                t=' ';
  138.           OLED_Clear();
  139.           while(1)
  140.         {
  141.         //        LED_ON;
  142.                 t = Hcsr04GetLength();
  143.                 OLED_ShowCHinese(0,0,0);//中
  144.                 OLED_ShowCHinese(18,0,1);//景
  145.                 OLED_ShowCHinese(36,0,2);//园
  146.                 OLED_ShowCHinese(54,0,3);//电
  147.                 OLED_ShowCHinese(72,0,4);//子
  148. //                OLED_ShowCHinese(90,0,5);//科
  149. //                OLED_ShowCHinese(108,0,6);//技
  150. //                OLED_ShowString(0,3,"1.3' OLED TEST");
  151.                 //OLED_ShowString(8,2,"ZHONGJINGYUAN");
  152.          //        OLED_ShowString(20,4,"2014/05/01");
  153.                 OLED_ShowString(70,3,"CM");
  154. //                OLED_ShowString(63,6,"CODE:");
  155. //                OLED_ShowChar(48,6,t);//显示ASCII字符
  156. //                t++;
  157. //                if(t>'~')t=' ';
  158.                 OLED_ShowNum(30,3,t,4,16);//显示ASCII字符的码值
  159. //
  160. //
  161.                 delay_ms(8000);
  162. //                OLED_Clear();
  163. //                delay_ms(8000);
  164. //        //                LED_OFF;
  165. //                OLED_DrawBMP(0,0,128,8,BMP1);  //图片显示(图片显示慎用,生成的字表较大,会占用较多空间,FLASH空间8K以下慎用)
  166. //                delay_ms(8000);
  167. //                OLED_DrawBMP(0,0,128,8,BMP2);
  168. //                delay_ms(8000);
  169.         }
  170.
  171. }
全部资料51hei下载地址:
超声波.7z (194.39 KB, 下载次数: 49)
收藏收藏3 分享淘帖 顶 踩
