查看: 5027|回复: 4
ili9488驱动程序
ID:297330 发表于 2020-4-4 08:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include"LCD drive.h"
  2. // ili9488 init code
  3. void init_9488()
  4. {
  5.                 LLCD_WRITE_CMD(0xE0); //P-Gamma
  6.                 LLCD_WRITE_DATA(0x00);
  7.                 LLCD_WRITE_DATA(0x03);
  8.                 LLCD_WRITE_DATA(0x0C);
  9.                 LLCD_WRITE_DATA(0x09);
  10.                 LLCD_WRITE_DATA(0x17);
  11.                 LLCD_WRITE_DATA(0x09);
  12.                 LLCD_WRITE_DATA(0x3E);
  13.                 LLCD_WRITE_DATA(0x89);
  14.                 LLCD_WRITE_DATA(0x49);
  15.                 LLCD_WRITE_DATA(0x08);
  16.                 LLCD_WRITE_DATA(0x0D);
  17.                 LLCD_WRITE_DATA(0x0A);
  18.                 LLCD_WRITE_DATA(0x13);
  19.                 LLCD_WRITE_DATA(0x15);
  20.                 LLCD_WRITE_DATA(0x0F);
  21.                 LLCD_WRITE_CMD(0XE1); //N-Gamma
  22.                 LLCD_WRITE_DATA(0x00);
  23.                 LLCD_WRITE_DATA(0x11);
  24.                 LLCD_WRITE_DATA(0x15);
  25.                 LLCD_WRITE_DATA(0x03);
  26.                 LLCD_WRITE_DATA(0x0F);
  27.                 LLCD_WRITE_DATA(0x05);
  28.                 LLCD_WRITE_DATA(0x2D);
  29.                 LLCD_WRITE_DATA(0x34);
  30.                 LLCD_WRITE_DATA(0x41);
  31.                 LLCD_WRITE_DATA(0x02);
  32.
  33.                 LLCD_WRITE_DATA(0x0B);
  34.                 LLCD_WRITE_DATA(0x0A);
  35.                 LLCD_WRITE_DATA(0x33);
  36.                 LLCD_WRITE_DATA(0x37);
  37.                 LLCD_WRITE_DATA(0x0F);
  38.                 LLCD_WRITE_CMD(0XC0); //Power Control 1
  39.                 LLCD_WRITE_DATA(0x17); //Vreg1out
  40.                 LLCD_WRITE_DATA(0x15); //Verg2out
  41.                 LLCD_WRITE_CMD(0xC1); //Power Control 2
  42.                 LLCD_WRITE_DATA(0x41); //VGH,VGL
  43.                 LLCD_WRITE_CMD(0xC5); //Power Control 3
  44.                 LLCD_WRITE_DATA(0x00);
  45.                 LLCD_WRITE_DATA(0x12); //Vcom
  46.                 LLCD_WRITE_DATA(0x80);
  47.                 LLCD_WRITE_CMD(0x36); //Memory Access
  48.                 LLCD_WRITE_DATA(0x48);
  49.                 LLCD_WRITE_CMD(0x3A); // Interface Pixel Format
  50.                 LLCD_WRITE_DATA(0x66);
  51.                 LLCD_WRITE_CMD(0XB0); // Interface Mode Control
  52.                 LLCD_WRITE_DATA(0x00);
  53.                 LLCD_WRITE_CMD(0xB1); //Frame rate
  54.                 LLCD_WRITE_DATA(0xA0); //60Hz
  55.                 LLCD_WRITE_CMD(0xB4); //Display Inversion Control
  56.                 LLCD_WRITE_DATA(0x02); //2-dot
  57.                 LLCD_WRITE_CMD(0XB6); //RGB/MCU Interface Control
  58.                 LLCD_WRITE_DATA(0x02); //MCU
  59.                 LLCD_WRITE_DATA(0x02); //Source,Gate scan dieection
  60.
  61.                 LLCD_WRITE_CMD(0XE9); // Set Image Function
  62.                 LLCD_WRITE_DATA(0x00); // Disable 24 bit data input
  63.                 LLCD_WRITE_CMD(0xF7); // Adjust Control
  64.                 LLCD_WRITE_DATA(0xA9);
  65.                 LLCD_WRITE_DATA(0x51);
  66.                 LLCD_WRITE_DATA(0x2C);
  67.                 LLCD_WRITE_DATA(0x82); // D7 stream, loose
  68.                 LLCD_WRITE_CMD(0x11); //Sleep out
  69.                 delayms(120);
  70.                 LLCD_WRITE_CMD(0x29); //Display on
  71. }
  72. void set_win_9488()
  73. {
  74.                 LLCD_WRITE_CMD(0x2A);
  75.                 LLCD_WRITE_DATA(0x00);
  76.                 LLCD_WRITE_DATA(0x00);
  77.                 LLCD_WRITE_DATA(0x01);
  78.                 LLCD_WRITE_DATA(0x3f);
  79.                 LLCD_WRITE_CMD(0x2B);
  80.                 LLCD_WRITE_DATA(0x00);
  81.                 LLCD_WRITE_DATA(0x00);
  82.                 LLCD_WRITE_DATA(0x01);
  83.                 LLCD_WRITE_DATA(0xdf);
  84.                         LLCD_WRITE_CMD(0x002C);
  85. }
  86. void set_point_9488(unsigned int x,unsigned int y)
  87. {
  88.                 LLCD_WRITE_CMD(0x002A);
  89.                 LLCD_WRITE_DATA((x>>8)&0xff)                ;
  90.                 LLCD_WRITE_DATA(x&0xff);
  91.                 LLCD_WRITE_CMD(0x002B);
  92.                 LLCD_WRITE_DATA((y>>8)&0xff);
  93.                 LLCD_WRITE_DATA(y&0xff);
  94.
  95.                 LLCD_WRITE_CMD(0x002C);
  96. }
收藏收藏3 分享淘帖 顶 踩
ID:1 发表于 2020-4-4 15:51 | 只看该作者
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
ID:658039 发表于 2020-12-25 08:42 | 只看该作者
听说ili9488与ST7796驱动是一样的,有人用过吗?
ID:61140 发表于 2022-7-6 18:00 | 只看该作者
不一样
两种芯片各有各的驱动方式.
ID:1039275 发表于 2022-7-20 09:40 | 只看该作者
问下,你用的是SPI接口吗?
