查看: 1640|回复: 1
单片机实现分钟计时器,从00.00都59.59,不知道哪里错了。求大佬答疑!
ID:718035 发表于 2020-4-6 13:57 | 显示全部楼层 |阅读模式
#include<reg52.h>
sbit a=P1^0;
sbit b=P1^1;
unsigned char code discode1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef};
unsigned char code discode2[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar counter=0;
uchar key=0;
uchar second=0;
uchar minute=0;
main()
          a=1;
          b=0;
    TMOD=0X01;
    TH0=0xDc;
    TL0=0x00;
           EA=1;
    ET0=1;
    TR0=1;
        if((P3&0x80)==0x00)
           key++;
           switch(key)
              case 1:
                P2=0x7f;   //11111111
                P0=discode2[second%10];
                break;
              case 2:
                P2=0xbf;      //10111111
                P0=discode2[second/10];
                break;
              case 3:
                P2=0xdf;       //11011111
                P0=discode2[minute%10];
                break;
void zhongduan()interrupt 1
    TH0=0xee;
    TL0=0x00;
    TF0=0;
    TR0=1;
    counter++;
    if(counter==200)
       counter=0;
       second++;
       if(second==60)
          second=0;
          minute++;
ID:584814 发表于 2020-4-15 15:15 | 显示全部楼层
key++,加到  key 的值大于 4 以后呢 ?
