查看: 2939|回复: 0
stm32F401,HSI作为时钟源PLL为时钟,PD2产生10K方波
  1. #include "stm32f4xx.h"
  2. #include "stm32f4xx_hal_gpio.h"
  3. #include "stm32f4xx_hal_rcc.h"
  4. // define busses presscalers High-speed APB (APB2) and low-speed APB (APB1)
  5. #define AHB_PRE         1                                        // 1, 2, 4, 8, 16, 64, 128, 256, 512
  6. #define APB1_PRE        2                                        // 1, 2, 4, 8, 16
  7. #define APB2_PRE        1                                        // 1, 2, 4, 8, 16
  8. #define SysTicksClk        10000                                // SysTick Freq = 10kHz
  9. // calculate peripheral frequencies
  10. #define SYSCLK                        46000000
  11. #define AHB                                SYSCLK/AHB_PRE
  12. #define APB1                        AHB/APB1_PRE
  13. #define APB1_TIM                APB1*2
  14. #define APB2                        AHB/APB2_PRE
  15. #define APB2_TIM                APB2*1
  16. #define SysTicks                AHB/SysTicksClk//4.6k 10k 0.1ms
  17. static void SetSysClock(void);
  18. int main()
  19. {
  20.         SetSysClock();
  21.         SysTick_Config(SysTicks);
  22.         // <=> RCC->AHB1ENR = RCC_AHB1ENR | 1 << 0 | 1 << 1
  23.         RCC->AHB1ENR |= RCC_AHB1ENR_GPIOAEN |
  24.                                         RCC_AHB1ENR_GPIOBEN |
  25.                                         RCC_AHB1ENR_GPIODEN; // GPIOD for CLK OUT
  26.         // LED1 connected to PA0, LED2 connected to PA6
  27.         GPIOA->MODER |= 1 << (0*2) | 1 << (6*2); // here 2 bits to code mode of 1 pin
  28.         GPIOD->MODER |= 1 << (2*2);
  29.
  30.         while(1)
  31.         {
  32.                 if(!(GPIOB->IDR & GPIO_IDR_ID0))
  33.                 {
  34.                         GPIOA->ODR |= 1 << 0; // LED1 ON
  35.                         GPIOA->ODR &= ~(1 << 6);
  36.                 }
  37.                 else
  38.                 {
  39.                         GPIOA->ODR &= ~(1 << 0); // LED2 ON
  40.                         GPIOA->ODR |= 1 << 6;
  41.                 }
  42.         }
  43. }
  44. // SysTick Interrupt Handler
  45. void SysTick_Handler(void) // SysTicksClk = 10kHz, 0.0001s time=1/freq
  46. {
  47.         // pin state pediod = 0.0001s
  48.         // Frequencies output = 2*period = 0.0002s time=1/freq 5kHz 0.2ms
  49.         if(GPIOD->ODR & GPIO_ODR_OD2)
  50.         {
  51.                 GPIOD->BSRR |= GPIO_BSRR_BR2;
  52.         }
  53.         else
  54.         {
  55.                 GPIOD->BSRR |= GPIO_BSRR_BS2;
  56.         }
  57. }
  58. static void SetSysClock(void)
  59. {
  60. /****************************************************************************/
  61. /*            PLL (clocked by HSI) used as System clock source              */
  62. /****************************************************************************/
  63.         //__IO uint32_t StartUpCounter = 0, HSIStatus = 0;
  64.         if ((RCC->CR & RCC_CR_HSIRDY) != RESET)
  65.         {
  66.                 /* Configure Flash prefetch, Instruction cache, Data cache and wait state */
  67.                 FLASH->ACR |= FLASH_ACR_PRFTEN;
  68.                 FLASH->ACR |= FLASH_ACR_LATENCY_2WS;
  69.                 /* HCLK = SYSCLK / 1*/
  70.                 RCC->CFGR &= ~RCC_CFGR_HPRE_Msk;  // AHBx=SYSCLK / AHB_PRE
  71.                 RCC->CFGR |= RCC_CFGR_HPRE_DIV1;
  72.                 /* PCLK2 = HCLK / 2*/
  73.                 RCC->CFGR &= ~RCC_CFGR_PPRE1_Msk; // APB2 = AHBx / APB2_PRE
  74.                 RCC->CFGR |= RCC_CFGR_PPRE1_DIV2;
  75.                 /* PCLK1 = HCLK / 4*/
  76.                 RCC->CFGR &= ~RCC_CFGR_PPRE2_Msk; // APB1 = AHBx / APB1_PRE
  77.                 RCC->CFGR |= RCC_CFGR_PPRE2_DIV1;
  78.                 /* Configure the main PLL */
  79.                 // RCC->PLLCFGR |= RCC_PLLCFGR_PLLSRC;
  80.                 // RCC_PLLCFGR_PLLM=16, RCC_PLLCFGR_PLLN=46, RCC_PLLCFGR_PLLP=2,
  81.                 RCC->PLLCFGR &= ~RCC_PLLCFGR_PLLM_Msk;
  82.                 RCC->PLLCFGR |= 16 << RCC_PLLCFGR_PLLM_Pos;
  83.                 RCC->PLLCFGR &= ~RCC_PLLCFGR_PLLN_Msk;
  84.                 RCC->PLLCFGR |= 92 << RCC_PLLCFGR_PLLN_Pos;
  85.                 RCC->PLLCFGR &= ~RCC_PLLCFGR_PLLP_Msk;
  86.                 /* Enable the main PLL */
  87.                 RCC->CR |= RCC_CR_PLLON;
  88.                 /* Wait till the main PLL is ready */
  89.                 while ((RCC->CR & RCC_CR_PLLRDY) == 0)
  90.                 {}
  91.                 /* Select the main PLL as system clock source */
  92.                 RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  93.                 RCC->CFGR |= RCC_CFGR_SW_PLL;
  94.                 /* Wait till the main PLL is used as system clock source */
  95.                 while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS ) != RCC_CFGR_SWS_PLL)
  96.                 {}
  97.         }
  98. }
