查看: 7248|回复: 3
红外接收程序问题!!帮忙看看
ID:8704 发表于 2009-6-5 11:56 | 显示全部楼层 |阅读模式
#include <reg52.h>
#include <lcd.h>
#include <epprom.h>
unsigned int temp_low_pulse1;
unsigned int temp_low_pulse0;
unsigned int temp_high_pulse1;
unsigned int temp_high_pulse0;
unsigned int count;
unsigned char write_enable;
sbit led8=P0^7;
sbit key=P0^0;
sbit key1=P0^1;
sbit key2=P0^2;
/*********      延时1S     ******************************************/
void delay_1s()
 unsigned int i,j;
 for(i=5;i>0;i--)
  for(j=110;j>0;j--);
void initial()
 EA=1; //开启总中断
 EX1=1; //开启外部中断1
 IT1=1; //外部中断1为下降沿有效
 TMOD=0x19; //定时器1,2 方式为1,且T0 GATE位有效
 TH0=0x00;
 TL0=0x00;
 TH1=0x00;
 TL1=0x00;
 count=0;
 unsigned char temp,temp_ge,temp_shi,temp_bai,num_ge,num_shi,num_bai,num_qian;
 unsigned int  count_qian,count_bai,count_shi,count_ge,num;
 initial();
 init();
 lcd_int();
 num=0;
  if(key==0)
   num++;
   if(num==2048)
   num=0;
   while(!key);
  if(key1==0)
   if(num==0)
    num=2048;
     num--;
   while(!key1);
 if(count>=2048)
  count=0;
 temp=read_add(num);
 temp_bai=temp/100;
 temp_shi=temp%100/10;
 temp_ge=temp%10;
 num_qian=num/1000;
 num_bai=num%1000/100;
 num_shi=num%100/10;
 num_ge=num%10;
 count_qian=count/1000;
 count_bai=count%1000/100;
 count_shi=count%100/10;
 count_ge=count%10;
 write_com(0x80);
 write_date(0x30+temp_bai);
 write_com(0x81);
 write_date(0x30+temp_shi);
 write_com(0x82);
 write_date(0x30+temp_ge);
 write_com(0x84);
 write_date(0x30+num_qian);
 write_com(0x85);
 write_date(0x30+num_bai);
 write_com(0x86);
 write_date(0x30+num_shi);
 write_com(0x87);
 write_date(0x30+num_ge);
 write_com(0x89);
 write_date(0x30+count_qian);
 write_com(0x8a);
 write_date(0x30+count_bai);
 write_com(0x8b);
 write_date(0x30+count_shi);
 write_com(0x8c);
 write_date(0x30+count_ge);
 if (write_enable==1)
 write_add(count,5);   //将红外信号的低电平的值写入储存器COUNT地址内
 delay_1s();
 write_add(count+1,6);   //将红外信号的低电平的值写入储存器COUNT+1地址内
 delay_1s();
 write_add(count+2,7);  //将红外信号的高电平的值写入储存器COUNT+2地址内
 delay_1s();
 write_add(count+3,8);  //将红外信号的高电平的值写入储存器COUNT+3地址内
 delay_1s();
 write_enable=0;
void int1() interrupt 2
    EX1=0;          //关外部中断1
 TR0=0;          //关闭定时器0
 TR1=0;          //关闭定时器1
 temp_low_pulse1=TH1-TH0;     //将TH1减去TL0的值(即红外信号的低电平)赋予temp_low_pulse1
 temp_low_pulse0=TL1-TL0;         //将TL1减去TL0的值(即红外信号的低电平)赋予temp_low_pulse0
 temp_high_pulse1=TH0;      //将TH0值(即红外信号的高电平值)赋予temp_high_pulse1
 temp_high_pulse0=TL0;      //将TL0值(即红外信号的高电平值)赋予temp_high_pulse0
 write_enable=1;
 TH0=0x00;         //TH0清零
 TL0=0x00;         //TL0清零
 TH1=0x00;         //TH1清零
 TL1=0x00;         //TL1清零
 TR0=1;          //启动定时器0
 TR1=1;          //启动定时器1
 led8=!led8;
 count=count+4;
 EX1=1;          //开外部中断1
本人编写了一个红外接收的程序,红外接收管接收端接单片机中断1,接收的红外波形以后,开启T0,T1定时器,对红外波形的高低电平及时,其中中断下降沿开启T1计时,电平升高后开启T0计时,T1-T0的时间就是红外波形的低电平时间,我利用AT24C16芯片保存定时时间,根据写的程序,在两次中断间隙时间过短了,没有足够的时间写进存储芯片,怎么解决啊?
ID:8704 发表于 2009-6-10 11:34 | 显示全部楼层
ID:16415 发表于 2009-8-28 11:32 | 显示全部楼层
 顶一下,我也在弄红外呢呵呵
ID:16651 发表于 2009-8-28 20:08 | 显示全部楼层
不知道你的问题解决了吗  我前一段时间也谢了一个简单的红外程序  传到http://sjcxlab.5d6d.com/thread-46-1-1.html  这里了  有兴趣的可以去看一下~~~~
