查看: 3178|回复: 2
789.C(275): error C202: 'time': undefined identifier出现这种情况是怎么回事
ID:730519 发表于 2020-4-16 14:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<stdio.h>
#define THC0 0xf9
#define TLC0 0x0f //2ms
unsigned char code Duan[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};//????????????0-9?????;
unsigned char Data_Buffer[8]={0,0,0,0,0,0,0,0};//???????
uchar i=0;
sbit AddSpeed=P1^1;
sbit SubSpeed=P1^2;
sbit PWM_FC=P1^0;
int e,e1,e2;
float uk,uk1,duk;//pid#?4W
float Kp=10,Ki=12,Kd=1.6;
int out=0;
uint SpeedSet=380;
uint cnt=0;
uint Inpluse=0,num=0;//Hk>#i+#l
uint PWMTime=100;//??????
unsigned char arry[];
void SendString(uint ch);
void PIDControl();
void Systemlnit();
void delay(uchar x);
void PWMOUT();
void SetSpeed();
void SegRefre();
Systemlnit();
SetSpeed();
SegRefre();
PWMOUT();
void PIDControl()//pid??????
e=SpeedSet-num;//???=?趨?-1s??
duk=(Kp*(e-e1)+Ki*e+Kd*(e-2*e1+e2))/50;//?????PID???/50 ???duk??????С????
uk=uk1+duk;
out=(int)uk; //????????
if(out>1000)
out=1000;
else if(out<0)
out=0;
uk1=uk;//???????λ
e2=e1;
e1=e;
PWMTime=out;
void delay( uchar x)
uint i,j;
for(i=x;i>0;i--)
for(j=50;j>0;j--);
void PWMOUT()
if(cnt<PWMTime)
PWM_FC=1;
PWM_FC=0;
if(cnt>1000) cnt=0;
void Systemlnit()
TMOD=0x21;
TH0=THC0;
TL0=TLC0;
TH1=0xC0;
TL1=0XC0;
ET1=1;
ET0=1;
TR0=1;
TR1=1;
EX0=1; //?ж?0?? ?????????
IT0=1;
EA=1;
e=0;//????????
e1=0;
e2=0;
void SetSpeed()
if(AddSpeed==0)
delay(200);//????????
if(AddSpeed==0)
SpeedSet+=10;
if(SpeedSet>1500)
SpeedSet=1500;
if(SubSpeed==0)
delay(200);
if(SubSpeed==0)
SpeedSet-=10;
if(SpeedSet<0) SpeedSet=0;
void SegRefre()//??????
Data_Buffer[0]=SpeedSet/1000;
Data_Buffer[1]=SpeedSet%1000/100;
Data_Buffer[2]=SpeedSet%100/10;
Data_Buffer[3]=SpeedSet%10;
Data_Buffer[4]=num/1000;
Data_Buffer[5]=num%1000/100;
Data_Buffer[6]=num%100/10;
Data_Buffer[7]=num%10;
voidint0()interrupt 0
Inpluse++;//?????????
void int0() interrupt 0
static unsigned char Bit=0;
TH0=THC0;
TL0=TLC0;
Bit++;
time++; //??????????
if(Bit>8) Bit=0;
P0=0xff;
P2=Duan[Data_ .Buffer[Bit]]; // ???????
switch(Bit)//?????λ?
case 0:P0=0X7F;break;
case 1:P0=0XBF;break;
case 2:P0=0XDF;break;
case 3:P0=0XEF;break;
case 4:P0=0XF7;break;
case 5:P0=0XFB;break;
case 6:P0=0XFD;break;
case 7:P0=0XFE;break;
if (time>100)
time=0;
num=lnpluse*5;//???1s?????????
Inpluse=0;
PIDControl();//????PID???????PWM
void timer_1() interrupt 3
cnt++; //cnt??? ???????2.5Khz}
ID:730519 发表于 2020-4-16 14:03 | 只看该作者
compiling 789.c...
789.C(305): error C202: 'time': undefined identifier
789.C(309): error C202: 'time': undefined identifier
789.C(311): error C202: 'lnpluse': undefined identifier
789.c - 4 Error(s), 0 Warning(s).
问题有点多  一下午看不出来
ID:452950 发表于 2020-4-16 15:15 | 只看该作者
time和Inpluse未定义
