查看: 1552|回复: 0
求一单片机程序思路,将采集的数据存入at24c1024中,下有采集程序和原理图
#include <reg51.h>
uchar code LEDData[]=
         0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
sbit OE  = P1^0;
sbit EOC = P1^1;
sbit ST  = P1^2;
sbit CLK = P1^3;
sbit SDA = P2^7;
sbit SCL = P2^6;
void DelayMS(uint ms)
         uchar i;
        while(ms--)
                 for(i=0;i<120;i++);
void Display_Result(uchar d)
         P2 = 0xf7;
        P0 = LEDData[d%10];
        DelayMS(5);
        P2 = 0xfb;
        P0 = LEDData[d%100/10];
        DelayMS(5);
        P2 = 0xfd;
        P0 = LEDData[d/100];
        DelayMS(5);
         TMOD = 0x02;
        TH0  = 0x14;
        TL0  = 0x00;
        IE   = 0x82;
        TR0  = 1;
        P1   = 0x3f;
                 ST = 0;
                ST = 1;
                ST = 0;
                while(EOC == 0);
                OE = 1;
                Display_Result(P3);
                OE = 0;
void Timer0_INT() interrupt 1
         CLK = !CLK;
