查看: 3939|回复: 3
求助:单片机1602/LM016L显示屏只显示一半内容
和师兄一起做了一个控制充放电的一个小电路,程序编译成hex文件显示屏只能显示预计一半内容,琢磨了一天没找到原因,求大神指点
实物预计用1602,proteus里面选用的是LM016L。D0到D7是接到了P0口上。全部程序太长所以只发了与显示屏相关的程序
sbit RS=P2^0;
sbit RW=P2^1;
sbit EN=P2^2;
uchar     code table1[]=" TYNCFDKZQXTS";
unsigned char code table2[]=" S:12.0 N:";
unsigned char code lcdd[]="0123456789";
uchar xs_vo,num;
#ifndef _YJ1602_H
#define _YJ1602_H
void init1602()
        EN=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
void write_com(uchar com)
        RW=0;        delay1();
        RS=0;
        delay1();
        EN=1;
        delay1();
        P0=com;
        delay1();
        EN=0;        delay1();
        delay(5);
void write_data(uchar date)
   RW=0;  delay1();
   RS=1;
   delay1();
   EN=1;
   delay1();
   P0=date;
   delay1();
   EN=0;   delay1();
   delay(5);
void yj1602()
{        uchar xs_vo;
        init1602();
        xs_vo=battery_v;
        V1=xs_vo/100;
    V2=xs_vo%100/10;
        V3=xs_vo%10;
        write_com(0x80+0x10);
        for(num=0;num<14;num++)
                write_data(table1[num]);
                delay(5);
        write_com(0x80+0x50);
        write_data(' ');
        delay(5);
        write_data('S');
        delay(5);
        write_data(':');
        write_data(' ');
        delay(5);
        write_data(lcdd[1]);
        delay(5);
        write_data(lcdd[2]);
        delay(5);
        write_data('.');
        delay(5);
        write_data(lcdd[0]);
        delay(5);
        write_data(' ');
        delay(5);
        write_data(' ');
        delay(5);
        write_data('N');
        delay(5);
        write_data(':');
        delay(5);
        write_data(lcdd[V1]);
        delay(5);
        write_data(lcdd[V2]);
        delay(5);
        write_data('.');
        delay(5);
        write_data(lcdd[V3]);
        delay(5);
        for(num=0;num<16;num++)
                write_com(0x1c);
                delay(1000);
ID:584814 发表于 2020-4-29 13:28 | 只看该作者
你写的就是你想的,显示的就是你写的。
ID:213173 发表于 2020-4-29 17:52 | 只看该作者
起始显示位置与整体左移位置不当,超出范围。
                delay(5);
                write_com(0x1c);
                delay(1000);
ID:740738 发表于 2020-4-29 21:33 来自触屏版 | 只看该作者
问题解决了,谢谢大佬
