查看: 2713|回复: 2
ADXL345自动休眠配置
ID:588723 发表于 2020-4-29 11:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. u8 ADXL345_Init(uint8 AClimit,uint8 STlimit,uint8 time)
  2. {
  3.   IIC_Init();                                                        //初始化IIC总线
  4.   if(ADXL345_RD_Reg(DEVICE_ID)==0XE5)        //读取器件ID
  5.   {
  6.     ADXL345_RD_Reg(0x30);
  7.     ADXL345_WR_Reg(DATA_FORMAT,0X0B);//   中断高低电平触发
  8.     ADXL345_WR_Reg(BW_RATE,0x1c);   // 低功耗 和速率设置
  9.     ADXL345_WR_Reg(POWER_CTL,0x28);
  10.     ADXL345_WR_Reg(INT_ENABLE,0x00);
  11.     ADXL345_WR_Reg (0x2d, 0x38);  // measure and wake up 8hz  08   38
  12.     ADXL345_WR_Reg (0x24, AClimit); //活动触发阈值
  13.     ADXL345_WR_Reg (0x27, 0xff); //比较法 3轴比较
  14.     ADXL345_WR_Reg (0x2b, 0x70); //第一 轴比较
  15.     ADXL345_WR_Reg (0x2F, 0x10);  // int map reg 0 means INT2中断选择
  16.     ADXL345_WR_Reg (0x2E, 0x18);  // int enable reg 中断开启
  17.     ADXL345_WR_Reg (0x25, STlimit); //静止阈值
  18.     ADXL345_WR_Reg (0x26, time); //静止触发时间 s
  19.     ADXL345_WR_Reg(OFSX,0x00);
  20.     ADXL345_WR_Reg(OFSY,0x00);
  21.     ADXL345_WR_Reg(OFSZ,0x00);
  22.     ADXL345_RD_Reg(0x30);
  23.     return 0;
  24.   }
  25.   return 1;
  26. }
ID:588723 发表于 2020-4-29 11:39 | 只看该作者
实测能正常使用  能设置休眠时间  唤醒阈值 和休眠阈值
ID:588278 发表于 2021-12-16 14:57 | 只看该作者
活动触发阈值有大小限制吗?比如必须得大于1g?
