查看: 4461|回复: 0
单片机0-99计时器设计(PROTEUS仿真+源程序)
今天刚做出的计数器,资料很全面,各位可以用来参考
程序如下:
                #include<reg51.h>
uchar code DSY_CODE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
//计数值分解后的各待显示数位
uchar Display_Buffer[3]={0,0,0};
uint Count = 0;
sbit Clear_Key = P3^6;
//在数码管上显示计数值
void Show_Count_ON_DSY()
  Display_Buffer[1] = Count % 100/10;
  Display_Buffer[0] = Count %10;
  if(Display_Buffer[1] == 0) //高位为0时不显示
    Display_Buffer[2] = 0x0a;
    //高位为0时,如果第二位为0则同样不显示
    if(Display_Buffer[1] == 0 ) Display_Buffer[1] = 0x0a;
P1=DSY_CODE[Display_Buffer[0] ];
P2=DSY_CODE[Display_Buffer[1] ];
P0=0xff;
P1=0xff;
P2=0xff;
IE=0x81;
IT0=1;
if(Clear_Key==0)
  Count = 0;
   Show_Count_ON_DSY();
//INTO中断函数
void EX_INT0() interrupt 0
Count++;
0-99计数器设计仿真+源码.rar (50.88 KB, 下载次数: 26)
收藏收藏2 分享淘帖 顶顶 踩踩
