查看: 2817|回复: 4
*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS无法生成hex文件
#include <reg51.h>
#define SEG P2
#define SCAN P3
#define uint  unsigned int
uchar shu[] = {0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xf9,0x80,0xc0,0xb0,0xc0,0xf8,0xc0,0x80,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};//18030708
uchar seg[10] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar sel[8] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char count=0;
unsigned int y,m;
void Timer0Interrupt(void) interrupt 1
    TH0 = 0x3C;
    TL0 = 0x0B0;
    count++;
void delay_1ms(uint x)
        uint i,j;
        for(i=0; i<x; i++)
           for(j=0; j<120; j++);
void InitTimer0(void)
    TMOD = 0x01;
    TH0 = 0x3C;
    TL0 = 0x0B0;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
               for(m=0;m<8;m++)
                SCAN = ~0xff;
                SEG = shu[y+m];
                SCAN = ~sel[m];
                delay_1ms(1);
if(count==20){count=0;break;}}
void main(void)
           for(y=0;y<15;y++)
        InitTimer0();
ID:750491 发表于 2020-5-13 09:43 | 只看该作者
就是出现了这个*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS
ID:213173 发表于 2020-5-13 10:14 | 只看该作者
ID:584814 发表于 2020-5-13 11:49 | 只看该作者
Keil 5 表示生成无压力。ERROR L104: MULTIPLE PUBLIC DEFINITIONS可能是低版本的没处理好变量以为是有重复定义,如果坚持在低版本上生成可将似是而非的不同之处搞大点而不仅在大小写。
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
ID:686878 发表于 2020-5-13 13:11 | 只看该作者
用Keil 4编译没有错误啊
