查看: 3353|回复: 0
[轉發]F28335 spwm生成程序
ID:754925 发表于 2020-5-18 20:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* * main.c */#include "DSP2833x_Project.h"
void InitEPwm1Example(void);void Gpio_Setup(void);interrupt void epwm1_isr(void);
int N=60;float M=0.8;int i;
float sina[30]={0.0000, 0.1081, 0.2150, 0.3193, 0.4199, 0.5156,                0.6052, 0.6877, 0.7622, 0.8277, 0.8835, 0.9290,                0.9635, 0.9868, 0.9985, 0.9985, 0.9868, 0.9635,                0.9290, 0.8835, 0.8277, 0.7622, 0.6877, 0.6052,                0.5156, 0.4199, 0.3193, 0.2150, 0.1081, 0.0000};
float sinb[30]={0.8660, 0.8069, 0.7383, 0.6610, 0.5760, 0.4843,                0.3868, 0.2849, 0.1796, 0.0722, -0.0361, -0.1439,                -0.2501, -0.3533, -0.4524, -0.5462, -0.6335, -0.7135,                -0.7850, -0.8474, -0.8998, -0.9417, -0.9726, -0.9920,                -0.9998, -0.9959, -0.9803, -0.9533, -0.9150, -0.8660};
int main(void) {        InitSysCtrl();  //初始化系统控制        InitEPwm1Gpio();        Gpio_Setup();   //子函数,gpio口设置        DINT;           //关闭中断        InitPieCtrl();  //初始化中断控制        IER = 0x0000;        IFR = 0x0000;        InitPieVectTable();//初始化中断矢量表
        EALLOW;  // This is needed to write to EALLOW protected registers        PieVectTable.EPWM1_INT = &epwm1_isr;        EDIS;
        EALLOW;        SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;  //先置0,进行ePWM配置,再置1        EDIS;
        InitEPwm1Example();
        EALLOW;        SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;  //看上一个注释        EDIS;
        i=1;
        IER |= M_INT3;
        // Enable EPWM INTn in the PIE: Group 3 interrupt 1-3        PieCtrlRegs.PIEIER3.bit.INTx1 = 1;
        // Enable global Interrupts and higher priority real-time debug events:        EINT;   // Enable Global interrupt INTM        ERTM;   // Enable Global realtime interrupt DBGM
        for(;;){            __asm("          NOP");        }
void Gpio_Setup(void){    EALLOW;    GpioCtrlRegs.GPAMUX1.bit.GPIO0=1;   //GPIO0配置为ePWM1A功能    GpioCtrlRegs.GPAMUX1.bit.GPIO1=1;   //GPIO1配置为ePWM1B功能    EDIS;}
void InitEPwm1Example(void){       // Setup TBCLK       EPwm1Regs.TBPRD = 0x61A8;                      // 3KHz       EPwm1Regs.TBPHS.half.TBPHS = 0x0000;           // Phase is 0       EPwm1Regs.TBCTR = 0;                           // 时基计数器清零       EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up       EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;        // Disable phase loading       EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;       // Clock ratio to SYSCLKOUT       EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;
       // Setup shadowing       EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;       EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;       EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;  // Load on Zero       EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
       // Set actions       EPwm1Regs.AQCTLA.bit.CAU = AQ_SET;             // Set PWM1A on event A, up count       EPwm1Regs.AQCTLA.bit.CAD = AQ_CLEAR;           // Clear PWM1A on event A, down count
       EPwm1Regs.AQCTLB.bit.CBU = AQ_SET;             // Set PWM1B on event B, up count       EPwm1Regs.AQCTLB.bit.CBD = AQ_CLEAR;           // Clear PWM1B on event B, down count
       // Interrupt where we will change the Compare Values       EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_PRD;      // Select INT on PRD event       EPwm1Regs.ETSEL.bit.INTEN = 1;                 // Enable INT       EPwm1Regs.ETPS.bit.INTPRD = ET_1ST;            // Generate INT on 1ST event
       EPwm1Regs.CMPA.half.CMPA=0x0C35;}
interrupt void epwm1_isr(void){
    if ((i>=0)&&(i<N/2)){        EPwm1Regs.CMPA.half.CMPA=EPwm1Regs.TBPRD*((1.0+M*sina[ i])/2.0);        EPwm1Regs.CMPB=EPwm1Regs.TBPRD*((1.0+M*sinb[ i])/2.0);    }
    if ((i>=N/2)&&(i<N)){        EPwm1Regs.CMPA.half.CMPA=EPwm1Regs.TBPRD*((1.0-M*sina[i-30])/2.0);        EPwm1Regs.CMPB=EPwm1Regs.TBPRD*((1.0-M*sinb[i-30])/2.0);    }
    i++;
    if (i>=N){        i=0;    }
    EPwm1Regs.ETCLR.bit.INT = 1;        //写1对ETFLG[INT]状态标志位清零,从而能进行下一次中断    PieCtrlRegs.PIEACK.all=PIEACK_GROUP3;}
收藏收藏2 分享淘帖 顶 踩
