麻烦各位大佬帮我看看吧
#include<reg52.h>
#include<stdio.h>
#include<string.h>
void initSer(); //串口初始化
uchar sendFlag = 0; //未发送数据时
uchar receFlag =0; //未接受到数据时
unsigned char dat;
char buf_string[4]; //定义数据包长度为15个字符
uint xs;
uint cc=0;
uint us;
//uint num=120;
uchar disbuffer[4];
sbit KEY = P3^2;
sbit KEY1 = P3^3;
sbit CLK=P3^7; //ê±?óD?o?
sbit ST=P3^4; //???ˉD?o?
sbit EOC=P3^5; //×a???áê?D?o?
sbit OE=P3^6; //ê?3?ê1?ü
sbit beep = P2^4;//zhuanhuan
sbit led = P2^5;
uchar dat,num,flag;//发送暂存变量
uchar LED_Buffer[3] = {0}; //从串口接收的数据
//uchar Buffer[2]={0};
uchar code table[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar i=0,flag;
int bai,shi,ge;
int shuzi=0;
uchar rlen = 0;
uchar Buffer[10];
uchar ii;
uchar Receive_Buffer[10];
uchar Buf_Index = 0;
uint rnum=0;
#include<reg51.h>
#include<intrins.h>
uchar bufr[]="------\r\n";//存放接收数据
uchar *prx=&bufr;//接收指针
bit str; //接收完毕标志位
//段码
uchar code leddata[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
//延时函数
void delay( uint i)
uint m,n;
for(m=i;m>0;m--)
for(n=90;n>0;n--);
//数码管显示函数
void led_display()
uchar i;
P2 = 0x01;
for(i=0;i<4;i++)
P0=0xff;
P2 = _cror_(P2,1);
P0 = leddata[bufr[i]-'0'];
delay(2);
//字符发送函数
void putchar(uchar data1)
SBUF = data1; //将待发送的字符送入发送缓冲器
while(!TI); //等待发送完成
TI = 0; //发送中断标志请0
//字符串发送函数
void putstring(uchar *dat)
while(*dat != '\0') //判断字符串是否发送完毕
putchar(*dat); //发送单个字符
dat++; //字符地址加1,指向先下一个字符
delay(5);
//串口初始化函数
void serial_init()
TMOD = 0x20; //定时器工作方式2
SCON = 0x50; //串行口工作方式2
PCON = 0x80; //SMOD = 1,波特率加倍
TH1 = 0xfa;
TL1 = 0xfa; //波特率设置9600
ES = 1;
EA = 1;//开总中断
serial_init();
TR1 = 1;
putstring("Receiving from 8051...\r\n");
putstring("----------------------\r\n");
delay(50);
while(!str);//等待接收完毕
P0=0xff;
while(!str);
led_display();
void serial() interrupt 4
if(RI!=1) return;//判断是否接收
str = 0;
ES = 0;
*prx = SBUF; //接收存放数据
putchar(*prx);
RI = 0;
prx++; //指针自加
if(*prx=='\0') //是否接收完成
prx = &bufr;//指针初始化
str = 1; //标志位置1
putstring("\r\n");
putstring("translate over!\r\n");
ES = 1;
return;
ES = 1;
return; //退出中断
void delay(uint i) //?óê±
uint j;
for(j=i;j>0;j--);
void delay_ms(unsigned int x)
uchar i;
while(x--)
for(i=0;i<120;i++);
/*******************ADC?áè?******************/
void display(void)
uchar codevalue[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00,0x40};
uchar chocode[]={0xf7,0xfb,0xfd,0xfe};
uchar i=0,p,t;
disbuffer[0]=(rnum%10);
disbuffer[1]=(rnum%100/10);
disbuffer[2]=(rnum/100);
for(i=0;i<4;i++)
t=chocode[i];
P2=t;
p=disbuffer[i];
t=codevalue[p];
P0=t;
delay(40);
P2=0xff;
void Timer0_INT() interrupt 1
TH0=(65536-10)/256;
TL0=(65536-10)%256;
CLK=~CLK;
* 名称 : Com_Init()
* 功能 : 串口初始化,晶振11.0592,波特率9600,使能了串口中断
* 输入 : 无
* 输出 : 无
void Com_Init(void)
SCON = 0x50;
TMOD = 0x20;
PCON = 0x00;
TH1 = 0xFd; //设置波特率 9600
TL1 = 0xFd;
TR1 = 1; //启动定时器1
ES = 1; //开串口中断
EA = 1; //开总中断
void check_led()
if(rnum>200)
led=0;
{ led=1;}
char putchar(char c)
SBUF = c;
while(TI == 0);
TI = 0;
return c;
void SendString(char *s)
while(*s)
putchar(*s);
s++;
* 名称 : Main()
* 功能 : 主函数
* 输入 : 无
* 输出 : 无
void Main()
SCON = 0x50;
TMOD = 0x21;
PCON = 0x00;
TH1 = 0xfd;
TL1 = 0xfd;
// TMOD|=0X02;
TH0=(65536-10)/256;
TL0=(65536-10)%256;
//// EX0 = 1;
//// IT0 = 1;
ES = 1; //
IP = 0x10;
TR1 = 1;
TR0 = 1;
OE=0;
ST=0;
ST=0;
ST=1;
ET0=1; /**/
EA = 1;
// TI=1;
//delay_ms(300);
//delay_ms(500);
//delay_ms(1000);
//delay_ms(1000);
// led=0;
#if 1
delay_ms(10);
if(Buf_Index>0) {
if(Buf_Index < 4) {
// if(Buf_Index == 3)rnum = (Receive_Buffer[0]-'0')*100+(Receive_Buffer[1]-'0')*10+(Receive_Buffer[2]-'0');
// else if(Buf_Index == 2)rnum = (Receive_Buffer[0]-'0')*10+(Receive_Buffer[1]-'0');
// else rnum = (Receive_Buffer[0]-'0');
if(Buf_Index == 3)rnum = (Receive_Buffer[0]-48)*100+(Receive_Buffer[1]-48)*10+(Receive_Buffer[2]-48);
else if(Buf_Index == 2)rnum = (Receive_Buffer[0]-48)*10+(Receive_Buffer[1]-48);
else rnum = (Receive_Buffer[0]-48);
if(rnum<256) {
SendString(Receive_Buffer);
for(ii=0;ii<sizeof(Receive_Buffer);ii++)Receive_Buffer[ii]=0;
Buf_Index=0;
else {
Buf_Index=0;
rnum = 0;
else {
Buf_Index=0;
if(EOC==1);
OE=1;
cc=P1;
OE=0;
ST=0;
ST=1;
ST=0;
display();
#endif
void Serial_INT() interrupt 4
uchar c;
if(RI==0)
return;
//ES = 0;
RI = 0;
c = SBUF;
if(c>='0' && c<='9')
Receive_Buffer[Buf_Index] = c;
Buf_Index++;
if(Buf_Index>10)Buf_Index=0;
// ES = 1;
