查看: 5545|回复: 2
单片机+74hc595 16X16点阵控制程序+Proteus仿真
点阵控制,因无法发图片
  1. #include<reg51.h>//头文件
  2. sbit shcp=P1^2;//数据输入时钟线 595的11脚
  3. sbit stcp=P1^1;//输出存储器锁存时钟线 595的12脚
  4. sbit ds=P1^0;//数据线  595的14脚
  5. sbit s1=P3^1;//按下暂停再暂按继续
  6. sbit s2=P3^2;//按下方向取反
  7. sbit s3=P3^3;//闪烁
  8. sbit s4=P3^4;  //切换内容
  9. sbit s5=P3^5; //加速
  10. sbit s6=P3^6;        //减速
  11. bit fx;//方向切换
  12. bit ss ;//闪烁切换
  13. int xsflag=0;
  14. int sd=10;
  15. int count;
  16. unsigned char alt;//数据移动定时时间
  17. unsigned int net;//控制显示的字符
  18. unsigned char zi1=7,zi2=3,zi3=3;
  19. unsigned int zong;//总字符  (所有的字数+1)*32   字数指的是汉字,字母、数字两个算一个数字
  20. unsigned char code tab1[]={
  21. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
  22. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
  23. 0x08,0x20,0x06,0x20,0x40,0x7E,0x31,0x80,0x00,0x01,0x7F,0xE2,0x40,0x0C,0x4F,0xF0,
  24. 0x40,0x08,0x7F,0xE4,0x00,0x00,0x1F,0xE2,0x00,0x01,0xFF,0xFE,0x00,0x00,0x00,0x00,/*"测",2*/
  25. 0x08,0x40,0x08,0x42,0x08,0x81,0xFF,0xFE,0x09,0x00,0x04,0x02,0x19,0x02,0x12,0x42,
  26. 0x14,0x42,0x90,0x42,0x70,0x7E,0x14,0x42,0x12,0x42,0x15,0x42,0x18,0x02,0x00,0x00,/*"控",3*/
  27. 0x08,0x20,0x08,0x22,0x08,0x41,0xFF,0xFE,0x08,0x80,0x09,0x01,0x10,0x01,0x11,0x02,
  28. 0x11,0xC2,0x11,0x34,0xFF,0x08,0x11,0x14,0x11,0x62,0x11,0x81,0x10,0x01,0x00,0x00,/*"技",4*/
  29. 0x00,0x08,0x08,0x10,0x08,0x20,0x08,0x40,0x08,0x80,0x0B,0x00,0x0C,0x00,0xFF,0xFF,
  30. 0x0C,0x00,0x0B,0x00,0x48,0x80,0x38,0x40,0x08,0x20,0x08,0x10,0x00,0x08,0x00,0x00,/*"术",5*/
  31.
  32. 0x00,0x10,0x00,0x10,0x07,0x10,0xF9,0x10,0x11,0x10,0x11,0x10,0x11,0x10,0x11,0x10,
  33. 0x11,0x10,0x11,0x12,0x11,0x01,0x11,0x02,0x11,0xFC,0x10,0x00,0x00,0x00,0x00,0x00,/*"与",6*/
  34.
  35. 0x00,0x80,0x01,0x00,0x06,0x00,0x1F,0xFF,0xE0,0x00,0x00,0x01,0x38,0x02,0x07,0x04,
  36. 0x80,0xC8,0x60,0x30,0x00,0xC8,0x07,0x04,0x78,0x02,0x00,0x01,0x00,0x01,0x00,0x00,/*"仪",7*/
  37. 0x01,0x10,0x01,0x10,0x79,0x2F,0x49,0x29,0x49,0x49,0x49,0x49,0x79,0x8F,0x07,0x00,
  38. 0x01,0x80,0x79,0x4F,0x4D,0x49,0x4B,0x29,0x49,0x29,0x79,0x1F,0x01,0x10,0x00,0x00,/*"器",8*/
  39. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",9*/
  40. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/
  41. };
  42. unsigned char code tab2[]={
  43. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
  44. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
  45. 0x10,0x04,0x1F,0xFC,0x10,0x84,0x00,0x80,0x00,0x80,0x10,0x84,0x1F,0xFC,0x10,0x04,/*"H",2*/
  46. 0x00,0x00,0x00,0xF8,0x01,0x24,0x01,0x24,0x01,0x24,0x01,0x24,0x00,0xE8,0x00,0x00,/*"e",3*/
  47. 0x00,0x00,0x08,0x04,0x08,0x04,0x1F,0xFC,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00,/*"l",4*/
  48. 0x00,0x00,0x08,0x04,0x08,0x04,0x1F,0xFC,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00,/*"l",5*/
  49. 0x00,0x00,0x00,0xF8,0x01,0x04,0x01,0x04,0x01,0x04,0x01,0x04,0x00,0xF8,0x00,0x00,/*"o",6*/
  50. 0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xCC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",7*/
  51. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",8*/
  52. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",9*/
  53.
  54. };
  55. unsigned char code tab3[]={
  56. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
  57. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
  58. 0x00,0x00,0x08,0x04,0x08,0x04,0x1F,0xFC,0x00,0x04,0x00,0x04,0x00,0x00,0x00,0x00,/*"1",2*/
  59. 0x00,0x00,0x0E,0x0C,0x10,0x14,0x10,0x24,0x10,0x44,0x11,0x84,0x0E,0x0C,0x00,0x00,/*"2",3*/
  60. 0x00,0x00,0x0C,0x18,0x10,0x04,0x11,0x04,0x11,0x04,0x12,0x88,0x0C,0x70,0x00,0x00,/*"3",4*/
  61. 0x00,0x00,0x00,0xE0,0x03,0x20,0x04,0x24,0x08,0x24,0x1F,0xFC,0x00,0x24,0x00,0x00,/*"4",5*/
  62. 0x00,0x00,0x1F,0x98,0x10,0x84,0x11,0x04,0x11,0x04,0x10,0x88,0x10,0x70,0x00,0x00,/*"5",6*/
  63. 0x00,0x00,0x07,0xF0,0x08,0x88,0x11,0x04,0x11,0x04,0x18,0x88,0x00,0x70,0x00,0x00,/*"6",7*/
  64. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",8*/
  65. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",9*/
  66. };
  67. void delay(unsigned int z)//延时子函数
  68. {
  69.    unsigned char x;
  70.    for(;z>0;z--)
  71.    for(x=110;x>0;x--);
  72. }
  73. void writedata(unsigned char dat1,unsigned char dat2)         //595显示子函数
  74. {
  75.         unsigned char i;
  76.         //CY存储移位之后的数据  CY进位标志位,单片机内部的寄存器   移位之后的数据就存在CY里面
  77.         for(i=0;i<8;i++)//循环八次
  78.         {
  79.                 dat1=dat1<<1;//数据左移11110001
  80.                 ds=CY;//数据发送
  81.                 shcp=1;//上升沿发生移位 上升沿时数据寄存器的数据锁存。
  82.                 shcp=0;
  83.         }
  84.         for(i=0;i<8;i++)//循环八次
  85.         {
  86.                 dat2=dat2<<1;//数据左移
  87.                 ds=CY;//数据发送
  88.                 shcp=1;//上升沿发生移位 上升沿时数据寄存器的数据锁存 。
  89.                 shcp=0;
  90.         }
  91.         stcp=0;
  92.         stcp=1;//上升沿将数据送到输出锁存器
  93.         stcp=0;
  94. }
  95. void main()         //主函数
  96. {
  97.         char i,aa;
  98.         TMOD=0x01;//定时器0  模式1  16位定时模式
  99.         TH0=(65536-10000)/256;//定时10.000ms
  100.         TL0=(65536-10000)%256;
  101.         ET0=1;//使能定时器0
  102.         EA=1;//开启总中断
  103.         TR0=1;//开始计数
  104.         zong=(zi1+1)*32;
  105.         while(1)         //无限循环
  106.         {
  107.                 if(s1==0)//检测按键
  108.                 {
  109.                         delay(30);//延时消除按键抖动
  110.                         if(s1==0)
  111.                         {
  112.                                 ss=0;
  113.                                 TR0=~TR0;//按下暂停  暂按继续
  114.                                 while(s1==0);//等待按键松手
  115.                         }
  116.                 }
  117.                 if(s2==0)//检测按键
  118.                 {
  119.                         delay(30);//延时消除按键抖动
  120.                         if(s2==0)
  121.                         {
  122.                                 fx=~fx;//方向取反
  123.                                 TR0=1;
  124.                                 ss=0;
  125.                                 aa=0;
  126.                                 if(fx==0)net=0;//正向移动
  127.                                 if(fx==1)net=zong;//反向移动
  128.                                 while(s2==0);//等待按键松手
  129.                         }
  130.                 }
  131.                 if(s3==0){
  132.                         delay(30);
  133.                         TR0=0;
  134.                         net=32;
  135.                         ss=1;
  136.                         while(!s3);
  137.                 }
  138.                 if(s4==0){
  139.                         xsflag++;
  140.                         if(xsflag>=3)
  141.                                 xsflag=0;
  142.                         net=32;
  143.                         while(!s4);
  144.                         if(xsflag==0)
  145.                         zong=(zi1+1)*32;
  146.                         if(xsflag==1)
  147.                         zong=(zi2+1)*32;
  148.                         if(xsflag==2)
  149.                         zong=(zi3+1)*32;
  150.                 }
  151.                 if(s5==0){
  152.                         ss=0;
  153.                         sd=sd-2;
  154.                         if(sd<=4)
  155.                         sd=4;
  156.                         while(!s5);
  157.                 }
  158.                 if(s6==0){
  159.                         ss=0;
  160.                         sd=sd+2;
  161.                         if(sd>=20)
  162.                         sd=20;
  163.                         while(!s6);
  164.                 }
  165.                  if(ss==0){
  166.                                 for(i=0;i<16;i++)//循环移位
  167.                                 {
  168.                                         //两片138组成的4-16线译码器
  169.                                         P2=i;//列数据驱动,138的驱动端口
  170.                                         if(xsflag==0){
  171.                                         writedata(tab1[net+aa],tab1[net+aa+1]);//写入需要显示的数据
  172.                                         }
  173.                                         if(xsflag==1){
  174.                                         writedata(tab2[net+aa],tab2[net+aa+1]);//
  175.                                         }
  176.                                         if(xsflag==2){
  177.                                         writedata(tab3[net+aa],tab3[net+aa+1]);//
  178.                                         }
  179.                                         delay(3);//延时
  180.                                         writedata(0,0);//清屏
  181.                                         aa+=2;//数据加 实现扫描
  182.                                         if(aa>30)aa=0;//循环16次 清零
  183.                                 }
  184.                         }else{
  185.                                 count++;
  186.                                 if(count >=50){
  187.                                         count=0;
  188.                                         net=net+32;
  189.                                         if(net>zong){
  190.                                                 net=32;
  191.                                         }
  192.                                 }
  193.                                 if(count>25){
  194.                                          for(i=0;i<16;i++)//循环移位
  195.                                         {
  196.                                                 //两片138组成的4-16线译码器
  197.                                                 P2=i;//列数据驱动,138的驱动端口
  198.                                                 if(xsflag==0){
  199.                                                 writedata(tab1[net+aa],tab1[net+aa+1]);//写入需要显示的数据
  200.                                                 }
  201.                                                 if(xsflag==1){
  202.                                                 writedata(tab2[net+aa],tab2[net+aa+1]);//
  203.                                                 }
  204.                                                 if(xsflag==2){
  205.                                                 writedata(tab3[net+aa],tab3[net+aa+1]);//
  206.                                                 }
  207.                                                 delay(3);//延时
  208.                                                 writedata(0,0);//清屏
  209.                                                 aa+=2;//数据加 实现扫描
  210.                                                 if(aa>30)aa=0;//循环16次 清零
  211.                                         }
  212.                                 }else{
  213.                                    writedata(0,0);//清屏
  214.                                    delay(50);
  215.                                 }
  216.                         }
  217.         }
  218. }
  219. void timer0() interrupt 1
  220. {
  221.         TH0=(65536-10000)/256;//10.000ms   进入一次中断
  222.         TL0=(65536-10000)%256;
  223.         alt++;
  224.         if(alt>=sd)//到100.000ms时间加以实现移动 用于控制移动速度
  225.         {
  226.                 alt=0;
  227.                 if(fx==0)//正向移动
  228.                 {
  229.                         net=net+2;        //每次送两个编码数据
  230.                         if(net>zong)//达到总字符
  231.                         net=0;//数据清零
  232.                 }
  233.                 else//否则反向移动
  234.                 {
  235.                         net=net-2;//每次送两个编码数据
  236.                         if(net<2)//数据完毕
  237.                         net=zong;//回到总字符
  238.                 }
  239.         }
  240. }
16X16点阵.zip (29.75 KB, 下载次数: 140)
参与人数 1黑币 +30 收起 理由
1963781320 + 30 很给力!谢谢,加油
收藏收藏6 分享淘帖 顶 踩
ID:574708 发表于 2020-12-6 14:44 | 只看该作者
你这个字模怎么取?
ID:1086402 发表于 2023-6-28 20:20 | 只看该作者
你这个字模怎么取
