查看: 4130|回复: 2
STM32F407读写SPI接口的flash W25Q128存储芯片驱动程序
这是我给学生讲解SPI接口时,写的STM32F407 读写SPI接口的flash W25Q128的例程
使用了固件库,附件中用windows画图工具画了几幅示意图帮助理解,图画得比较丑,希望能帮助到其他人
  1. #include "stm32f4xx.h"
  2. #include "spi.h"
  3. void spi1_init(void)
  4. {
  5.     GPIO_InitTypeDef  GPIO_InitStruct;
  6.     SPI_InitTypeDef SPI_InitStruct;
  7.
  8.     //开启SPI1 和 GPIOB的时钟
  9.     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
  10.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
  11.
  12.
  13.     //设置引脚 PB3--SPI1_SCK PB4--SPI1_MISO PB5--SPI1_MOSI
  14.     //模式、推挽、是否上拉等等
  15.
  16.     GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;//复用模式
  17.     GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;//推挽输出
  18.     GPIO_InitStruct.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 |GPIO_Pin_5;    //3 4 5号引脚
  19.     GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP;//内部上拉电阻
  20.     GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;//快速
  21.     GPIO_Init(GPIOB, &GPIO_InitStruct);
  22.
  23.     //复用为SPI1
  24.     GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_SPI1);
  25.     GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_SPI1);
  26.     GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_SPI1);
  27.
  28.     //PB14---作为 W25Q128的片选
  29.     GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT;//输出模式
  30.     //GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;//推挽输出
  31.     GPIO_InitStruct.GPIO_Pin = GPIO_Pin_14;    //14号引脚
  32.     //GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP;//内部上拉电阻
  33.     //GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;//快速
  34.     GPIO_Init(GPIOB, &GPIO_InitStruct);
  35.
  36.     //默认先不选中W25Q128
  37.     CS = 1;
  38.     //关于主从模式 高低位那个先发 8或16bits 时钟的频率 极性和相位
  39.     SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128;
  40.     //W25Q128 MODE 3
  41.     SPI_InitStruct.SPI_CPHA = SPI_CPHA_2Edge;//从机mode 3的需求
  42.     SPI_InitStruct.SPI_CPOL = SPI_CPOL_High;//从机mode 3的需求
  43.     SPI_InitStruct.SPI_CRCPolynomial = 7;//校验和多项式有几项
  44.     SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b;//从机的需求
  45.     SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex;//两线全双工
  46.     SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;//从机的需要
  47.     SPI_InitStruct.SPI_Mode = SPI_Mode_Master;
  48.     SPI_InitStruct.SPI_NSS = SPI_NSS_Soft;//软件管理片选引脚
  49.     SPI_Init(SPI1, &SPI_InitStruct);
  50.     //使能SPI1
  51.     SPI_Cmd(SPI1, ENABLE);
  52.
  53. }
  54. unsigned char spi1_write_read_byte(unsigned char data)
  55. {
  56.     //等上一次发送完成
  57.     while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) != SET);
  58.
  59.     SPI_I2S_SendData(SPI1, data);
  60.
  61.     //等接收缓冲非空
  62.     while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) != SET);
  63.
  64.     return SPI_I2S_ReceiveData(SPI1);
  65. }
  1. void spi_init(void)
  2. {
  3.     GPIO_InitTypeDef GPIO_InitStruct;
  4.     SPI_InitTypeDef SPI_InitStruct;
  5.
  6.     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
  7.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
  8.
  10.     GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
  11.     GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
  12.     GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_14;
  13.     GPIO_InitStruct.GPIO_PuPd  = GPIO_PuPd_UP;
  14.
  15.     GPIO_Init(GPIOB, &GPIO_InitStruct);
  16.     GPIO_SetBits(GPIOB, GPIO_Pin_14);
  17.
  18.     // SCK MISO MOSI
  19.     GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_AF;
  20.     GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
  21.     GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
  22.     GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_3 | GPIO_Pin_4 |GPIO_Pin_5;
  23.     GPIO_InitStruct.GPIO_PuPd  = GPIO_PuPd_UP;
  24.
  25.     GPIO_Init(GPIOB, &GPIO_InitStruct);
  26.
  27.     GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_SPI1);
  28.     GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_SPI1);
  29.     GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_SPI1);
  30.
  31.     SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128;
  32.     SPI_InitStruct.SPI_CPHA = SPI_CPHA_2Edge;
  33.     SPI_InitStruct.SPI_CPOL = SPI_CPOL_High;
  34.     SPI_InitStruct.SPI_CRCPolynomial = 7;
  35.     SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b;
  36.     SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  37.     SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;
  38.     SPI_InitStruct.SPI_Mode = SPI_Mode_Master;
  39.     SPI_InitStruct.SPI_NSS = SPI_NSS_Soft;
  40.     SPI_Init(SPI1, &SPI_InitStruct);
  41.     //ê1ÄüSPI
  42.     SPI_Cmd(SPI1, ENABLE);
  43.
  44.     spi_write_read_byte(0xff);
  45. }
  46. u8 spi_write_read_byte( u8 data )
  47. {
  48.     while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) != SET);
  49.     SPI_I2S_SendData(SPI1, data);
  50.
  51.     while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) != SET);
  52.     return SPI_I2S_ReceiveData(SPI1);
  53. }
全部资料51hei下载地址:
09 SPI.rar (1.4 MB, 下载次数: 81)
收藏收藏2 分享淘帖 顶顶 踩踩
ID:765366 发表于 2020-5-31 00:02 | 只看该作者
首次发帖等待审核
ID:124010 发表于 2021-4-14 14:50 | 只看该作者
你好,请问我读取id的时候,读到的全部是0xFF可能是啥原因
