查看: 2502|回复: 2
请大师指教,急急急
ID:50636 发表于 2013-5-30 09:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  ORG   0000H
  SJMP  DISPLAY
   ORG   0003H
  LJMP  BUTTON
ORG   000BH
   LJMP  DINGSHI
RS    EQU    P3.0
RW    EQU    P3.1
   E     EQU    P3.4
ORG   0030H
      DISPLAY:      SETB  EA
                     SETB  EX0
            SETB  IT0
            MOV   TMOD,   #01H
            MOV   TL0,    #0FFH
            MOV   TH0,    #0FFH
            SETB  ET0
            CLR   P0.5
            CLR   P0.6
            CLR   P0.7
            SETB  TR0
            MOV   DPTR,    #TAB
            MOV   R0,      #00H
            MOV   R1,      #16
            MOV   R3,      #00H
            MOV   R4,      #00H
      LP9:      LCALL CHUSHI
      LP2:     ACALL BUSY
                        MOV   A,       #00H
            MOVC  A,       @A+DPTR
            MOV   P1,      A
            ACALL DATAS
            INC   DPTR
            DJNZ  R1,      LP2
      LP3:      CJNE  R3,      #00H,     LP4
                     CJNE  R4,      #00H,     LP4
            SJMP  LP3
      LP4:           MOV   R7,      #00H
            MOV   R5,      #09H
            ACALL BUSY
            MOV   P1,      #0C0H
            ACALL ENABLE
            MOV   DPTR,    #MMTAB
            ACALL BUSY
       LP5:       MOV   A,       #00H
            MOVC  A,       @A+DPTR
            MOV   P1,      A
            INC   DPTR
            ACALL DATAS
            ACALL BUSY
            DJNZ  R5,      LP5
            MOV   DPTR,    #STAB
            MOV   A,       R2
            MOV   P1,      A
            ACALL DATAS
            ACALL BUSY
            MOV   A,       R3
            MOVC  A,       @A+DPTR
            MOV   P1,      A
            ACALL DATAS
            ACALL BUSY
            MOV   A,       R4
            MOVC  A,       @A+DPTR
            MOV   P1,      A
            ACALL DATAS
      LP8:        CJNE   R7,     #00H,    LP7
            LJMP  LP8
      LP7:     SJMP  LP4
      CHUSHI:        ACALL BUSY
            MOV   P1,      #00000001B
            ACALL ENABLE
            ACALL BUSY
            MOV   P1,      #00111000B
            ACALL ENABLE
            ACALL BUSY
            MOV   P1,      #00001111B
            ACALL ENABLE
            ACALL BUSY
            MOV   P1,      #00000110B
            ACALL ENABLE
            ACALL BUSY
            MOV   P1,      #80H
            ACALL ENABLE
            RET
      ENABLE:        SETB  E
            CLR   RS
            CLR   RW
            CLR   E
            RET
      DATAS:      SETB  E
            SETB  RS
            CLR   RW
            CLR   E
            RET
      BUSY:          CLR   E
            MOV   P1,     #0FFH
            CLR   RS
            SETB  RW
            SETB  E
            JB    P1.7,   BUSY
            RET
            ORG   2000H
         DINGSHI:       CPL   P0.7
            JNB   P0.7,   Z1
            MOV   A,      #0FFH
            SUBB  A,      R0
            MOV   TH0,    A
            SETB  TR0
            RETI
      Z1:            MOV   TH0,    R0
            SETB  TR0
            RETI
      BUTTON:        PUSH  ACC
            CLR   EX0
            CLR   EA
            INC   R7
            MOV   A,       #0FFH
            MOV   P2,      A
            MOV   A,       P2
            JNB   ACC.0,   AA0
            JNB   ACC.1,   KK0
            JNB   ACC.2,   ZZ0
            JNB   ACC.3,   FF0
            JNB   ACC.4,   WW0
            AJMP  QQ
      AA0:           CJNE  R0,      #0FFH,     AA1
            AJMP  QQ
      AA1:           MOV   A,       R0
            ADD   A,       #5
            MOV   R0,      A
            AJMP  QQ
      KK0:           CJNE  R0,      #00,       MM
            AJMP  QQ
      MM:            MOV   A,       R0
            SUBB  A,       #5
            MOV   R0,      A
            AJMP  QQ
      ZZ0:           CJNE   R0,     #01,    ZZ1
                     AJMP   QQ
      ZZ1:           MOV    A,     R0
                     INC    A,      #10
            MOV    R0,      A
            AJMP   QQ
      FF0:           CJNE    R0,  #01,  FF1
                     AJMP    QQ
         FF1:           MOV    A,   R0
                     DEC    A,    #1
            MOV     R0,   A
      QQ:            MOV   A,       R0
            MOV   B,       #5
            DIV   AB
            MOV   B,       #10
            DIV   AB
            MOV   R3,      A
            MOV   R4,      B
            SETB  EX0
            LCALL DELAY
            LCALL DELAY
            LCALL DELAY
            LCALL DELAY
            SETB  EA
            POP   ACC
            RETI
      WW0:           CLR   P0.5
            CLR   P0.6
            LCALL DELAY
            LCALL DELAY
            LCALL DELAY
            SETB  EX0
            SETB  EA
            POP   ACC
            RETI
DELAY:         MOV   R5,     #0E0H
MM0:           MOV   R6,     #30H
MM1:           DJNZ  R6,     MM1
            DJNZ  R5,     MM0
            RET
TAB:           DB    53H, 45H, 54H, 20H
            DB    53H, 50H, 45H, 45H
            DB    44H, 20H, 50H, 4CH
            DB    45H, 41H, 53H, 45H
STAB:      DB    30H, 31H, 32H, 33H
            DB    34H, 35H, 36H, 37H
            DB    38H, 39H, 41H, 42H
            DB    43H, 44H, 45H, 46H
      MMTAB:         DB    43H, 4FH, 52H, 52H
            DB    45H, 4EH, 54H, 20H
            DB    3AH
            END
ID:1 发表于 2013-5-30 16:26 | 只看该作者
这段汇编程序是有什么问题?具体一点
ID:76287 发表于 2015-4-7 19:04 | 只看该作者
不懂,但是还是要顶,安抚楼主受伤心灵,每一个新手都是痛苦的开始,快乐的结局
