查看: 7585|回复: 4
基于51单片机的电机转速控制Proteus仿真程序
#include<reg52.h>
#include<stdio.h>
#define THC0 0xf9
#define TLC0 0x0f   //2ms
unsigned char  code Duan[]={0x3F, 0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};//共阴极数码管,0-9段码表
unsigned char  Data_Buffer[8]={0,0,0,0,0,0,0,0};             // 显示缓冲
uchar i=0;
sbit AddSpeed=P1^1;
sbit SubSpeed=P1^2;
sbit TurnForward=P1^3;
sbit TurnBackward=P1^4;
sbit Stop=P1^5;
sbit IN1=P3^0;
sbit IN2=P3^1;
sbit PWM_FC=P1^0;
int e ,e1 ,e2 ;
float uk ,uk1 ,duk ;//pid输出值
float Kp=15,Ki=12,Kd=1.6;
int out=0;
uint SpeedSet=380;
uint cnt=0;
uint Inpluse=0,num=0;//脉冲计数
uint PWMTime=100;//脉冲宽度
unsigned char  arry[];
void SendString(uint ch);
void PIDControl();
void SystemInit();
void delay(uchar x);
void PWMOUT();
void SetSpeed();
void SegRefre();
/**************主函数************/
    SystemInit();
        SetSpeed();     //按键设定速度
        SegRefre();     //数码管显示刷新
        PWMOUT();       //输出PWM
void PIDControl()        //pid偏差计算
    e=SpeedSet-num;
    duk=(Kp*(e-e1)+Ki*e+Kd*(e-2*e1+e2))/50;
    uk=uk1+duk;
    out=(int)uk;   //输出为占空比
    if(out>1000)
        out=1000;
    else if(out<0)
        out=0;
    uk1=uk;               //变量值移位
    e2=e1;
    e1=e;
    PWMTime=out;
void delay(uchar x)
    uint i,j;
    for(i=x;i>0;i--)
        for(j=50;j>0;j--);
void PWMOUT()
    if(cnt<PWMTime)
        PWM_FC=1;
        PWM_FC=0;
    if(cnt>1000) cnt=0;
void SystemInit()
    TMOD=0X21;
    TH0=THC0;
    TL0=TLC0;
    TH1=0xC0;
    TL1=0XC0;
    ET1=1;
    ET0=1;
    TR0=1;
    TR1=1;
    EX0=1;
    IT0=1;
    EA=1;
    e =0;
    e1=0;
    e2=0;
    IN1 = 1;
    IN2 = 0;
void SetSpeed()
    if(AddSpeed==0)
        delay(200);           //消抖处理
        if(AddSpeed==0)
            SpeedSet+=10;
            if(SpeedSet>1500)
                SpeedSet=1500;
    if(SubSpeed==0)
        delay(200);
        if(SubSpeed==0)
            SpeedSet-=10;
            if(SpeedSet<0) SpeedSet=0;
    if(TurnForward==0)
        delay(200);
        if(TurnForward==0)
           IN1 = 1;
           IN2 = 0;
           while(TurnForward==0);
    if(TurnBackward==0)
        delay(200);
        if(TurnBackward==0)
           IN1 = 0;
           IN2 = 1;
           while(TurnBackward==0);
    if(Stop==0)
        delay(200);
        if(Stop==0)
           IN1 = 1;
           IN2 = 1;
           while(Stop==0);
void SegRefre()       //显示刷新
     Data_Buffer[0]=SpeedSet/1000;        //分离设定值各位
     Data_Buffer[1]=SpeedSet%1000/100;
     Data_Buffer[2]=SpeedSet%100/10;
     Data_Buffer[3]=SpeedSet%10;
     Data_Buffer[4]=num/1000;
     Data_Buffer[5]=num%1000/100;
     Data_Buffer[6]=num%100/10;
     Data_Buffer[7]=num%10;
void int0() interrupt 0
    Inpluse++;          //采集外部脉冲
void t0() interrupt 1
    static unsigned char Bit=0;
    static unsigned int time=0;
    TH0=THC0;
    TL0=TLC0;
    Bit++;
    time++;  //转速测量周期
    if(Bit>8) Bit=0;
    P0=0xff;
    P2=Duan[Data_Buffer[Bit]];  //显示段码
    switch(Bit)                 //数码管位选
        case 0:P0=0X7F;break;
        case 1:P0=0XBF;break;
        case 2:P0=0XDF;break;
        case 3:P0=0XEF;break;
        case 4:P0=0XF7;break;
        case 5:P0=0XFB;break;
        case 6:P0=0XFD;break;
        case 7:P0=0XFE;break;
    if(time>100)
        time=0;
        num=Inpluse*5;
        Inpluse=0;
        PIDControl();
void timer_1()  interrupt 3
    cnt++;  //cnt越大占空比越高2.5Khz
全部资料51hei下载地址:
单片机直流电机.zip (1.81 MB, 下载次数: 178)
收藏收藏4 分享淘帖 顶顶1 踩踩
ID:825015 发表于 2020-9-30 21:42 | 只看该作者
哥哥,你可以帮我讲解一下吗?急求,我看不懂
ID:825015 发表于 2020-9-30 21:45 | 只看该作者
请求讲解
ID:220066 发表于 2022-3-10 09:25 | 只看该作者
东西挺好的 挺实用的
ID:1142899 发表于 2025-1-12 17:10 | 只看该作者
谢谢分享!东西很好
