查看: 10174|回复: 0
Proteus8.9 VSM Studio IAR编译器仿真AT89C51RD2系列022_lcdNokia3310_5510
ID:371233 发表于 2020-6-5 22:08 | 显示全部楼层 |阅读模式
一,打开文件(可以随文下载放置在文档中打开)。(如下图1所示)
图1
二,调整原理图大小,适合可视,另存工程文件。(如下图2,3,4所示)
图2
图3
图4
三,点击Source Code标签。(如下图5所示)
图5
四,编辑main.c 代码如Proteus8.9 VSM Studio IAR编译器仿真AT89C51RD2系列022_lcdNokia3310_5510 (如下图6所示)
图6
五,Main.c 代码:
/* Main.c file generated by New Project wizard
* Coder:      Ziegler Yin
* Created:   周日 5月 3 2020
* Processor: AT89C51RD2
* Compiler:  IAR for 8051 (C)
#include "Nokia.h"
char mt1[]=" Welcome to ";
char mt2[]="Kaillen Work ";
char mt3[]=" www*wark*top ";
char mt4[]="Nokia3310_5110";
char mt5[]=" Code Made ";
char mt6[]=" _-Ziegler Yin ";
int main(void) {
        LCD_init(); //初始化液晶
        LCD_clear();
        SCLK =1;
        while(1)  {
                 LCD_write_english_string(0, 0, mt1);
                 LCD_write_english_string(0, 1, mt2);
                 LCD_write_english_string(0, 2, mt3);
                 LCD_write_english_string(0, 3, mt4);
                 LCD_write_english_string(0, 4, mt5);
                 LCD_write_english_string(0, 5, mt6);
nokia_5110.h:
*Coder:       Ziegler Yin
* Compiler:  Keil for 8051
#ifndef __NOKIA_H_
#define __NOKIA_H_
#include <stdio.h>
#include <ioAT89C51.h>
#include <intrinsics.h>
#define u8 unsigned char
#define u16 unsigned int
#define SCLK            (P2_bit.P2_5)
#define SDIN            (P2_bit.P2_4)
#define LCD_DC       (P2_bit.P2_3)
#define LCD_CE        (P2_bit.P2_2)
#define LCD_RST      (P2_bit.P2_1)
#define                delay_time        25664
static u8 ft[][6] =
    { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },   // sp
    { 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00 },   // !
    { 0x00, 0x00, 0x07, 0x00, 0x07, 0x00 },   // "
    { 0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14 },   // #
    { 0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12 },   // $
    { 0x00, 0x62, 0x64, 0x08, 0x13, 0x23 },   // %
    { 0x00, 0x36, 0x49, 0x55, 0x22, 0x50 },   // &
    { 0x00, 0x00, 0x05, 0x03, 0x00, 0x00 },   // '
    { 0x00, 0x00, 0x1c, 0x22, 0x41, 0x00 },   // (
    { 0x00, 0x00, 0x41, 0x22, 0x1c, 0x00 },   // )
    { 0x00, 0x14, 0x08, 0x3E, 0x08, 0x14 },   // *
    { 0x00, 0x08, 0x08, 0x3E, 0x08, 0x08 },   // +
    { 0x00, 0x00, 0x00, 0xA0, 0x60, 0x00 },   // ,
    { 0x00, 0x08, 0x08, 0x08, 0x08, 0x08 },   // -
    { 0x00, 0x00, 0x60, 0x60, 0x00, 0x00 },   // .
    { 0x00, 0x20, 0x10, 0x08, 0x04, 0x02 },   // /
    { 0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E },   // 0
    { 0x00, 0x00, 0x42, 0x7F, 0x40, 0x00 },   // 1
    { 0x00, 0x42, 0x61, 0x51, 0x49, 0x46 },   // 2
    { 0x00, 0x21, 0x41, 0x45, 0x4B, 0x31 },   // 3
    { 0x00, 0x18, 0x14, 0x12, 0x7F, 0x10 },   // 4
    { 0x00, 0x27, 0x45, 0x45, 0x45, 0x39 },   // 5
    { 0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30 },   // 6
    { 0x00, 0x01, 0x71, 0x09, 0x05, 0x03 },   // 7
    { 0x00, 0x36, 0x49, 0x49, 0x49, 0x36 },   // 8
    { 0x00, 0x06, 0x49, 0x49, 0x29, 0x1E },   // 9
    { 0x00, 0x00, 0x36, 0x36, 0x00, 0x00 },   // :
    { 0x00, 0x00, 0x56, 0x36, 0x00, 0x00 },   // ;
    { 0x00, 0x08, 0x14, 0x22, 0x41, 0x00 },   // <
    { 0x00, 0x14, 0x14, 0x14, 0x14, 0x14 },   // =
    { 0x00, 0x00, 0x41, 0x22, 0x14, 0x08 },   // >
    { 0x00, 0x02, 0x01, 0x51, 0x09, 0x06 },   // ?
    { 0x00, 0x32, 0x49, 0x59, 0x51, 0x3E },   // @
    { 0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C },   // A
    { 0x00, 0x7F, 0x49, 0x49, 0x49, 0x36 },   // B
    { 0x00, 0x3E, 0x41, 0x41, 0x41, 0x22 },   // C
    { 0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C },   // D
    { 0x00, 0x7F, 0x49, 0x49, 0x49, 0x41 },   // E
    { 0x00, 0x7F, 0x09, 0x09, 0x09, 0x01 },   // F
    { 0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A },   // G
    { 0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F },   // H
    { 0x00, 0x00, 0x41, 0x7F, 0x41, 0x00 },   // I
    { 0x00, 0x20, 0x40, 0x41, 0x3F, 0x01 },   // J
    { 0x00, 0x7F, 0x08, 0x14, 0x22, 0x41 },   // K
    { 0x00, 0x7F, 0x40, 0x40, 0x40, 0x40 },   // L
    { 0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F },   // M
    { 0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F },   // N
    { 0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E },   // O
    { 0x00, 0x7F, 0x09, 0x09, 0x09, 0x06 },   // P
    { 0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E },   // Q
    { 0x00, 0x7F, 0x09, 0x19, 0x29, 0x46 },   // R
    { 0x00, 0x46, 0x49, 0x49, 0x49, 0x31 },   // S
    { 0x00, 0x01, 0x01, 0x7F, 0x01, 0x01 },   // T
    { 0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F },   // U
    { 0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F },   // V
    { 0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F },   // W
    { 0x00, 0x63, 0x14, 0x08, 0x14, 0x63 },   // X
    { 0x00, 0x07, 0x08, 0x70, 0x08, 0x07 },   // Y
    { 0x00, 0x61, 0x51, 0x49, 0x45, 0x43 },   // Z
    { 0x00, 0x00, 0x7F, 0x41, 0x41, 0x00 },   // [
    { 0x00, 0x55, 0x2A, 0x55, 0x2A, 0x55 },   // 55
    { 0x00, 0x00, 0x41, 0x41, 0x7F, 0x00 },   // ]
    { 0x00, 0x04, 0x02, 0x01, 0x02, 0x04 },   // ^
    { 0x00, 0x40, 0x40, 0x40, 0x40, 0x40 },   // _
    { 0x00, 0x00, 0x01, 0x02, 0x04, 0x00 },   // '
    { 0x00, 0x20, 0x54, 0x54, 0x54, 0x78 },   // a
    { 0x00, 0x7F, 0x48, 0x44, 0x44, 0x38 },   // b
    { 0x00, 0x38, 0x44, 0x44, 0x44, 0x20 },   // c
    { 0x00, 0x38, 0x44, 0x44, 0x48, 0x7F },   // d
    { 0x00, 0x38, 0x54, 0x54, 0x54, 0x18 },   // e
    { 0x00, 0x08, 0x7E, 0x09, 0x01, 0x02 },   // f
    { 0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C },   // g
    { 0x00, 0x7F, 0x08, 0x04, 0x04, 0x78 },   // h
    { 0x00, 0x00, 0x44, 0x7D, 0x40, 0x00 },   // i
    { 0x00, 0x40, 0x80, 0x84, 0x7D, 0x00 },   // j
    { 0x00, 0x7F, 0x10, 0x28, 0x44, 0x00 },   // k
    { 0x00, 0x00, 0x41, 0x7F, 0x40, 0x00 },   // l
    { 0x00, 0x7C, 0x04, 0x18, 0x04, 0x78 },   // m
    { 0x00, 0x7C, 0x08, 0x04, 0x04, 0x78 },   // n
    { 0x00, 0x38, 0x44, 0x44, 0x44, 0x38 },   // o
    { 0x00, 0xFC, 0x24, 0x24, 0x24, 0x18 },   // p
    { 0x00, 0x18, 0x24, 0x24, 0x18, 0xFC },   // q
    { 0x00, 0x7C, 0x08, 0x04, 0x04, 0x08 },   // r
    { 0x00, 0x48, 0x54, 0x54, 0x54, 0x20 },   // s
    { 0x00, 0x04, 0x3F, 0x44, 0x40, 0x20 },   // t
    { 0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C },   // u
    { 0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C },   // v
    { 0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C },   // w
    { 0x00, 0x44, 0x28, 0x10, 0x28, 0x44 },   // x
    { 0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C },   // y
    { 0x00, 0x44, 0x64, 0x54, 0x4C, 0x44 },   // z
    { 0x14, 0x14, 0x14, 0x14, 0x14, 0x14 }    // horiz lines
static u8 write_chinese[][24]={
//测
        {0x89,0xF2,0x00,0xFF,0x01,0xF9,0xFF,0x00,0xFC,0x00,0xFF,0x00,0x00,0x07,0x04,0x04,0x02,0x01,0x02,0x04,0x01,0x04,0x07,0x00},
//试
        {0x11,0xF6,0x00,0x04,0x24,0xE4,0x24,0x24,0xFF,0x05,0x06,0x00,0x00,0x07,0x02,0x01,0x02,0x03,0x01,0x01,0x01,0x02,0x07,0x00},
//程
        {0x8A,0x6A,0xFF,0x49,0x20,0xAF,0xA9,0xE9,0xA9,0xAF,0x20,0x00,0x01,0x00,0x07,0x00,0x04,0x04,0x04,0x07,0x04,0x04,0x04,0x00},
//序
        {0x00,0xFE,0x42,0x4A,0x4A,0x5B,0xEA,0x5A,0x4A,0xC2,0x42,0x00,0x06,0x01,0x00,0x00,0x04,0x04,0x07,0x00,0x00,0x00,0x00,0x00},
void delay_1us(void);
void delay_1ms(void);
void delay_nms(u16 n);
void LCD_init(void);
void LCD_clear(void);
void LCD_set_XY(u8 X, u8 Y);
void LCD_write_char(u8 c);
void LCD_write_english_string(u8 X, u8 Y, char *st);                //u8 X, u8 Y, char *s
void LCD_write_chinese_string(u8 X, u8 Y, u8 ch_with,u8 num, u8 line,u8 row);
void LCD_draw_bmp_pixel(u8 X, u8 Y, u8 *map, u8 Pix_x, u8 Pix_y);
void LCD_write_byte(u8 dat, u8 command);
#endif
六,点击构建工程按钮,编译工程。(如下图7所示)
图7
七,点击窗口左下方仿真按钮,可见lcdNokia3310_5510屏上信息显示在屏。 (如下图8,9,10所示)
图8
图9
图10
附件Proteus8.9 VSM Studio IAR编译器仿真AT89C51RD2系列022_lcdNokia3310_5510在已安装Proteus8.9的计算机文件夹中打开即可
需要进一步了解,请加入QQ群:976235464
IAR_AT89C51RD2_022_Nokia5110_02pt.rar
129.71 KB, 下载次数: 14, 下载积分: 黑币 -5
