查看: 2117|回复: 0
单片机汇编语言红绿灯模拟 数码管显示不全怎么解决?
这是个红绿灯模拟里面的中断程序。我把它的主程序设为空程序了。没了绿色字体的部分,中断程序作为主程序运行时正常,但作为中断总是数码管显示残缺。本来四个数码管显示器,有三个显示就不错了。是不是因为没有什么中断现场保护??不懂
DAT  SEGMENT;
TABLE DB  00H,67H, 7FH, 07H, 7DH, 6DH, 66H, 4FH, 5BH,06H,3FH;9876543210
DAT  ENDS
STACK SEGMENT  'STACK'
  STA     DB  1000 DUP(?)
       PP     EQU LENGTH STA
STACK ENDS
CODE  SEGMENT ;PUBLIC 'CODE'
      ASSUME CS:CODE, DS:DAT ,SS:STACK
START:
       MOV AX,DAT
       MOV DS,AX
       MOV AX,STACK
           MOV SS,AX
       MOV AX, PP
       MOV  SP, AX       ;设置SP值
       PUSH  DS
       MOV AX,0
           MOV DS,AX
           MOV AX,CODE
     MOV CL,4
     SHL AX,CL
     ADD AX,OFFSET IRQ0
     MOV SI,80H
     MOV [SI],AX
     MOV AX,0
     MOV [SI+2],AX
   POP  DS
       MOV DX,8020H     ; 8259地址
  MOV AL,00010011B  ; 单片8259, 上升沿中断, 要写ICW4
  OUT DX,AL
  MOV DX,8022H
  MOV AL,20H    ; 中断号为20H
  OUT DX,AL
  MOV AL,01H    ; 工作在8086/88 方式
  OUT DX,AL
  IN AL,DX
  AND AL,0FEH
  OUT DX,AL
  MOV DX,8006H  ;8255控制
  MOV AL,80H    ;模式设置
  OUT DX,AL
MOV DX,8016H
OUT DX,AL
     MOV BL,0
LP:   STI   ;开中断
       NOP
       JMP  LP
IRQ0:
CLI
MOV AL,80H
MOV DX,8006H
OUT DX,AL
MOV DX,8016H
OUT DX,AL;两个芯片方式字设置
SSET1:LEADI,TABLE+7;读取3的地址
SSET2:MOV BP,DI;读取3的地址
SSET3:LEADI,TABLE+5;读取5的地址
SSET4:LEABX,TABLE+6;读取4的地址
SSET5:LEA SI,TABLE+10;读取0的地址
TTW:
   MOV AL,[BP]
MOV DX,8012H
   OUT DX,AL;高位初始化为3
MOV AL,[DI]
   MOV DX,8002H
   OUT DX,AL;高位初始化为5
L1W:MOV AL,[BX]
   MOV DX,8004H
   OUT DX,AL
   CMP AL,3FH;判断移位
   JE KK1W
B1W:MOV AL,[SI]
   MOV DX,8014H
   OUT DX,AL
   CMP AL,3FH;判断移位
   JE KK2W
B2W:INC BX;
   INC SI
MOV DX,60000
LOPW:NOP
    NOP
    NOP
    DEC DX
JNZ LOPW
MOV AL,[SI]
CMP AL,3FH
JE CHANGEW;交换循环判断1
    JMPTTW
KK1W:INC DI
MOV AL,[DI]
CMP AL,3FH
JE SS1W
PP1W:LEA BX,TABLE
JMP B1W
KK2W:INC BP
MOV AL,[BP]
CMP AL,3FH
JE SS2W;低位为0时调整低位起始值地址和高位地址
PP2W:LEA SI,TABLE
JMP B2W
SS1W:LEA DI,TABLE
JMP PP1W
SS2W:LEA BP,TABLE
    JMPPP2W;只有个位数值时高位不显示0
       MOVDX,8020H;
       MOVAL,20H
       OUTDX,AL
       STI
       IRET
CHANGEW:
CMP BP,0000H
JMP TTW
CODE   ENDS
       END START
