查看: 2066|回复: 3
完全不会单片机 东拼西凑的程序,无法显示数据,求指导
ID:769585 发表于 2020-6-10 19:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<math.h>
#include<absacc.h>
#include<intrins.h>
#include<reg51.h>
#define uint unsigned  int
#define ulong unsigned long
#define BUSY  0x80                  //常量定义
#define DATAPORT P0
#define ADCDELAY 5
sbit LCM_RS=P2^0;
sbit LCM_RW=P2^1;
sbit LCM_EN=P2^2;
sbit CS =P1^2;  //ADC0832 chip seclect
sbit CLK =P1^3;  //ADC0832 clock signal
sbit SDI =P1^1;  //ADC0832 k in
sbit SDO =P1^0;  //ADC0832 k out
uchar ad_data;                    //采样值存储
unsigned char press_bai=0;        //显示值百位
unsigned char press_shi=0;        //显示值十位
unsigned char press_ge=0;         //显示值个位
unsigned char press_dot=0;        //显示值十分位
uchar code str0[]={"Weight:   .   kg. "};
uchar HighRH = 0;
uchar HighRL = 0;
uchar LowRH = 0;
uchar LowRL = 0;
unsigned int a;
uchar rate;
sbit PWMOUT = P1^0;
uchar step, rec_data,flag;
void ADCInit(void);        //初始化TLC2543
uint StartConversion(uchar channl);        //开始转换,同时选择通道,同时返回上一次采样值
void delay(uint);
void lcd_wait(void);                      //检测忙子程序
void delay_LCM(uint);                     //延时子程序
void initLCM(void);                       //初始化子程序
void WriteCommandLCM(uchar WCLCM,uchar BusyC);           //写指令到LCM子程序
void WriteDataLCM(uchar WDLCM);                          //写数据到LCM子程序
void DisplayOneChar(uchar X,uchar Y,uchar DData);        //显示指定坐标的一个字符子函数
void DisplayListChar(uchar X,uchar Y,uchar code *DData); //显示指定坐标的一串字符子函数
void display(void);                                       //系统显示子函数
void ConfigPWM(uchar rate);
void alarm(void);
void data_pro(void);
void ConfigPWM(uchar dc);
void key_setPWM(void);
uchar duty_cycle(uchar ad_data);
void chuankou_init();
/**********main funcation************/
void main(void)
    delay(50);
    initLCM( );
                chuankou_init();
    WriteCommandLCM(0x01,1);           //清屏显示
    DisplayListChar(0,0,str0);
                delay(10);
                EA = 1;
                ConfigPWM(rate);
                        ad_data =StartConversion(0);                 //采样值存储单元初始化为0
                        alarm();
                        data_pro();
                        display();
                        a=duty_cycle(ad_data);
                        ConfigPWM(a);
                        key_setPWM();
                        if(a!=rate)
                        ConfigPWM(rate);
                                if(RI==1)//串口
                        RI=0;
                        rec_data=SBUF;
                        step=rec_data*2;
                        SBUF=rec_data;
void TIME_INIT()
TMOD|=0X02;
IT0=1;
IT1=1;
TR1=1;
EX1=1;
EX0=1;
ET0=1;
TR0=1;
EA=1;
SCON|=0X50;
TMOD|=0X20;
PCON|=0X80;
TH1=0XFA;
TL1=0XFA;
TR1=1;
SM0=0;
SM1=1;
REN=1;
EA=1;
ES=1;
/********延时K*1ms,12.000mhz**********/
void delay(uint x)
    uchar i;
         while(x--)
                 for(i = 0;i < 120;i++)
/**********写数据到ICM子函数************/
    if(BusyC)
                        lcd_wait();          //检测忙信号
                DATAPORT=WCLCM;
    LCM_RS=0;
    LCM_RW=0;
    LCM_EN=1;
         _nop_();
         _nop_();
         _nop_();
    LCM_EN=0;
/**********????LCM???************/
    lcd_wait( );
                DATAPORT=WDLCM;
    LCM_RS=1;        //选中数据寄存器
    LCM_RW=0;        //写模式
    LCM_EN=1;
    _nop_();
                 _nop_();
                 _nop_();
    LCM_EN=0;
/***********lcm内部等待程序*************/
void lcd_wait(void)
    DATAPORT=0xff;       //读LCD前若单片机输出低电平,而读出LCD为高电平,则冲突,Proteus仿真会有显示逻辑黄色
                LCM_EN=1;
    LCM_RS=0;
    LCM_RW=1;
    _nop_();
    _nop_();
                _nop_();
    while(DATAPORT&BUSY)
                        LCM_EN=0;
                        _nop_();
                        _nop_();
                        LCM_EN=1;
                        _nop_();
                        _nop_();
    LCM_EN=0;
/**********LCM??????***********/
void initLCM( )
         DATAPORT=0;
         delay(15);
         WriteCommandLCM(0x38,0);            //三次显示模式,不检测忙信号
                delay(5);
    delay(5);
    delay(5);
    WriteCommandLCM(0x38,1);            //8bit数据传送,两行显示,5*7字型,检测忙信号
    WriteCommandLCM(0x08,1);            //关闭显示,检测忙信号
    WriteCommandLCM(0x01,1);            //清屏,检测忙信号
    WriteCommandLCM(0x06,1);            //显示光标右移设置
    WriteCommandLCM(0x0c,1);            //显示屏打开,光标不显示,不闪烁,检测忙信号
    Y&=1;
    X&=15;
    if(Y)X|=0x40;                    //若Y为1(显示第二行)地址译码+0x40
    X|=0x80;                          //指令码为地址码+0x80
    WriteCommandLCM(X,0);
    WriteDataLCM(DData);
    uchar ListLength=0;
    Y&=0x01;
    X&=0x0f;
    while(X<16)
        DisplayOneChar(X,Y,DData[ListLength]);
        ListLength++;
        X++;
void display(void)
                DisplayOneChar(7,0,press_bai+0x30);
                DisplayOneChar(8,0,press_shi+0x30);
                DisplayOneChar(9,0,press_ge +0x30);
                DisplayOneChar(10,0,056);
    DisplayOneChar(11,0,press_dot+0x30);
void Delay_ADC(uchar ms)
        uchar i;
        for(; ms > 0; ms--)
                for(i = 5; i > 0; i--);
void ADCInit(void)        //初始化TLC2543
        CS = 1;
        CLK = 0;
        SDI = 0;
        SDO = 1;
uint StartConversion(uchar channl)        //开始转换,同时选择通道,同时返回上一次采样值
        uint dat = 0;
        uchar i;
        CS = 0;
        SDI = 0;
        for(i = 0; i < 12; i++)        //通道选择
                dat <<= 1;        //左移一位
                if(channl & 0x80)
                        SDI = 1;
                        SDI = 0;
                channl <<= 1;        //左移一位
                CLK = 1;
                if(SDO)
                        dat += 1;
                Delay_ADC(ADCDELAY);
                CLK = 0;
        CS = 1;
        return dat;
void data_pro(void)
      unsigned int temp;
      float  press;
                                int vary=ad_data;      //y=(115-15)/(243-13)*X+15kpa
                         //press=24+ad_data/2.67;
                         press=((10.0/28.1)*vary)+9.3;        //测试时补偿值为9.3
                         temp=(int)(press*10);                 //放大10倍,便于后面计算
                         press_bai=temp/1000;
                         press_shi=(temp%1000)/100;
                         press_ge=((temp%1000)%100)/10;
                         press_dot=((temp%1000)%100)%10;
        uchar rate;
        rate= 100*ad_data/256;
  return(rate);
/*??????dc,??20Hz????*/
        unsigned long tmp;          //临时变量
        uint high, low;
        tmp = 11059200/12/20;        //计算一个周期所需的计数值
        high = (tmp*dc)/100;         //计算高电平所需计数值
        low = tmp - high;             //计算低电平所需计数值
        high = 65536 - high + 12;    //计算高电平的定时器重载值并补偿中断延时
        low = 65536 - low + 12;          //计算低电平的定时器重载值并补偿中断延时
        HighRH = (uchar)(high >>8);      //高电平重载值拆分为高低字节
        HighRL = (uchar)high;
        LowRH = (uchar)(low >> 8);         //低电平重载值拆分为高低字节
        LowRL = (uchar)low;
        TMOD &= 0xF0;                //清0 T0的控制位
        TMOD |= 0x01;                 //配置T0的模式为 1
        TH0 = HighRH;                   //加载T0重载值
        TL0 = HighRL;
        ET0 = 1;                    //使能T0中断
        TR0 = 1;                  //启动T0
void init0() interrupt 0
        step++;
        if(step==200)
                step=0;
/*???0????*/
void init1() interrupt 2
        step--;
        if(step==0)
                step=0;
void chuankou() interrupt 4
        RI=0;
        rec_data=SBUF;
        step=rec_data*2;
        flag=1;
ID:584814 发表于 2020-6-11 16:30 | 只看该作者
完全不会单片机可以学,东拼西凑的程序可以调,无法显示数据可以改,但如果为论文最好上淘宝
ID:420836 发表于 2020-6-11 20:53 | 只看该作者
已经很好地将所有内容组合在一起。 如果仍然有问题,可以学习一些示例。
ID:436885 发表于 2020-6-12 01:21 | 只看该作者
都不知道你们想要实现什么目的?
