查看: 3338|回复: 4
51单片机三路超声波避障,麦克纳姆轮 程序有什么问题 求帮助
ID:776497 发表于 2020-6-11 18:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <REGX51.H>
uint PWM = 5;          //最大20,pwm调速
uchar time = 0;
uint Shi_Jian;
uint a,b,c,FJL,LJL,RJL;
void Delay (uint t)                //@11.0592MHz    100us
        unsigned char i;
        while (t)
                i = 43;
                while (--i);
                t--;
void Timer_Init()   //定时器    @11.0592MHZ   0.1ms
        TMOD = 0x11;
        TH0 = 0xFB;
        TL0 = 0xAF;
        TF0        = 0;
        ET0 = 1;          //允许中断
        EA = 1;           //开启总中断
        TR0 = 1;          /开启定时器
        TF1        = 0;
        TH1 = 0;
        TL1 = 0;
void Timer0_Rountine() interrupt 1   //T0  中断
        time++;
        TH0 = 0xFB;
        TL0 = 0xAF;
        if(time >= 20)
                time = 0;
int Front_Ju_Li ()               //测前方距离
        P2_0 = 1;                      //发送超声波
        Delay(1);                      //延时100us
        P2_0 = 0;                      //关闭超声波
        while (!P2_1);                 //未接收到超声波并等待
        TR1 = 1;                       //开启定时器
        while (P2_1);                  //接收到超声波并等待
        TR1 = 0;                       //关闭定时器1
        Shi_Jian = TH1*256 + TL1;
        TH1 = 0;
        TL1 = 0;
        FJL = (Shi_Jian*1.7)/100;      //单位  cm
        return FJL;
int Zuo_Ju_Li ()               //测左边距离
        P2_2 = 1;                      //发送超声波
        Delay(1);                      //延时100us
        P2_2 = 0;                      //关闭超声波
        while (!P2_3);                 //未接收到超声波并等待
        TR1 = 1;                       //开启定时器
        while (P2_3);                  //接收到超声波并等待
        TR1 = 0;                       //关闭定时器1
        TH1 = 0;
        TL1 = 0;
        LJL = (Shi_Jian*1.7)/100;      /单位  cm
        return LJL;
int You_Ju_Li ()               //测右边距离
        P2_4 = 1;                      //发送超声波
        Delay(1);                      //延时100us
        P2_4 = 0;                      //关闭超声波
        while (!P2_5);                 //未接收到超声波并等待
        TR1 = 1;                       //开启定时器
        while (P2_5);                  //接收到超声波并等待
        TR1 = 0;                       //关闭定时器1
        TH1 = 0;
        TL1 = 0;
        RJL = (Shi_Jian*1.7)/100;      //单位  cm
void Car_Stop ()   //停止
                P1_0=0,P1_1=0,P1_2=0,P1_3=0,P1_4=0,P1_5=0,P1_6=0,P1_7=0;
void Car_Run ()   //前进
        if (time <= PWM)
                P1_0=1,P1_1=0,P1_2=0,P1_3=1,P1_4=0,P1_5=1,P1_6=0,P1_7=1;
                Car_Stop ();
void Car_Zuozhuan ()   //左转
        if (time <= PWM)
                P1_0=0,P1_1=1,P1_2=0,P1_3=1,P1_4=1,P1_5=0,P1_6=0,P1_7=1;
                Car_Stop ();
void Car_Youzhuan ()   //右转
        if (time <= PWM)
                P1_0=1,P1_1=0,P1_2=1,P1_3=0,P1_4=0,P1_5=1,P1_6=1,P1_7=0;
                Car_Stop ();
void Car_Houtui ()   /后退
        if (time <= PWM)
                P1_0=0,P1_1=1,P1_2=1,P1_3=0,P1_4=1,P1_5=0,P1_6=1,P1_7=0;
                Car_Stop ();
        Timer_Init();
        while (1)
                do
                        Car_Run ();
                        a = Front_Ju_Li ();
                }while(a >= 20);
                Car_Stop ();
                b = Zuo_Ju_Li ();
                Delay(100);
                c = You_Ju_Li ();
                Delay(100);
                        if (b <= 15 && c <= 15)      //进入狭小空间,后退
                                Car_Houtui ();
                        if (b <= c)             //左边距离小于右边距离,右转
                                Car_Youzhuan ();
                        if (c <= b)             /右边距离小于左边距离,左转
                                Car_Zuozhuan ();
                                Car_Stop ();
帮忙看一下程序有什么问题
收藏收藏1 分享淘帖 顶 踩
ID:328014 发表于 2020-6-11 18:53 | 只看该作者
这个程序没有问题
ID:774446 发表于 2020-6-12 08:09 | 只看该作者
我觉得这程序写的很好思路也没有问题,棒棒的
ID:776497 发表于 2020-6-12 11:40 | 只看该作者
51hei团团 发表于 2020-6-11 18:53
这个程序没有问题
但是执行不了
小车不动
ID:573789 发表于 2020-6-17 14:55 | 只看该作者
很好 的教程
