查看: 2775|回复: 1
AutoChips 7801的BMP085气温气压测量
BMP085是一款基于I2C接口的数字式气温、气压传感器,具有体积少易于使用的特点。
BMP085MCU的连接关系为:
SCLK——PB7
SDIN——PB8
其余的两个引脚则接3.3V工作电源
BMP085与开发板连接图
定义GPIO输入及输出高低电平的语句为:
#define SCL_Set()        GPIO_SetPinLevel(GPIOB, GPIO_PIN7, GPIO_LEVEL_HIGH);  // PB7
#define SCL_Clr()        GPIO_SetPinLevel(GPIOB, GPIO_PIN7, GPIO_LEVEL_LOW);
#define SDA_Set()        GPIO_SetPinLevel(GPIOB, GPIO_PIN8, GPIO_LEVEL_HIGH);  // PB8
#define SDA_Clr()        GPIO_SetPinLevel(GPIOB, GPIO_PIN8, GPIO_LEVEL_LOW);
#define IIC_SDA_IN    GPIO_GetPinLevel(GPIOB, GPIO_PIN8)
#define IIC_INPUT_MODE_SET()   GPIO_SetDir(GPIOB, GPIO_PIN8, GPIO_IN);
#define IIC_OUTPUT_MODE_SET()  GPIO_SetDir(GPIOB, GPIO_PIN8, GPIO_OUT);
配置相关引脚为输出功能的函数为:
  1. void IIC_Init(void)
  2. {
  3. GPIO_SetDir(GPIOB, GPIO_PIN7, GPIO_OUT);
  4. GPIO_SetDir(GPIOB, GPIO_PIN8, GPIO_OUT);
  5. }
辅助BMP085读写的基本函数有:
  1. void IIC_Start(void)
  2. {
  3. IIC_OUTPUT_MODE_SET();
  4. SDA_Set();
  5. SCL_Set();
  6. udelay(5);
  7. SDA_Clr();
  8. udelay(5);
  9. SCL_Clr();
  10. }
  11. void IIC_Stop(void)
  12. {
  13. IIC_OUTPUT_MODE_SET();
  14. SDA_Clr();
  15. SCL_Clr();
  16. udelay(5);
  17. SCL_Set();
  18. udelay(5);
  19. SDA_Set();
  20. udelay(5);
  21. }
  22. void IIC_Ack(void)
  23. {
  24. SCL_Clr();
  25. IIC_OUTPUT_MODE_SET();
  26. SDA_Clr();
  27. udelay(2);
  28. SCL_Set();
  29. udelay(2);
  30. SCL_Clr();
  31. }
  32. void IIC_NAck(void)
  33. {
  34. SCL_Clr();
  35. IIC_OUTPUT_MODE_SET();
  36. SDA_Set();
  37. udelay(2);
  38. SCL_Set();
  39. udelay(2);
  40. SCL_Clr();
  41. }
BMP085的初始化函数为:
  1. void Init_BMP085()
  2. {
  3. ac1 = Multiple_read(0xAA);
  4. ac2 = Multiple_read(0xAC);
  5. ac3 = Multiple_read(0xAE);
  6. ac4 = Multiple_read(0xB0);
  7. ac5 = Multiple_read(0xB2);
  8. ac6 = Multiple_read(0xB4);
  9. b1 =  Multiple_read(0xB6);
  10. b2 =  Multiple_read(0xB8);
  11. mb =  Multiple_read(0xBA);
  12. mc =  Multiple_read(0xBC);
  13. md =  Multiple_read(0xBE);
  14. }
气温的读取函数为:
  1. long bmp085ReadTemp(void)
  2. {
  3. IIC_Start();
  4. IIC_Send_Byte(BMP085_SlaveAddress);
  5. while(IIC_Wait_Ack()){}
  6. IIC_Send_Byte(0xF4);
  7. while(IIC_Wait_Ack()){}
  8. IIC_Send_Byte(0x2E);
  9. while(IIC_Wait_Ack()){}
  10. IIC_Stop();
  11. mdelay(10);
  12. return (long) Multiple_read(0xF6);
  13. }
气压的读取函数为:
  1. long bmp085ReadPressure(void)
  2. {
  3. long pressure = 0;
  4. IIC_Start();
  5. IIC_Send_Byte(BMP085_SlaveAddress);
  6. while(IIC_Wait_Ack()){}
  7. IIC_Send_Byte(0xF4);
  8. while(IIC_Wait_Ack()){}
  9. IIC_Send_Byte(0x34);
  10. while(IIC_Wait_Ack()){}
  11. IIC_Stop();
  12. mdelay(10);
  13. pressure = Multiple_read(0xF6);
  14. pressure &= 0x0000FFFF;
  15. return pressure;
  16. }
实现图示输出效果的主程序为:
  1. int main(void)
  2. {
  3. InitDelay();
  4. InitDebug();
  5. OLED_Init();
  6. OLED_Clear();
  7. OLED_ShowString(0,0,"AC8710 TEST",16);
  8. OLED_ShowString(0,2,"OLED Display",16);
  9. OLED_ShowString(0,4,"jinglixixi",16);
  10. OLED_ShowString(0,6,"2020.6.6",16);
  11. IIC_Init(); //BMP085
  12. Init_BMP085();
  13. while(1)
  14. {
  15. bmp085Convert();
  16. printf("temperature: %d C\r\n", temperature/10);
  17. printf("pressure: %d KPa\r\n", pressure/100);
  18. ConvAltitude();
  19. mdelay(1000);
  20. }
  21. }
测量效果图
ID:776997 发表于 2020-6-17 22:36 | 只看该作者
感谢鼓励
