查看: 4191|回复: 2
16X16点阵扩展16X32点阵示例(程序+仿真)
  1. #include <reg51.h>
  3. #define uint unsigned int
  4. #define  SPEED   1 //移动速度,数字越小越快,数字越大越慢
  5. sbit DS=P2^0;           //接U2_74HC595的引脚14
  6. sbit ST=P2^2;           //接U2_74HC595的引脚12
  7. sbit SH=P2^1;           //接U2_74HC595的引脚11
  8. uchar code table1[]={        //点阵屏的上部(1屏和2屏)
  9. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  10. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  11. 0x04,0x24,0x24,0x24,0x7F,0xC4,0x44,0x04,0x04,0xFF,0x04,0x44,0x34,0x05,0x04,0x00,/*"我"的上半部,0*/
  12. 0x01,0x26,0x34,0x2C,0x24,0x24,0x37,0x4C,0x44,0x44,0x4C,0x74,0xC4,0x45,0x06,0x00,/*"爱"的上半部,1*/
  13. 0x00,0x01,0x06,0x1F,0xE0,0x02,0x04,0x18,0xF0,0x10,0x13,0x10,0x10,0x14,0x18,0x00,/*"你"的上半部,2*/
  14. 0x00,0x00,0x0F,0x08,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x08,0x0F,0x00,0x00,0x00,/*"中"的上半部,3*/
  15. 0x00,0x7F,0x40,0x48,0x49,0x49,0x49,0x4F,0x49,0x49,0x49,0x48,0x40,0x7F,0x00,0x00,/*"国"的上半部,4*/
  16. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  17. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  18. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  19. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  20. };
  21. uchar code table2[]={         //点阵屏的下部(3屏和4屏)
  22. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  23. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  24. 0x00,0x10,0x12,0x21,0xFE,0x40,0x82,0x02,0x04,0xC8,0x30,0x28,0x44,0x82,0x1F,0x00,/*"我"的下半部,0*/
  25. 0x00,0x82,0x84,0x89,0x91,0xE1,0xB2,0xAA,0xA4,0xA4,0xAA,0xB2,0x81,0x01,0x01,0x00,/*"爱"的下半部,1*/
  26. 0x80,0x00,0x00,0xFF,0x00,0x08,0x30,0xC0,0x02,0x01,0xFE,0x00,0x80,0x60,0x18,0x00,/*"你"的下半部,2*/
  27. 0x00,0x00,0xF0,0x20,0x20,0x20,0x20,0xFF,0x20,0x20,0x20,0x20,0xF0,0x00,0x00,0x00,/*"中"的下半部,3*/
  28. 0x00,0xFF,0x02,0x12,0x12,0x12,0x12,0xF2,0x12,0x52,0x32,0x12,0x02,0xFF,0x00,0x00,/*"国"的下半部,4*/
  29. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  30. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  31. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  32. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,        //空白屏
  33. };
  34. void senddata(uchar,uchar,uchar,uchar);
  35. void delay(uint);
  36. void main()
  37. {
  38.         uchar        i,j,k,m,n=0;
  39.         while(1)
  40.         {
  41.                  for(i=0;i<112;i++) //要显示的字数,值=字数*16+32, 最后的这个32是显示二个空白屏
  42.                 {
  43.                         for(j=0;j<SPEED;j++)   //移动速度
  44.                         {
  45.                                 for(k=0;k<16;k++) //显示列数(勿修改)
  46.                                 {
  47.                                         m=i+k;
  48.                                         P1=k;
  49.                                         senddata(table1[m+16],table2[m+16],table1[m],table2[m]); //传送第上部屏和下部屏
  50.                                         //delay(100);        //延时,去掉,会闪烁
  51.                                           senddata(0,0,0,0);        //消隐,全灭
  52.                                 }
  53.                         }
  54.                 }
  55.         }
  56.
  57. }
  58. /* 将每行数据送至74HC595
  59. * m为高8位,n为低8位
  60. * SH为移位时钟,ST为锁存时钟 */
  61. void senddata(uchar m,uchar n, uchar m1, uchar n1)
  62. {
  63.         uchar i;
  64.         ST=0;
  65.         for(i=0;i<32;i++)  //有多少行,就改多少
  66.         {
  67.                 SH=0;
  68.                 if(i<8) {                                         //1-8行
  69.                           DS=0X80&(m<<i);
  70.                 } else if(i>=8 && i<16) {         //9-16行
  71.                         DS=0X80&(n<<(i-8));
  72.                 } else if(i>=16 && i<24) {         //17-24行
  73.                         DS=0X80&(m1<<(i-16));
  74.                 } else if(i>=24 && i<32) {         //24-32行
  75.                         DS=0X80&(n1<<(i-24));
  76.                 }
  77.
  78.                 SH=1;
  79.         }
  80.         ST=1;
  81. }
  82. void delay(uint m)
  83. {
  84.         uint j;
  85.         for(j=m;j>0;j--);
  86. }
_16X16点阵扩展16X32.zip (633.65 KB, 下载次数: 85)
收藏收藏5 分享淘帖 顶 踩
ID:235055 发表于 2020-7-7 08:24 | 只看该作者
收藏了,谢谢楼主无私分享
ID:678046 发表于 2020-11-8 16:10 | 只看该作者
想问一下LED点阵的连接,怎么区分他的行线列线啊?
