查看: 1777|回复: 3
求助:若单片机收到字符‘a’,则打开所有发光二级管;若收到字符‘b’,则关闭所...
ID:781542 发表于 2020-6-16 23:52 | 显示全部楼层 |阅读模式
#include<reg52.h>
void Uartlnit();
unsigned char flag,i,a=0x00,b=0xff;
typedef unsigned int u16;   //?????????????????????
typedef unsigned char u8;
#define led P1    //??P1??????led,???????????led????P1??
void delayms(u16);
void delayms(uint);   //????????????????
void Uartlnit()
u8 i;
  led=0x00;   //??????? ???????з????????
  delayms(1000); //??????? ???1000ms
  led=0xff;     //??????? ??????з????????
  delayms(1000);
SM0=0; //??????? ?洢?????
SM1=1; //??????? ??????????????1
TMOD=0X20; //??????? ?趨?????1?8λ?????????
REN=1; //??????? ??????????????
TR1=1; //??????? ????????1
  TH1=0XFD;
TL1=0XFD; //??????? ?趨?????????????????9600bps
EA=1; //??????? ????ж????
ES=1; //??????? ?????ж????
Uartlnit();
    if(flag==1)
      ES=0;
   for(i=0;i<6;i++)
    SBUF=a;
    led=0x00;
    while(!TI);
    TI=0;
      flag=0;
      SBUF=a;
   led=a;
      while(!TI);
      TI=0;
      ES=1;
    else if(flag==1)
      ES=0;
   for(i=0;i<6;i++)
    SBUF=b;
    led=0xff;
    while(!TI);
    TI=0;
      flag=0;
      SBUF=b;
   led=b;
      while(!TI);
      TI=0;
      ES=1;
    led=0x00;
     led=0xff;
void ser() interrupt 4    //??????? ???崮???ж?
RI=0;
P1=SBUF;
a=SBUF;
b=SBUF;
flag=1;
void delayms(uint x)
uint i,j;
for(i=x;i>0;i--)   //??????? i=x???????x????
  for(j=114;j>0;j--);
这是我的,不知道哪里出问题了,能帮我看看嘛,谢谢。
ID:781542 发表于 2020-6-16 23:53 | 显示全部楼层
若单片机收到字符‘a’,则打开所有发光二级管;若收到字符‘b’,则关闭所有发光二级管;否则,所有发光二级管每隔1s闪烁一次。
ID:744327 发表于 2020-6-17 08:17 | 显示全部楼层
自定义与宏定义冲突了 #define uint unsigned int
ID:213173 发表于 2020-6-17 08:43 | 显示全部楼层
#include<reg52.h>
#define led P1
void Uart_Init()
        TMOD=0X20;
        TH1=0XFD;
        TL1=0XFD;
        TR1=1;
        REN=1;
        SM0=0;
        SM1=1;
        EA=1;
        ES=1;
        Uart_Init();
        while(1);
        u8 i;
        RI=0;
        i=SBUF;
        if(i=='a')
                led=0x00;
        if(i=='b')
                led=0xff;
