查看: 1667|回复: 0
简易数码管时钟
ID:777468 发表于 2020-6-18 21:39 | 显示全部楼层 |阅读模式
#include <REGX52.H>
typedef unsigned int u16;
typedef unsigned char u8;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
u8 shi=12,fen=59,miao=14;s=0;
u8 DisplayData[8];
u8 code smgduan[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void delay(u16 i)
        while(i--);
void datapros()
        DisplayData[0] = smgduan[shi/10];
        DisplayData[1] = smgduan[shi%10];
        DisplayData[2] = 0x40;
        DisplayData[3] = smgduan[fen/10];
        DisplayData[4] = smgduan[fen%10];
        DisplayData[5] = 0x40;
        DisplayData[6] = smgduan[miao/10];
        DisplayData[7] = smgduan[miao%10];
void DigDisplay()
        u8 i;
        for(i=0;i<8;i++)
                switch(i)
                        case(0):
                                LSA=0;LSB=0;LSC=0; break;
                        case(1):
                                LSA=1;LSB=0;LSC=0; break;
                        case(2):
                                LSA=0;LSB=1;LSC=0; break;
                        case(3):
                                LSA=1;LSB=1;LSC=0; break;
                        case(4):
                                LSA=0;LSB=0;LSC=1; break;
                        case(5):
                                LSA=1;LSB=0;LSC=1; break
                        case(6):
                                LSA=0;LSB=1;LSC=1; break;
                        case(7):
                                LSA=1;LSB=1;LSC=1; break;
                P0=DisplayData[7-i];
                delay(100);
                P0=0x00;
                datapros();
                DigDisplay();
                if(s<60)
                   s++;
                   delay(1000);
                 if(s>=60)
                           miao++;
                         s=0;
                         delay(1000);
                         if(miao>=60)
                           fen++;
                           miao=0;
                           delay(1000);
                           if(fen>=60)
                                    fen=0;
                                 shi++;
                                 delay(1000);
                                 if(shi>=12)
                                         shi=1;
