查看: 4381|回复: 3
常用的摩托罗拉Altium Designer库下载
如题
一些常用的ad库,里面包含着许多我们经常用的一些库 有需要的可以下载看一下
3 components      Motorola Amplifier Audio Amplifier                IPC-7351 Footprint Added.
145 components    Motorola Amplifier Operational Amplifier          IPC-7351 Footprint Added.
NE592D            Motorola Amplifier Video Amplifier                IPC-7351 Footprint Added.
19 components     Motorola Analog Comparator                        IPC-7351 Footprint Added.
MC1495D           Motorola Analog Multiplier Divider                IPC-7351 Footprint Added.
4 components      Motorola Analog Timer Circuit                     IPC-7351 Footprint Added.
MC13022DW         Motorola Audio TV Stereo Decoder                  IPC-7351 Footprint Added.
UAA1041D          Motorola Automotive Direction Indicator           IPC-7351 Footprint Added.
MC1488D           Motorola Communication Communication Interface    IPC-7351 Footprint Added.
5 components      Motorola Communication Receiver                   IPC-7351 Footprint Added.
6 components      Motorola Communication Telephone Circuit          IPC-7351 Footprint Added.
MC145026DW        Motorola Communication Transmitter                IPC-7351 Footprint Added.
MC10321DW         Motorola Converter Analog to Digital              IPC-7351 Footprint Added.
2 components      Motorola Converter Digital to Analog              IPC-7351 Footprint Added.
19 components     Motorola DSP 16-Bit                               IPC-7351 Footprint Added.
29 components     Motorola DSP 24-Bit                               IPC-7351 Footprint Added.
6 components      Motorola Discrete BJT                             IPC-7351 Footprint Added.
2 components      Motorola Discrete Diode                           IPC-7351 Footprint Added.
16 components     Motorola Discrete MOSFET                          IPC-7351 Footprint Added.
TDA1085CD         Motorola Interface AC Motor Controller            IPC-7351 Footprint Added.
MC33157DW         Motorola Interface Bridge Driver                  IPC-7351 Footprint Added.
5 components      Motorola Interface Display Driver                 IPC-7351 Footprint Added.
3 components      Motorola Interface Line Driver                    IPC-7351 Footprint Added.
4 components      Motorola Interface Line Receiver                  IPC-7351 Footprint Added.
12 components     Motorola Interface Line Transceiver               IPC-7351 Footprint Added.
7 components      Motorola Interface MOSFET Driver                  IPC-7351 Footprint Added.
4 components      Motorola Interface Peripheral Driver              IPC-7351 Footprint Added.
MC33030DW         Motorola Interface Servo Motor Controller         IPC-7351 Footprint Added.
5 components      Motorola Interface Terminator                     IPC-7351 Footprint Added.
MC33153D          Motorola Interface Transistor Driver              IPC-7351 Footprint Added.
8 components      Motorola Logic Arithmetic                         IPC-7351 Footprint Added.
10 components     Motorola Logic Buffer Line Driver                 IPC-7351 Footprint Added.
4 components      Motorola Logic Comparator                         IPC-7351 Footprint Added.
28 components     Motorola Logic Counter                            IPC-7351 Footprint Added.
12 components     Motorola Logic Decoder Demux                      IPC-7351 Footprint Added.
18 components     Motorola Logic Flip-Flop                          IPC-7351 Footprint Added.
32 components     Motorola Logic Gate                               IPC-7351 Footprint Added.
16 components     Motorola Logic Latch                              IPC-7351 Footprint Added.
55 components     Motorola Logic Multiplexer                        IPC-7351 Footprint Added.
4 components      Motorola Logic Parity Gen Check Detect            IPC-7351 Footprint Added.
22 components     Motorola Logic Register                           IPC-7351 Footprint Added.
6 components      Motorola Logic Switch                             IPC-7351 Footprint Added.
3 components      Motorola Logic Timer                              IPC-7351 Footprint Added.
4 components      Motorola Memory Serial PROM                       IPC-7351 Footprint Added.
238 components    Motorola Microcontroller 16-Bit                   IPC-7351 Footprint Added.
243 components    Motorola Microcontroller 32-Bit                   IPC-7351 Footprint Added.
659 components    Motorola Microcontroller 8-Bit                    IPC-7351 Footprint Added.
4 components      Motorola Microprocessor 16-Bit                    IPC-7351 Footprint Added.
MC68020FE         Motorola Microprocessor 32-Bit                    IPC-7351 Footprint Added.
8 components      Motorola PLD Programmable Array Data              IPC-7351 Footprint Added.
2 components      Motorola Peripheral Clock Generator               IPC-7351 Footprint Added.
MC68440FN         Motorola Peripheral DMA Controller                IPC-7351 Footprint Added.
MC10E197FN        Motorola Peripheral HD Data Sep Sync              IPC-7351 Footprint Added.
MC68230FN         Motorola Peripheral IO Port                       IPC-7351 Footprint Added.
MC68901FN         Motorola Peripheral Multifunction Controller      IPC-7351 Footprint Added.
10 components     Motorola Power Mgt DC-DC Converter                IPC-7351 Footprint Added.
2 components      Motorola Power Mgt SMPS Controller                IPC-7351 Footprint Added.
TCF6000D          Motorola Power Mgt Supervisory Circuit            IPC-7351 Footprint Added.
2 components      Motorola Power Mgt Switching Regulator            IPC-7351 Footprint Added.
3 components      Motorola Power Mgt Voltage Detector               IPC-7351 Footprint Added.
5 components      Motorola Power Mgt Voltage Reference              IPC-7351 Footprint Added.
23 components     Motorola Power Mgt Voltage Regulator              IPC-7351 Footprint Added.
2 components      Motorola RF Amplifier                             IPC-7351 Footprint Added.
16 components     Motorola RF and IF Frequency Synthesiser          IPC-7351 Footprint Added.
MC13023D          Motorola RF and IF Front End                      IPC-7351 Footprint Added.
MC13143D          Motorola RF and IF Mixer                          IPC-7351 Footprint Added.
3 components      Motorola RF and IF Modulator Demodulator          IPC-7351 Footprint Added.
4 components      Motorola RF and IF Radio Receiver Circuit         IPC-7351 Footprint Added.
2 components      Motorola RF and IF Transmitter                    IPC-7351 Footprint Added.
MC623DR2          Motorola Sensor Temperature Sensor                IPC-7351 Footprint Added.
2 components      Motorola Video Colour Decoder Circuit             IPC-7351 Footprint Added.
3 components      Motorola Video Signal Processor                   IPC-7351 Footprint Added.
MC12149D          Motorola Voltage Controlled Oscillator            IPC-7351 Footprint Added.
全部资料51hei下载地址:
Motorola_350806.zip (16.83 MB, 下载次数: 28)
ID:681605 发表于 2020-6-20 06:26 | 只看该作者
你竟然拿2006年的库来让大家下载??
ID:779913 发表于 2020-9-15 20:28 | 只看该作者
lovefeyer 发表于 2020-6-20 06:26
你竟然拿2006年的库来让大家下载??
啊,我不知道啊,师傅发的,为了凑积分就传上去了
ID:667692 发表于 2020-11-20 06:54 | 只看该作者
老掉牙的东西,基本无用!
