查看: 1702|回复: 1
求助 用arduino 读取 mpu6050数据 结果串口一片白 编译上传都没啥问题
ID:514512 发表于 2020-6-23 17:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <Wire.h>
long accelX,accelY,accelZ;
float gForceX,gForceY,gForceZ;
long gyroX,gyroY,gyroZ;
float rotX,rotY,rotZ;
void setupMPU(){
Wire.beginTransmission(0b1101000);
Wire.write(0x6B);
Wire.write(0b00000000);
Wire.endTransmission(true);
Wire.write(0x1B);
Wire.write(0x1C);
void  recordAccelRegisters() {
Wire.write(0x3B);
Wire.requestFrom(0b1101000,6);
while(Wire.available()<6);
accelX = Wire.read()<<8|Wire.read();
accelY = Wire.read()<<8|Wire.read();
accelZ = Wire.read()<<8|Wire.read();
processAccelData();
void  processAccelData(){
  gForceX = accelX / 16384.0;
  gForceY = accelY / 16384.0;
  gForceZ = accelZ / 16384.0;
void  recordGyroRegisters() {
  Wire.write(0x43);
  gyroX = Wire.read()<<8|Wire.read();
  gyroY = Wire.read()<<8|Wire.read();
  gyroZ = Wire.read()<<8|Wire.read();
  processGyroData();
void  processGyroData() {
  rotX = gyroX / 131.0;
  rotY = gyroY / 131.0;
  rotZ = gyroZ / 131.0;
void printData(){
  Serial.print("Gyro  (deg)");
  Serial.print(" X=");
  Serial.print("rotX");
  Serial.print(" Y=");
  Serial.print("rotY");
  Serial.print(" Z=");
  Serial.print("rotZ");
  Serial.print(" Accel (g)");
  Serial.print("gForceX");
  Serial.print("gForceY");
  Serial.println("gForceZ");
void setup() {
Serial.begin(9600);
Wire.begin();
setupMPU();
void loop() {
  recordAccelRegisters();
  recordGyroRegisters();
  printData();
  delay(100);
ID:514512 发表于 2020-6-23 17:17 | 只看该作者
是程序哪里不对吗
