查看: 1872|回复: 0
用PROTEUS仿真单片机串口通讯
设计要求:
实现与Proteus中的8051单片机进行串行通信。先回顾一下串行通信。在串行通信中有两个引脚分别称为TXRXTX引脚用于发送数据,而RX引脚用于接收数据。
8051微控制器具有这两个引脚,因此它支持串行通信,并且这些引脚位于AT89C52微控制器的10号和11号引脚上。
首先,将对此项目进行原理图设计(如下图),在端口1上连接8LED,并通过串行端口发送字符来打开或关闭这些LED。设计完原理图之后,我们将为8051微控制器设计编程代码,并测试结果。
#include <reg52.h>
#define Baud_rate 0xFD // BAUD RATE 9600
void SerialInitialize(void);
void SendByteSerially(unsigned char);
void cct_init(void);
sbit Appliance1 = P1^0;
sbit Appliance2 = P1^1;
sbit Appliance3 = P1^2;
sbit Appliance4 = P1^3;
sbit Appliance5 = P1^4;
sbit Appliance6 = P1^5;
sbit Appliance7 = P1^6;
sbit Appliance8 = P1^7;
cct_init();
SerialInitialize();
EA = 1;
ES = 1;
while(1) {;}
void cct_init(void) //initialize cct
P0 = 0x00; //not used
P1 = 0x00; //Used for Appliances
P2 = 0x00; //not used
P3 = 0x03; //used for serial
void SerialInitialize(void) // INITIALIZE SERIAL PORT
TMOD = 0x20;// Timer 1 IN MODE 2 -AUTO RELOAD TO GENERATE BAUD RATE
SCON = 0x50;// SERIAL MODE 1, 8-DATA BIT 1-START BIT, 1-STOP BIT, REN
//ENABLED
TH1 = Baud_rate;// LOAD BAUDRATE TO TIMER REGISTER
TR1 = 1;// START TIMER
void SendByteSerially(unsigned char serialdata)
SBUF = serialdata; // LOAD DATA TO SERIAL BUFFER REGISTER
while(TI == 0);// WAIT UNTIL TRANSMISSION TO COMPLETE
TI = 0;// CLEAR TRANSMISSION INTERRUPT FLAG
void serial_ISR (void) interrupt 4
//receive character
char chr;
if(RI==1)
chr = SBUF;
RI = 0;
P0 = ~P0; //Show the data has been updated
switch(chr)
case '1': Appliance1 = 1; SendByteSerially('k'); break;
case '2': Appliance2 = 1; SendByteSerially('k'); break;
case '3': Appliance3 = 1; SendByteSerially('k');break;
case '4': Appliance4 = 1; SendByteSerially('k'); break;
case '5': Appliance5 = 1; SendByteSerially('k'); break;
case '6': Appliance6 = 1; SendByteSerially('k'); break;
case '7': Appliance7 = 1; SendByteSerially('k'); break;
case '8': Appliance8 = 1; SendByteSerially('k'); break;
case 'a': Appliance1 = 0; SendByteSerially('k'); break;
case 'b':Appliance2 = 0; SendByteSerially('k'); break;
case 'c': Appliance3 = 0; SendByteSerially('k'); break;
case 'd': Appliance4 = 0; SendByteSerially('k'); break;
case 'e': Appliance5 = 0; SendByteSerially('k'); break;
case 'f': Appliance6 = 0; SendByteSerially('k'); break;
case 'g': Appliance7 = 0; SendByteSerially('k'); break;
case 'h': Appliance8 = 0; SendByteSerially('k'); break;
default: ;break; //do nothing
RI = 0;
