查看: 2234|回复: 2
有没有大神可以指导一下为什么仿真的时候湿度显示一直是0
#include <reg52.h>
#include "1602.h"
#include "dht.h"
#include "2402.h"
sbit buzzer=P2^0;
//定义LED灯
sbit Led=P1^6;                //除湿灯
sbit fan=P1^5;
sbit Key_HH1 = P3^4;
sbit Key_HH2 = P3^5;
//定义标识
volatile bit FlagStartRH = 0;  //开始温湿度转换标志
volatile bit FlagKeyPress = 0; //有键按下
//定义温湿度传感器用外部变量
extern U8  U8FLAG,k;
extern U8  U8count,U8temp;
extern U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
extern U8  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
extern U8  U8comdata;
extern U8  count, count_r;
U16 temp;
S16  humidity;
S16 idata  HH;  //湿度上限
char * pSave;
//定义变量
U16 RHCounter;
//数据初始化
void Data_Init() {
    RHCounter = 0;
    Led = 1;
    HH = 85;
//定时器0初始化
void Timer0_Init() {
    ET0 = 1;        //允许定时器0中断
    TMOD = 1;       //定时器工作方式选择
    TL0 = 0x06;
    TH0 = 0xf8;     //定时器赋予初值
    TR0 = 1;        //启动定时器
//定时器0中断
void Timer0_ISR (void) interrupt 1 using 0 {
    TL0 = 0x06;
    //每2秒钟启动一次温湿度转换
    RHCounter ++;
    if (RHCounter >= 1000) {
        FlagStartRH = 1;
        RHCounter = 0;
//存入设定值、
void Save_Setting() {
    pSave =  (char *)&HH;
    wrteeprom(2, *pSave);          //存湿度上限值RH低8位
    DELAY(500);
    pSave ++;
    wrteeprom(3, *pSave);          //存湿度上限值RH高8位
    DELAY(500);
//载入设定值、
void Load_Setting() {
    *pSave++ = rdeeprom(2);
    *pSave = rdeeprom(3);
    if ((HH>99)||(HH<0)) HH = 85;
* 名称 : Main()
* 功能 : 主函数
void main() {
    U16 i, j, testnum;
    EA = 0;
    Timer0_Init();  //定时器0初始化
    Data_Init();
    EA = 1;
    L1602_init();
//    L1602_string(1,1," Welcome to H   ");
    //延时
    for (i=0; i<500; i++)
        for (j=0; j<1000; j++)
    //清屏
    L1602_string(1,1,"Hum:  %    H:  % ");
    //载入湿度上限设定值
    Load_Setting();
    L1602_char(1, 13, HH/10+48);
    L1602_char(1, 14, HH%10+48);
    while(1) {
        //温湿度转换标志检查
        if (FlagStartRH == 1) {  //定时器
            TR0 = 0;
            testnum = RH();
            FlagStartRH = 0;
            //读出湿度,只取整数部分
            TR0 = 1;
            humidity = U8RH_data_H;
            //显示湿度
            L1602_int(1,2,humidity);
        if (!Key_HH1) {     //上下限处理
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            if (!Key_HH1) {
                if(HH>0)
                    HH--;
                else HH=0;
                Save_Setting();
        if (!Key_HH2) {
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            DELAY(5000);
            if (!Key_HH2) {
                if(HH>99)
                    HH=99;
                else HH++;
                Save_Setting();
        if (humidity > HH) {
            fan=0;
            Led = 0;  //灯打开
            buzzer=0;
            DELAY(5000);
            Led = 1;  //湿度灯关
            buzzer=1;
            DELAY(5000);
        } else {
            fan=1;
湿度控制.zip
69.92 KB, 下载次数: 5
ID:764088 发表于 2020-7-6 11:26 | 只看该作者
1)先查,传感器 传 回的值是否正确;不对 就调换 传感器硬件
2) 传感器 值 转换对否,不对,调试 转换软件,
3)显示驱动 环节 是否工作?
ID:332444 发表于 2020-7-6 11:40 | 只看该作者
测试1602传给值看显示是否正常这样去排除
