查看: 4259|回复: 2
为什么我仿真LM016L老是不显示
ID:787147 发表于 2020-6-29 09:16 | 显示全部楼层 |阅读模式
#include <reg51.h>
#include <intrins.h>
#include <stdio.h>                       //包含必要的头文件
#define delay4us() {_nop_();_nop_();_nop_();_nop_();}
#define NOP _nop_()
sbit HIGH=P2^3;
sbit LOW=P2^4 ;
sbit AD_CS =P1^0;
sbit SCK=P1^1;
sbit DO=P1^2;
sbit DI=P1^2;
sbit RS=P2^0;
sbit RW=P2^1;
sbit E =P2^2;                            //必要的位定义
unsigned char adval;
uchar Display_Buffer[] = "000.0KPa";
uchar code Line1[] = "Current Press:";          //初始化所显示的字符
uchar adc0832(uchar channel)      //读ADC0832函数,采集并返回
    uchar i=0;
    uchar j;
    uint dat2=0;
    uchar ndat=0;
    if(channel==0)channel=2;
    if(channel==1)channel=3;
    AD_CS=0;NOP; NOP;                           //拉低CS端,AD片选
DI=1;NOP; NOP;
//在第一个脉冲下降之前 DI 必须是高电平,表示启始信号
    SCK=1;NOP; NOP;
    SCK=0;NOP; NOP;
    SCK=1;
DI=channel&0x1;NOP;NOP;
  //在第二和第三个脉冲下降之前 DI 输入两位表示通道
    SCK=0;NOP; NOP;
    SCK=1;
    DI=(channel>>1)&0x1;NOP; NOP;
    SCK=0;                                  //写命令完成,DI失去输入作用
    DI=1;NOP;NOP;
    dat2=0;
    for(i=0;i<8;i++)                                    //读出8字节数据
       dat2|=DO;
       SCK=1;NOP; NOP;
       SCK=0;NOP; NOP;
       dat2<<=1;
       if(i==7)
               dat2|=DO;
    for(i=0;i<8;i++)
      j=0;
      j=j|DO;
      SCK=1;NOP; NOP;
      SCK=0;NOP; NOP;
      j=j<<7;
      ndat=ndat|j;
      if(i<7)ndat>>=1;
    AD_CS=1;
    SCK=0;
    DO=1;
    dat2<<=8;
    dat2|=ndat;
    return(dat2);                                      //返回数据
void DelayMS(uint ms)             //延时程序,相应数值为相应毫秒数
    uchar i;
    while(ms--)
      for(i=0;i<120;i++);                               //1mS延时
uchar Read_LCD_State()                         //检测LCD是否“忙”
    uchar state;
    RS=0;RW=1;E=1;DelayMS(1);
    state=P0;                                         //返回P0的值
    E= 0;DelayMS(1);
    return state;                                       //返回状态
void LCD_Busy_Wait()
    while((Read_LCD_State()&0x80)==0x80);
    DelayMS(5);
void LCD_Write_Command(uchar cmd)                      //写命令函数
     LCD_Busy_Wait();
     RS = 0;
     RW = 0;
     E  = 0;
     _nop_();
     _nop_();
     P0 = cmd;                   //将CMD值写入LCD产生相应的控制
     delay4us();
    E = 1;
     delay4us();
     E = 0;
void Set_LCD_Pos(uchar pos)
    LCD_Write_Command(pos | 0x80);
void LCD_Write_Data(uchar dat)                        //写数据函数
    LCD_Busy_Wait();
    RS = 1;
    RW = 0;
    E  = 0;
    P0 = dat;
    delay4us();
   E = 1;
    delay4us();
    E = 0;
void LCD_Initialise()                               //LCD初始化函数
     LCD_Write_Command(0x38); DelayMS(1);
     LCD_Write_Command(0x0c); DelayMS(1);
     LCD_Write_Command(0x06); DelayMS(1);
     LCD_Write_Command(0x01); DelayMS(1);
void Display_LCD_String(uchar p,uchar *s)              //LCD显示函数
    uchar i;
    Set_LCD_Pos(p);
    for(i=0;i<16;i++)
   LCD_Write_Data(s);                                  //调用写数据函数
       DelayMS(1);
void write_sfm(uchar add,uchar num)                    //分秒函数
     LCD_Write_Command(0x80+0x40+add);
                                            //第行数据指针位置调整
     LCD_Write_Data(0x30+num);
      uchar c;
      uint bai,sh,ge,xiaoshu;
           long d;                         //为得到小数部分,使用长整形数
      LCD_Initialise();
      DelayMS(10);
      Display_LCD_String(0x00,Line1);
      Display_LCD_String(0x46,Display_Buffer);
      HIGH=0;
           LOW=0;
          c=adc0832(0);
                   d=c;
                   d=d*10;                         //将数值扩大10倍得到小数
          d=((d-100)*1000/2360)+150;         //将电压值转换为压力值
          bai=d/1000 ;                                 //分离出百位
          sh=d%1000/100;                               //分离出十位
          ge=d%100/10;                                 //分离出个位
                     xiaoshu=d%10        ;                            //分离出小数位
                    if(c>246)                                  //判断过压函数
                   {       HIGH=1;LOW=0;                     //开启过压报警灯
                           DelayMS(1) ;
                           write_sfm(6,bai);
                  write_sfm(7,sh);
                  write_sfm(8,ge);
                           write_sfm(10,xiaoshu);                    //写数据
                   else if(c<10)                             //开启欠压报警灯                    {
                    {      LOW=1; HIGH=0;
                           write_sfm(6,bai);
                  write_sfm(7,sh);
                  write_sfm(8,ge);
                          HIGH=0;LOW=0;                           //正常状态,显示压力值                                 write_sfm(6,bai);
                 write_sfm(7,sh);
                 write_sfm(8,ge);
}                                                            //程序完
#include <reg51.h>
#define NOP _nop_()
sbit HIGH=P2^3;
sbit LOW=P2^4 ;
sbit AD_CS =P1^0;
sbit SCK=P1^1;
sbit DO=P1^2;
sbit DI=P1^2;
sbit RS=P2^0;
sbit RW=P2^1;
    uchar i=0;
    uchar j;
    uint dat2=0;
    uchar ndat=0;
DI=1;NOP; NOP;
    SCK=1;NOP; NOP;
    SCK=0;NOP; NOP;
    SCK=1;
    SCK=0;NOP; NOP;
    SCK=1;
    DI=1;NOP;NOP;
    dat2=0;
       dat2|=DO;
       SCK=1;NOP; NOP;
       SCK=0;NOP; NOP;
       dat2<<=1;
       if(i==7)
               dat2|=DO;
    for(i=0;i<8;i++)
      j=0;
      j=j|DO;
      SCK=1;NOP; NOP;
      SCK=0;NOP; NOP;
      j=j<<7;
      ndat=ndat|j;
      if(i<7)ndat>>=1;
    AD_CS=1;
    SCK=0;
    DO=1;
    dat2<<=8;
    dat2|=ndat;
    uchar i;
    while(ms--)
    uchar state;
    state=P0;                                         //返回P0的值
    E= 0;DelayMS(1);
    DelayMS(5);
     LCD_Busy_Wait();
     RS = 0;
     RW = 0;
     E  = 0;
     _nop_();
     _nop_();
     delay4us();
    E = 1;
     delay4us();
     E = 0;
    LCD_Busy_Wait();
    RS = 1;
    RW = 0;
    E  = 0;
    P0 = dat;
    delay4us();
   E = 1;
    delay4us();
    E = 0;
    uchar i;
    Set_LCD_Pos(p);
    for(i=0;i<16;i++)
       DelayMS(1);
                                            //第行数据指针位置调整
      uchar c;
      LCD_Initialise();
      DelayMS(10);
      HIGH=0;
           LOW=0;
          c=adc0832(0);
                   d=c;
                    if(c>246)                                  //判断过压函数
                           DelayMS(1) ;
                           write_sfm(6,bai);
                  write_sfm(7,sh);
                  write_sfm(8,ge);
                    {      LOW=1; HIGH=0;
                           write_sfm(6,bai);
                  write_sfm(7,sh);
                  write_sfm(8,ge);
                 write_sfm(7,sh);
                 write_sfm(8,ge);
}                                                            //程序完
仿真图
仿真图
ID:789121 发表于 2020-6-29 11:05 | 显示全部楼层
看着也不像有问题的,初始化后的字符显示不显示?先单独测试显示试一下
ID:861063 发表于 2020-12-24 09:59 来自触屏版 | 显示全部楼层
是设置的电压的问题么?
