查看: 7859|回复: 8
请问大神们为什么最后一行显示missing return value 怎么修改
ID:793358 发表于 2020-6-29 23:43 | 显示全部楼层 |阅读模式
                    /*12Mhz晶振工作*/
#include <reg51.h>
sbit voice=P2^3;
uchar code sound[]={0xff,
                    0x2b,0x30,0x30,0x10,0x2b,0x30,0x30,0x10,0x2b,0x20,0x26,0x20,0x20,0x20,
                    0x26,0x20,0x2b,0x30,0x30,0x10,0x2b,0x30,0x30,0x10,0x2b,0x10,0x26,0x10,
                    0x2b,0x10,0x30,0x10,0x40,0x20,0x40,0x20,0x2b,0x30,0x30,0x10,0x2b,0x30,
                    0x30,0x10,0x2b,0x20,0x26,0x20,0x20,0x20,0x26,0x20,0x2b,0x30,0x26,0x10,
                    0x2b,0x20,0x30,0x20,0x2b,0x20,0x2b,0x20,0xff,0x20,0xff,0x20,0x2b,0x30,
                                        0x30,0x10,0x2b,0x30,0x30,0x10,0x2b,0x20,0x26,0x20,0x20,0x20,0x26,0x20,
                                        0x2b,0x30,0x26,0x10,0x2b,0x20,0x30,0x20,0x39,0x20,0x39,0x20,0x26,0x10,
                                        0x2b,0x10,0x30,0x10,0x2b,0x10,0x30,0x20,0x30,0x20,0x26,0x10,0x2b,0x10,
                                        0x30,0x10,0x2b,0x10,0x30,0x30,0x20,0x10,0x26,0x10,0x2b,0x10,0x30,0x10,
                                        0x2b,0x10,0x30,0x20,0x30,0x20,0x30,0x20,0x2b,0x20,0x26,0x20,0x30,0x20,0x1c,0x20,0x20,0x10,0x1c,0x10,
                    0x1c,0x30,0x30,0x10,0x19,0x20,0x1c,0x10,0x19,0x10,0x19,0x20,0x19,0x20,
                    0x1c,0x10,0x19,0x10,0x19,0x20,0x26,0x20,0x18,0x10,0x15,0x10,0x18,0x10,
                    0x19,0x10,0x1c,0x20,0x20,0x20,0x1c,0x20,0x20,0x10,0x1c,0x10,0x1c,0x10,
                    0x20,0x10,0x1c,0x10,0x20,0x10,0x1c,0x20,0x20,0x10,0x2b,0x10,0x2b,0x10,
                    0x20,0x20,0x20,0x10,0x26,0x20,0x26,0x20,0x30,0x20,0x2b,0x20,0x26,0x20,
                    0x30,0x20,0x1c,0x20,0x20,0x10,0x1c,0x10,0x1c,0x30,0x30,0x10,0x19,0x20,
                    0x1c,0x10,0x19,0x10,0x19,0x20,0x19,0x20,0x1c,0x10,0x19,0x10,0x19,0x20,
                    0x26,0x20,0x18,0x10,0x15,0x10,0x18,0x10,0x19,0x10,0x1c,0x20,0x20,0x20,
                    0x1c,0x20,0x13,0x10,0x13,0x10,0x13,0x20,0x20,0x20,0x1c,0x20,0x13,0x10,
                    0x13,0x10,0x13,0x10,0x20,0x20,0x1c,0x10,0x1c,0x20,0x1c,0x20,0x1c,0x20,
                    0x1c,0x20,0xff,0x20,0xff,0x20,  0x18,0x20,0x15,0x20,0x13,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,
                    0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x19,0x10,0x18,0x10,
                    0x18,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,
                    0x0e,0x10,0x10,0x10,0x10,0x10,0x13,0x30,0x15,0x20,0x18,0x10,0x1c,0x10,
                    0x1c,0x10,0x18,0x20,0x1c,0x10,0x15,0x10,0x18,0x10,0x1c,0x20,0x1c,0x10,
                    0x18,0x30,0x13,0x20,0x13,0x20,0x13,0x10,0x12,0x10,0x13,0x20,0x13,0x10,
                    0x15,0x20,0xff,0x20,0xff,0x20,0x18,0x20,0x15,0x20,0x13,0x20,0x0e,0x10,0x10,0x10,
                    0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,
                    0x15,0x20,0x13,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,
                    0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x10,0x13,0x30,0x15,0x20,0x18,0x10,
                    0x1c,0x10,0x1c,0x10,0x13,0x30,0x15,0x20,0x18,0x10,0x1c,0x10,0x1c,0x10,
                    0x18,0x30,0x18,0x20,0x18,0x20,0xff,0x20,0xff,0x20,0x1c,0x10,0x13,0x10,
                    0x15,0x20,0x18,0x10,0x1c,0x10,0x1c,0x10,0x13,0x30,0x15,0x20,0x18,0x10,
                    0x1c,0x10,0x1c,0x10,0x18,0x30,0x18,0x20,0x18,0x20,0x18,0x20,0x18,0x20,0x00,
uchar zdjs=0, jp;
del(yj);
void main(void)
      uint dpjs=0;
      uchar yj;
      TMOD=0x01,IE=0x82;
      TH0=0xd8, TL0=0xef;
   TR0=1;
      zdjs=0;
      dpjs++; yj=sound[dpjs];
     dpjs++; jp=sound[dpjs];
   while(zdjs!=jp)
      if(yj!=0xff)
             if(yj!=0)
             voice=!voice;
                 del(yj);
          dpjs=0;
                      break;
        voice=0;
                 del(jp);
   time0() interrupt 1  using 1
         TH0=0xd8, TL0=0xef;
         zdjs++;
del(yj)
      uchar yj2=2;
       while(yj!=0)
               while(yj2!=0)
                     yj2--;
                  yj2=2;
             yj--;
ID:793358 发表于 2020-6-30 00:25 | 显示全部楼层
刚进这个网站,也不知道这样合不合规
ID:584814 发表于 2020-6-30 07:54 | 显示全部楼层
void main(void) 改成 int main(void) 或 main(void) 试试
ID:592807 发表于 2020-6-30 08:25 | 显示全部楼层
错误标记在哪?missing return vaul一般是指函数忘记加return值了
ID:658665 发表于 2020-6-30 08:38 | 显示全部楼层
下次发帖的时候最好把代码缩进搞一下,这个程序的问题是del(yj)前面没有加void,只要改为void del(yj)就行了,下面是你的程序
project.zip
19.3 KB, 下载次数: 8
ID:744327 发表于 2020-6-30 08:39 | 显示全部楼层
直接修改return value的值,最后一行就有变化了。
ID:784974 发表于 2020-6-30 08:57 | 显示全部楼层
这个只是警告,和错误不同,错误的话不能生成HEX文件,警告可以生成HEX文件。
然后就是看你需要返回什么值,可以在del(yj)定义的函数最后面加一个return(),括号里看你需要添加返回什么吧。
希望有所帮助,如有错误也请指正,谢谢
ID:452950 发表于 2020-6-30 10:26 | 显示全部楼层
void del(yj)
      uchar yj2=2;
       while(yj!=0)
               while(yj2!=0)
                     yj2--;
                  yj2=2;
             yj--;
这个应该是延时函数,定义函数名前要加void
ID:793358 发表于 2020-6-30 11:11 来自触屏版 | 显示全部楼层
最后一行
