查看: 2001|回复: 2
这程序错在哪里了?还是我取字模取错了?显示不了我想要的·文字
ID:792340 发表于 2020-7-2 16:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#define int8 unsigned char
#define int16 unsigned int
#define int32 unsigned long
int8 flag;
int8 n;
int8 code table[][14]={
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  Fixedsys12;  ??????????:?x?=16x16   --*/
0xBF,0xBF,0xB0,0xB7,0xB7,0xB7,0xB0,0xBF,0xB0,0xB7,0xB7,0xB7,0xB0,0xBF,0xBF,0xFF,
0xFF,0xFF,0x00,0x7F,0x9D,0xFE,0x01,0xFF,0x00,0x7F,0x9D,0xFE,0x01,0xFF,0xFF,0xFF,
0xF7,0xF7,0xF0,0x07,0xF7,0xF0,0xFF,0x80,0xBB,0xBB,0xBB,0xBB,0x80,0xFF,0xFF,0xFF,
0xFD,0xBB,0x57,0xEF,0x97,0x79,0xFD,0x01,0xBD,0xBD,0xBD,0xBD,0x01,0xFD,0xFD,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xE5,0xE3,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFE,0xFD,0xF3,0x87,0xF7,0xF7,0xF7,0x00,0xF7,0xF7,0xF7,0xF7,0xF7,0xF7,0xFF,0xFF,
0xFD,0xFD,0xBD,0xBD,0xBD,0xBD,0xBD,0x01,0xBD,0xBD,0xBD,0xBD,0xBD,0xFD,0xFD,0xFF,
0xFF,0xFF,0xFF,0x80,0xBE,0xBE,0xBE,0xBE,0xBE,0xBE,0xBE,0x80,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0x00,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0xFD,0x00,0xFF,0xFF,0xFF,0xFF,
0xFF,0xF8,0xFF,0x00,0xF7,0xFB,0xEF,0xEF,0xEF,0x00,0xEF,0xEF,0xE0,0xFF,0xFF,0xFF,
0x7F,0xFF,0xFF,0x00,0xFF,0x7E,0x7D,0x73,0x4F,0x3F,0x4F,0x73,0x7D,0x7E,0x7E,0xFF,
0xFF,0xFF,0xF8,0xC6,0xDE,0xDE,0xDE,0xD0,0xBE,0xBE,0x3E,0xBE,0xFE,0xFE,0xFF,0xFF,
0xFF,0xFB,0xF7,0xEF,0x9F,0xFD,0xFE,0x01,0xFF,0xFF,0xBF,0xDF,0xEF,0xF3,0xFF,0xFF};
void delay(void);
int16 offset;
void main(void)
    int8 i;
    int8 *p;
    flag=0x10;
    n=0;
    TMOD=0x01;
    TH0=0xb1;
    TL0=0xe0;
    ET0=1;
    EA=1;
    TR0=1;
    p=&table[0][0];
    while (1)
        for (i=0;i<8;i++)    //ÏÔê¾×ó°ë±ßÆáÄ»
            P0=*(p+offset+2*i);
            P2=i|0x08;    //P2.4=0,P2.3=1 Ñ¡ÖDU2, êä3öé¨ÃèÂë¸øU6
            delay();
            P0=*(p+offset+2*i+1);
              P2=i|0x10;   //P2.4=1,P2.3=0 Ñ¡ÖDU3, êä3öé¨ÃèÂë¸øU7
            delay();
        for (i=8;i<16;i++)     //ÏÔê¾óò°ë±ßÆáÄ»
            P0=*(p+offset+2*i);
             P2=(i-8)|0x20;   //P2.5=1 P2.4=0, P2.3=0 Ñ¡ÖDU4,êä3öé¨ÃèÂëU8
            delay();
             P2=(i-8)|0x40;   //P2.6=1 P2.5=0, P2.4=0 Ñ¡ÖDU5,êä3öé¨ÃèÂëU9
            delay();
void delay(void)
    int16 i;
    for (i=0;i<50;i++)
void timer0() interrupt 1 using 3
    TF0=0;
    TH0=0xb1;
    TL0=0xe0;
    if (n<10)
    n++;
    offset+=2;
    if (offset>480)
            offset=0;
        n=0;
ID:282850 发表于 2020-7-3 09:42 | 只看该作者
取模要知道方向、高低位
ID:311846 发表于 2020-7-3 16:40 | 只看该作者
不要急着取模,先显示数字字母之类的,确保显示没有问题再考虑其他的
