查看: 5620|回复: 3
基于STM32执行的MQTT协议 源程序与资料下载
自己根据MQTT协议报文在STM32上成功运行。
  1. /* USER CODE END Header */
  2. /* Includes ------------------------------------------------------------------*/
  3. #include "main.h"
  4. #include "tim.h"
  5. #include "usart.h"
  6. #include "gpio.h"
  7. /* Private includes ----------------------------------------------------------*/
  8. /* USER CODE BEGIN Includes */
  9. #include "string.h"
  10. #include "xianshispi.h"
  11. #include "MQTT_8266.H"
  12. /* USER CODE END Includes */
  13. /* Private typedef -----------------------------------------------------------*/
  14. /* USER CODE BEGIN PTD */
  15. /* USER CODE END PTD */
  16. /* Private define ------------------------------------------------------------*/
  17. /* USER CODE BEGIN PD */
  18. /* 大于printf重定向 */
  19. uint8_t USART1_TX_BUF[200];
  20. #define u1_printf(...)  HAL_UART_Transmit(&huart1,USART1_TX_BUF,sprintf((char *)USART1_TX_BUF,__VA_ARGS__),0xffff)
  21.
  22. uint8_t USART2_TX_BUF[200];
  23. #define u2_printf(...)  HAL_UART_Transmit(&huart2,USART2_TX_BUF,sprintf((char *)USART2_TX_BUF,__VA_ARGS__),0xffff)
  24. /* esp8266加入的WIFI(热点)名称和密码 */
  25. #define WIFI_Name         "EnHahaha7"
  26. #define WIFI_Key                "hjj1234567890"
  27. /* USER CODE END PD */
  28. /* Private macro -------------------------------------------------------------*/
  29. /* USER CODE BEGIN PM */
  30. /* USER CODE END PM */
  31. /* Private variables ---------------------------------------------------------*/
  32. /* USER CODE BEGIN PV */
  33. uint8_t Uart2_RX_Buf,WIFI_IP[15];
  34. uint8_t num,Buf[150],time;
  35. extern uint8_t Connect_Flag;
  36. extern uint16_t MQTT_PING_Time;                        //PING报文计数变量
  37. uint8_t PING_Flag;
  38. /* USER CODE END PV */
  39. /* Private function prototypes -----------------------------------------------*/
  40. void SystemClock_Config(void);
  41. /* USER CODE BEGIN PFP */
  42. /* 连接WIFI程序 */
  43. void ESP_Connect_WIFI()
  44. {
  45.         char *Start;
  46.         char *End;
  47.         u1_printf("正在连接WIFI...\r\n");
  48.
  49.         u2_printf("AT\r\n");        //测试AT启动
  50.         HAL_Delay(300);
  51.         u2_printf("AT+CWMODE=1\r\n");        //设置esp8266 STA模式
  52.         HAL_Delay(300);
  53.         u2_printf("AT+CWJAP_CUR=\"%s\",\"%s\"\r\n",WIFI_Name,WIFI_Key);        //临时接入WIFI(热点)
  54.         HAL_Delay(11000);
  55.         u2_printf("AT+CIFSR\r\n");        //获取IP地址
  56.         HAL_Delay(300);
  57.
  58.         if(strstr((char *)Buf,"\"") != NULL)                                //软检测到IP地址,OLED显示IP地址
  59.         {
  60.                 //显示IP地址
  61.                 OLED_ShowString(0,0,"IP:",1);
  62.                 Start = strstr((char *)Buf,"\"") + 1;
  63.                 End = strstr(Start,"\"");
  64.                 memcpy(WIFI_IP,Start,End - Start);
  65.                 WIFI_IP[End - Start] = '\0';
  66.                 OLED_ShowString(0,2,WIFI_IP,1);
  67.
  68.                 //串口1打印热点名、IP地址
  69.                 u1_printf("WIFI Name:%s\nWIFI IP:%s\r\n",WIFI_Name,WIFI_IP);
  70.         }
  71.         else u1_printf("WIFI连接失败");
  72. }
  73.
  74. /* USER CODE END PFP */
  75. /* Private user code ---------------------------------------------------------*/
  76. /* USER CODE BEGIN 0 */
  77. /* USER CODE END 0 */
  78. /**
  79.   * @brief  The application entry point.
  80.   * @retval int
  81.   */
  82. int main(void)
  83. {
  84.   /* USER CODE BEGIN 1 */
  85.
  86.   /* USER CODE END 1 */
  87.   /* MCU Configuration--------------------------------------------------------*/
  88.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  89.   HAL_Init();
  90.   /* USER CODE BEGIN Init */
  91.   /* USER CODE END Init */
  92.   /* Configure the system clock */
  93.   SystemClock_Config();
  94.   /* USER CODE BEGIN SysInit */
  95.   /* USER CODE END SysInit */
  96.   /* Initialize all configured peripherals */
  97.   MX_GPIO_Init();
  98.   MX_USART1_UART_Init();
  99.   MX_USART2_UART_Init();
  100.   MX_TIM1_Init();
  101.   /* USER CODE BEGIN 2 */
  102.         HAL_UART_Receive_IT(&huart2,&Uart2_RX_Buf,1);        //开启串口2接收中断
  103.         HAL_TIM_Base_Start_IT(&htim1);        //开启T1中断
  104.   /* USER CODE END 2 */
  105.   /* Infinite loop */
  106.   /* USER CODE BEGIN WHILE */
  107.         OLED_Init();                                //OLED初始化
  108.
  109.         ESP_Connect_WIFI();        //ESP8266连接WIFI,并显示在OLED
  110.
  111.         Connect_Sever();                //TCP连接服务器
  112.         MQTT_Conect();                        //连接云平台
  113.
  114.         MQTT_SUBSCRIBE();                //订阅主题
  115. //        MQTT_PUBLISH("HJJ");                        //发送消息
  116.   while (1)
  117.   {
  118.                 if(PING_Flag == 1)
  119.                 {
  120.                         PING_Flag=0;
  121.                         MQTT_PING();                        //发送心跳包
  122.                 }
  123.     /* USER CODE END WHILE */
  124.     /* USER CODE BEGIN 3 */
  125.   }
  126.   /* USER CODE END 3 */
  127. }
  128. /**
  129.   * @brief System Clock Configuration
  130.   * @retval None
  131.   */
  132. void SystemClock_Config(void)
  133. {
  134.   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  135.   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  136.   /**Initializes the CPU, AHB and APB busses clocks
  137.   */
  138.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  139.   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  140.   RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  141.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  142.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI_DIV2;
  143.   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL16;
  144.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  145.   {
  146.     Error_Handler();
  147.   }
  148.   /**Initializes the CPU, AHB and APB busses clocks
  149.   */
  150.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  151.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  152.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  153.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  154.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  155.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  156.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
  157.   {
  158.     Error_Handler();
  159.   }
  160. }
  161. /* USER CODE BEGIN 4 */
  162. void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)//串口接收中断回调函数
  163. {
  164.         if(huart == &huart2)
  165.         {
  166.                 HAL_UART_Receive_IT(&huart2,&Uart2_RX_Buf,1);//开启串口2接收中断
  167.                 Buf[num] = Uart2_RX_Buf;//将串口2接收到的数据存入Buf缓存区
  168.                 num++;time=0;
  169.         }
  170. }
  171. //uint8_t i;
  172. void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)//定时器中断回调函数
  173. {
  174.         time++;
  175.         if(time>=20 && num>0)
  176.         {
  177.                 Buf[num] = '\0';
  178.                 MQTT_RxData((char *)Buf,num);                //判断串口2接收到的数据
  179. //                for(i=0;i<num;i++) u1_printf("%c",Buf[i]);                                //串口1打印串口2接收的数据
  180.                 time=0;num=0;
  181.         }
  182.
  183.         if(Connect_Flag == 1)        //只有在连接了云平台且订阅了主题才需要发送PING报文
  184.         {
  185.                 MQTT_PING_Time++;                //每隔10S发送一次心跳包,防止服务器将客户端踢走
  186.                 if(MQTT_PING_Time >= 40000)
  187.                 {
  188.                         PING_Flag=1;
  189.                         MQTT_PING_Time=0;
  190.                 }
  191.         }
  192. }
  193. /* USER CODE END 4 */
  194. /**
  195. ……………………
  196. …………限于本文篇幅 余下代码请从51黑下载附件…………
MQTT_Demo.7z (4.18 MB, 下载次数: 122)
参与人数 2黑币 +56 收起 理由
ag26259 + 6 感谢分享
收藏收藏9 分享淘帖 顶 踩1
ID:764088 发表于 2020-7-6 14:59 | 只看该作者
感恩 楼主,谢了,收藏
ID:294886 发表于 2024-9-2 09:26 | 只看该作者
谢谢分享,最近在用mqtt,刚好有用
ID:1131980 发表于 2024-9-14 15:15 | 只看该作者
使用8266 MQTT
