查看: 1661|回复: 0
动态数码管显示实验
ID:638710 发表于 2020-7-7 20:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/*         实验名:动态数码管显示实验
*         实验说明:8位数码管显示4036
                  #include<reg51.h>
#define GPIO_DIG P0       //段选
#define GPIO_PLACE P1    //位选
unsigned char code DIG_PLACE[] = {
0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f };   //位选控制
unsigned char code DIG_CODE[] = {0x66,0x3f,0x4f,0x7};   //4036
unsigned char DisplayDate[8];   //用来存放要显示的8位数的值
void DigDisplay();         //动态显示函数
//主函数
void main(void)
     unsigned char i;
     for(i=0;i<8;i++)
             DisplayDate[i] = DIG_CODE[i];
         DigDisplay();
//使用数码管显示
void DigDisplay()
      unsigned char i;
          unsigned int j;
          for(i=0;i<8;i++)
             GPIO_PLACE = DIG_PLACE[i];         //发送位选
                 GPIO_DIG = DisplayDate[i];     //发送段码
                 j = 10;
                 while(j--)                          //扫描间隔时间设定
                 GPIO_DIG = 0x00;    //消隐
