查看: 3888|回复: 4
STM32电子时钟1602显示仿真加程序 编译程序错误
ID:190577 发表于 2020-7-16 22:27 | 显示全部楼层 |阅读模式
#include "stm32f4xx.h"
#include "delay.h"
#include "seg.h"
#include "timer.h"
unsigned int nian = 2020;
char yue = 7;
char ri = 16;
char shi = 9;
char fen = 31;
char miao = 30;
u8  bs=0;//存储时间的变量
u8 date[8]={0,0,0,0,0,0,0,0};//数据
u16 address[8]={0x0101,0x0102,0x0104,0x0108,0x0110,0x0120,0x0140,0x0180};//位码
char wendu[] = "Date:";
char shidu[] = "Time:";
#define LCD_DATA_PORT GPIOC
#define        LCD_RS_Set()        GPIO_SetBits(GPIOB, GPIO_Pin_8)
#define        LCD_RS_Clr()        GPIO_ResetBits(GPIOB, GPIO_Pin_8)
#define        LCD_RW_Set()        GPIO_SetBits(GPIOB, GPIO_Pin_9)
#define        LCD_RW_Clr()        GPIO_ResetBits(GPIOB, GPIO_Pin_9)
#define        LCD_EN_Set()        GPIO_SetBits(GPIOB, GPIO_Pin_10)
#define        LCD_EN_Clr()        GPIO_ResetBits(GPIOB, GPIO_Pin_10)
#define        DATAOUT(x)        GPIO_Write(GPIOC, x)
#define u8  unsigned char
void GPIO_Configuration(void);
void LCD1602_Wait_Ready(void);        //判忙
void LCD1602_Write_Cmd(u8 cmd);             //写命令
void LCD1602_Write_Dat(u8 dat);              //写数据
void LCD1602_ClearScreen(void);              //清屏
void LCD1602_Set_Cursor(u8 x, u8 y);
void LCD1602_Show_Str(u8 x, u8 y, char *str);    //显示
void LCD1602_Init(void);                        //初始化
        GPIO_InitTypeDef        GPIO_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(LCD_DATA_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;
        GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_UP;          //上拉
        GPIO_Init(GPIOB, &GPIO_InitStructure);
void LCD1602_Wait_Ready(void)   //检测忙
        int8_t sta=0;
        DATAOUT(0xff);      //PC全置1
        LCD_RS_Clr();       //RS 0
        LCD_RW_Set();       //RW 1
        do
                LCD_EN_Set();   //EN 1
                delay_ms(10);
                 sta = GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_7); //读取状态字
                LCD_EN_Clr();   //EN 0
        }while(sta & 0x80);
void LCD1602_Write_Cmd(u8 cmd)    //写入指令
        LCD1602_Wait_Ready();     //判忙
        LCD_RS_Clr();
        LCD_RW_Clr();
         DATAOUT(cmd);
        delay_us(10);
        LCD_EN_Set();
        LCD_EN_Clr();
        LCD_RS_Set();
        LCD_RW_Clr();
        DATAOUT(dat);
    delay_us(10);
        LCD_EN_Set();
        LCD_EN_Clr();
void LCD1602_ClearScreen(void)  //清屏
        LCD1602_Write_Cmd(0x01);
void LCD1602_Set_Cursor(u8 x, u8 y)   //光标设置位置
        u8 addr;
        if (y == 0)
                addr = 0x00 + x;
                addr = 0x40 + x;
        LCD1602_Write_Cmd(addr | 0x80);
void LCD1602_Show_Str(u8 x, u8 y, char *str)//字符串
        LCD1602_Set_Cursor(x, y);
        while(*str != '\0')
                LCD1602_Write_Dat(*str++);
void LCD1602_Init(void)//初始化
        GPIO_Configuration();
        LCD1602_Write_Cmd(0x38);
        LCD1602_Write_Cmd(0x0C);
        LCD1602_Write_Cmd(0x06);
int main(void)
        TIM3_Int_Init(15-1,2100-1);        //定时器3初始化
        LCD1602_Init();
        LCD1602_Show_Str(0,0,wendu);          //日期显示
        LCD1602_Show_Str(0,2,shidu);           //时间显示
        get_time(); //计时
              LCD1602_Write_Cmd( 0x80+5 );
                                LCD1602_Write_Dat( nian/1000 + 0x30 );//显示年
                                LCD1602_Write_Dat( nian%1000/100 + 0x30 );
                                LCD1602_Write_Dat( nian%100/10 + 0x30 );
                                LCD1602_Write_Dat( nian%10 + 0x30 );
                                LCD1602_Write_Dat( '-' );
                                LCD1602_Write_Dat( yue/10 + 0x30 );//显示月
                                LCD1602_Write_Dat( yue%10 + 0x30 );
                                LCD1602_Write_Dat( ri/10 + 0x30 );//显示日
                                LCD1602_Write_Dat( ri%10 + 0x30 );
                                LCD1602_Write_Cmd( 0x80 +0x40+5);
                                LCD1602_Write_Dat( shi/10 + 0x30 ); //显示时
                                LCD1602_Write_Dat( shi%10 + 0x30 );
                                LCD1602_Write_Dat( ':' );
                                LCD1602_Write_Dat( fen/10 + 0x30 );//显示分
                                LCD1602_Write_Dat( fen%10 + 0x30 );
                                LCD1602_Write_Dat( miao/10 + 0x30 );//显示秒
                                LCD1602_Write_Dat( miao%10 + 0x30 );
电子时钟.rar
484.6 KB, 下载次数: 97
ID:805441 发表于 2020-7-30 14:25 | 显示全部楼层
你好,我下载了发现HARDWARE里的文件是空的,程序和仿真有都
ID:890487 发表于 2021-3-13 13:24 | 显示全部楼层
请问楼主 如果1602是I2C通讯需要改动哪些部分 或者说如果直接用LCD2004A需要改什么
ID:190577 发表于 2021-8-18 06:55 | 显示全部楼层
你显示部分程序需要修改
ID:876894 发表于 2021-10-12 16:45 | 显示全部楼层
您好,hardware里面啥都没有啊
