查看: 1887|回复: 0
基于51单片机的温度控制系统
ID:526480 发表于 2020-7-26 01:09 | 显示全部楼层 |阅读模式
#include <reg52.H>
#include <intrins.H>
#include <stdio.h>
#include <math.H>
sbit rw = P2^6;
sbit RS = P2^5;
sbit LCDEN = P2^7;
/**//*****************************LCD1602*******************************/
void delayUs()
    _nop_();
void delayMs(uint a)
    uint i, j;
    for(i = a; i > 0; i--)
        for(j = 100; j > 0; j--);
void writeComm(uchar comm)
    RS = 0;
    P0 = comm;
    LCDEN = 1;
    delayUs();
    LCDEN = 0;
    delayMs(1);
//D′êy¾Y:RS=1, RW=0;
void writeData(uchar dat)
    RS = 1;
    P0 = dat;
    LCDEN = 1;
    delayUs();
    LCDEN = 0;
    delayMs(1);
void init()
    rw = 0;
    writeComm(0x38);
    writeComm(0x0c);
    writeComm(0x06);
    writeComm(0x01);
void writeString(uchar * str, uchar length)
    uchar i;
    for(i = 0; i < length; i++)
         writeData(str[i]);
/**//*****************************DS18B20*******************************/
sbit ds = P2^4;
unsigned char Now_Tem;
void dsInit()
    unsigned int i;
    ds = 0;
    i = 100;
    while(i>0) i--;
    ds = 1;
    i = 4;
    while(i>0) i--;
void dsWait()
      unsigned int i;
      while(ds);
      while(~ds);
      i = 4;
      while(i > 0) i--;
bit readBit()
    unsigned int i;
    bit b;
    ds = 0;
    i++;
    ds = 1;
    i++; i++;
    b = ds;
    i = 8;
    while(i>0) i--;
    return b;
unsigned char readByte()
    unsigned int i;
    unsigned char j, dat;
   dat = 0;
    for(i=0; i<8; i++)
        j = readBit();
        dat = (j << 7) | (dat >> 1);
    return dat;
void writeByte(unsigned char dat)
    unsigned int i;
    unsigned char j;
    bit b;
    for(j = 0; j < 8; j++)
        b = dat & 0x01;
        dat >>= 1;
        if(b)
            ds = 0;i++; i++;
            ds = 1;
            i = 8; while(i>0) i--;
            ds = 0;
            ds = 1;
            i++; i++;
void sendChangeCmd()
    dsInit();
    dsWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0x44);
void sendReadCmd()
    dsInit();
    dsWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0xbe);
int getTmpValue()
    unsigned int tmpvalue;
    int value;
    float t;
    unsigned char low, high;
    sendReadCmd();
    low = readByte();
    high = readByte();
    tmpvalue = high;
    tmpvalue <<= 8;
    tmpvalue |= low;
    value = tmpvalue;
    t = value * 0.0625;
    value = t * 100 + (value > 0 ? 0.5 : -0.5); //′óóú0¼ó0.5, D¡óú0¼õ0.5
    return value;
void display(int v)
    unsigned char count;
    unsigned char datas[] = {' ', 0, 0};
        unsigned char table0[]=0xdf;
        unsigned char table1[] = "C";
    unsigned int tmp = abs(v);
    datas[1] = tmp % 10000 / 1000;
    datas[2] = tmp % 1000 / 100;
        Now_Tem = datas[1]*10+ datas[2];      //á½Î»ÏÖÔúζè
    writeComm(0xc0+12);
    for(count = 1; count != 3; count++)
        writeData('0'+datas[count]);
        writeString(table0,1);//μ¥λ
        writeString(table1,1);
        writeComm(0x80+14);
        writeComm(0xc0+12);//¸öλê±Ïû西ոñ
        if(datas[1] == 0)
        writeData(datas[0]);
/**//*****************************°′¼ü*******************************/
sbit Key1=P1^0;
sbit Key2=P1^1;
unsigned char Set_Tem=75;                 //á½Î»é趨ζè
void Key_Scan(void)
        if(Key1 == 0)
                delayMs(5);
                if(Key1 == 0)
                        Set_Tem++;
                if(Set_Tem>=100)Set_Tem=0;
        if(Key2 == 0)
                delayMs(5);
                if(Key2 == 0)
                        Set_Tem--;
                if(Set_Tem<=0)Set_Tem=0;
        datas[1] = Set_Tem / 10;
    datas[2] = Set_Tem % 10;
        writeComm(0x80+12);
        writeComm(0x80+12);//¸öλê±Ïû西ոñ
        if(datas[1] == 0)
/**//*****************************Ä£·ÂPID*******************************/
uchar H_Time;
sbit PWM = P1^4;
void ComTemper()
        if(Set_Tem>Now_Tem)
                if(Set_Tem-Now_Tem>=10)
                        H_Time=100;
                        if(Set_Tem-Now_Tem==9)
                                H_Time=90;
                        if(Set_Tem-Now_Tem==8)
                                H_Time=80;
                        if(Set_Tem-Now_Tem==7)
                                H_Time=70;
                        if(Set_Tem-Now_Tem==6)
                                H_Time=60;
                        if(Set_Tem-Now_Tem==5)
                                H_Time=50;
                        if(Set_Tem-Now_Tem==4)
                                H_Time=40;
                        if(Set_Tem-Now_Tem==3)
                                H_Time=30;
                        if(Set_Tem-Now_Tem==2)
                                H_Time=20;
                        if(Set_Tem-Now_Tem==1)
                                H_Time=10;
                        H_Time=0;
/**//*****************************′®¿ú*******************************/
//′®¿ú·¢Ëíò»¸ö×Ö·û
void Send_Uart(unsigned char value)//μ¥Ƭ»úêy¾Y·¢Ëí
        ES=0;                         //′®¿úÖD¶Ï1رÕ
        TI=0;
        SBUF=value;                 //½«êy¾Y·Åèë′®¿ú¼Ä′æÆ÷
        while(!TI);
        TI=0; //èí¼tÇåáã
        ES=1; //′ò¿a′®¿úÖD¶Ï
////·¢Ëí×Ö·û′®
//void PT(char *puf)
//                 while(*puf!='\0')
//                                Send_Uart(*puf);
//                                puf++;
//                                delayMs(2);
    uchar table1[] = "Set_Tem:";
        uchar table2[] = "Now_Tem:";
        uint a,c;
    TMOD=0x01;//¶¨ê±Æ÷1¤×÷óú·½ê½1
        TH0=(65536-1000)/256;//¶¨ê±Æ÷¸33õÖμ
        TL0=(65536-1000)%256;
        ET0=1;//¿a¶¨ê±ÖD¶Ï
    TR0=1;//Æô¶ˉ¶¨ê±
        SCON=0x50;           //é趨′®¿ú1¤×÷·½ê½        1
    PCON=0x00;           //2¨ìØÂê2»±¶Ôö
    TMOD|=0x20;          //¶¨ê±Æ÷11¤×÷óú8λ×Ô¶ˉÖØÔØÄ£ê½, óÃóú2úéú2¨ìØÂê
    TL1=0xfd;
    TH1=0xfd;             //2¨ìØÂê9600
    TR1=1;                //′ò¿a¶¨ê±Æ÷1
    EA=1;                 //ÔêDí×üÖD¶Ï
    sendChangeCmd();
    init();
    writeComm(0x80);
    writeString(table1,8);
        writeComm(0xc0);
    writeString(table2,8);
        a=Set_Tem;//êy¾Y×a»»
            c=Now_Tem;
                delayMs(1000); //ζè×a»»ê±¼äDèòa750msòÔéÏ
        display(getTmpValue());
                Key_Scan();
        sendChangeCmd();
                TI=1;
                printf("Now_Tem:%déãê϶è\n",c);
                delayMs(4);
                TI=1;
                printf("Set_Tem:%déãê϶è\r\n",a);
/**********************T0ÖD¶Ï·tÎñ3ìDò*******************/
        void timer0(void)interrupt 1 using 1
        static uchar count;
        ComTemper();
        count++;
        count=count%100;//10msÖüÆú
        if(count<=H_Time)
                PWM=1;
                PWM=0;
DS18B20温度计(1602显示).rar
48.65 KB, 下载次数: 17, 下载积分: 黑币 -5
