查看: 2426|回复: 0
单片机智能路灯控制程序
#include <reg51.h>
unsigned char code changled[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x27,0x7f,0x6f};
unsigned char led[6];
unsigned char guandeng[3];
unsigned char kaideng[3];
unsigned char present_time[3];
unsigned char xiao[3];
unsigned char flash=0;
unsigned char timemeasure=0;
unsigned char flash_cs=0;
unsigned char tiaozheng=0;
unsigned int enabletime=0;
bit enablebit=0;
sbit dadeng=P1^4;
sbit xiaodeng=P1^5;
sbit P1_0=P1^0;
sbit P1_1=P1^1;
sbit P1_2=P1^2;
sbit P1_3=P1^3;
sbit P3_3=P3^3;
sbit P3_6=P3^6;
sbit P3_7=P3^7;
void change_data(unsigned char i)
        unsigned char x,change;
        if(i==1)
                x=present_time[0];
                change=x/100;
                x=present_time[0];
                led[0]=x/10-change*10;
                x=present_time[0];
                led[1]=(unsigned char)(x-change*100-led[0]*10);
                x=present_time[1];
                change=x/100;
                x=present_time[1];
                led[2]=x/10-change*10;
                x=present_time[1];
                led[3]=(unsigned char)(x-change*100-led[2]*10);
                x=present_time[2];
                change=x/100;
                x=present_time[2];
                led[4]=x/10-change*10;
                x=present_time[2];
                led[5]=(unsigned char)(x-change*100-led[4]*10);
        if(i==2)
                x=kaideng[0];
                change=x/100;
                x=kaideng[0];
                x=kaideng[0];
                x=kaideng[1];
                change=x/100;
                x=kaideng[1];
                x=kaideng[1];
                x=kaideng[2];
                change=x/100;
                x=kaideng[2];
                x=kaideng[2];
        if(i==3)
                x=guandeng[0];
                change=x/100;
                x=guandeng[0];
                x=guandeng[0];
                x=guandeng[1];
                change=x/100;
                x=guandeng[1];
                x=guandeng[1];
                x=guandeng[2];
                change=x/100;
                x=guandeng[2];
                x=guandeng[2];
void change_deng(unsigned i)
        if(i==0)
                 dadeng=1;
                 xiaodeng=0;
        if(i==1)
                dadeng=1;
                xiaodeng=1;
        if(i==2)
                dadeng=0;
                xiaodeng=1;
        if(i==3)
                dadeng=0;
                xiaodeng=0;
void init(void)
        guandeng[0]=6;
        guandeng[1]=0;
        guandeng[2]=0;
        kaideng[0]=18;
        kaideng[1]=0;
        kaideng[2]=0;
        present_time[0]=12;
        present_time[1]=00;
        present_time[2]=00;
        xiao[0]=23;
        xiao[1]=00;
        xiao[2]=00;
T0_in() interrupt 1 using 3
        unsigned char bb;
        flash++;
        enabletime++;
        if(flash==15)
                flash=0;
                if(flash_cs==0)
                        P2=254;
                if(flash_cs==1)
                        P2=253;
                if(flash_cs==2)
                        P2=251;
                if(flash_cs==3)
                        P2=247;
                if(flash_cs==4)
                        P2=239;
                if(flash_cs==5)
                        P2=223;
                bb=led[flash_cs];
                P0=changled[bb];
                if(flash_cs!=5)
                        flash_cs++;
                         flash_cs=0;
                if(enabletime==555)
                        enabletime=0;
                        enablebit=1;
T1_in() interrupt 3 using 3
        TH1=(65535-40000)/256;
        TL1=(65536-40000)%256;
        timemeasure++;
        if(timemeasure==10)
                timemeasure=0;
                if(present_time[2]<59)
                        present_time[2]=present_time[2]+1;
                        present_time[2]=0;
                        if(present_time[1]<59)
                                present_time[1]=present_time[1]+1;
                                present_time[1]=0;
                                if(present_time[0]<23)
                                        present_time[0]=present_time[0]+1;
                                        present_time[0]=0;
        if(tiaozheng<=3)
                change_data(1);
        if(present_time[0]==guandeng[0])
        if(present_time[1]==guandeng[1])
        if(present_time[2]==guandeng[2])
                xiaodeng=0;
                dadeng=0;
        if(present_time[0]==kaideng[0])
        if(present_time[1]==kaideng[1])
        if(present_time[2]==kaideng[2])
                xiaodeng=1;
                dadeng=1;
        if(present_time[0]==xiao[0])
        if(present_time[1]==xiao[1])
        if(present_time[2]==xiao[2])
                xiaodeng=1;
                dadeng=0;
main()
        unsigned char dengstate=0;
        P3=0x00;
        P1=0x00;
        TF0=1;
        ET0=1;
        TMOD=0x12;
        TH0=0x00;
        TL0=0x00;
        TR0=1;
        TF1=1;
        ET1=1;
        TR1=1;
        EA=1;
        init();
        change_data(1);
        init();
        for(;;)
                if(P1_3==1)
                if(enablebit==1)
                        enablebit=0;
                        enabletime=0;
                        change_deng(dengstate);
                        if(dengstate<3)
                                dengstate++;
                                 dengstate=0;
                        if(P1_0==1)
                        if(enablebit==1)
                                enablebit=0;
                                enabletime=0;
                                tiaozheng++;
                                if(tiaozheng>0)
                                if(tiaozheng<=3)
                                        change_data(3);
                                if(tiaozheng==10)
                                        tiaozheng=0;
                                        P3=0;
                                if(tiaozheng==1||tiaozheng==4||tiaozheng==7)
                                P3=1;
                                if(tiaozheng==2||tiaozheng==5||tiaozheng==8)
                                P3=2;
                                if(tiaozheng==3||tiaozheng==6||tiaozheng==9)
                                P3=4;
                          if(tiaozheng==1||tiaozheng==2||tiaozheng==3)
                                P3_3=1;
                                if(tiaozheng==4||tiaozheng==5||tiaozheng==6)
                                P3_6=1;
                                if(tiaozheng==7||tiaozheng==8||tiaozheng==9)
                                P3_7=1;
                        if(P1_2==1)
                        if(enablebit==1)
                                enablebit=0;
                                enabletime=0;
                                if(tiaozheng==1)
                                        present_time[0]=0;
                                        change_data(1);
                                if(tiaozheng==2)
                                        present_time[1]=0;
                                        change_data(1);
                                if(tiaozheng==3)
                                        present_time[2]=0;
                                        change_data(1);
                                if(tiaozheng==4)
                                        if(kaideng[0]<23)
                                        kaideng[0]=kaideng[0]+1;
                                        kaideng[0]=0;
                                        change_data(2);
                                if(tiaozheng==5)
                                        if(kaideng[1]<59)
                                        kaideng[1]=kaideng[1]+1;
                                        kaideng[1]=0;
                                        change_data(2);
                                if(tiaozheng==6)
                                        if(kaideng[2]<59)
                                        kaideng[2]=kaideng[2]+1;
                                        kaideng[2]=0;
                                        change_data(2);
                                if(tiaozheng==7)
                                        if(guandeng[0]<23)
                                        guandeng[0]=guandeng[0]+1;
                                        guandeng[0]=0;
                                        change_data(3);
                                if(tiaozheng==8)
                                        if(guandeng[1]<59)
                                        guandeng[1]=guandeng[1]+1;
                                        guandeng[1]=0;
                                        change_data(3);
                                if(tiaozheng==9)
                                        if(guandeng[2]<59)
                                        guandeng[2]=guandeng[2]+1;
                                        guandeng[2]=0;
                                        change_data(3);
                        if(P1_1==1)
                        if(enablebit==1)
                                enablebit=0;
                                enabletime=0;
                                if(tiaozheng==1)
                                        if(present_time[0]>=1)
                                        present_time[0]=present_time[0]-1;
                                        present_time[0]=23;
                                        change_data(1);
                                if(tiaozheng==2)
                                        if(present_time[1]>=1)
                                        present_time[1]=present_time[1]-1;
                                        present_time[1]=59;
                                        change_data(1);
                                if(tiaozheng==3)
                                        if(present_time[2]>=1)
                                        present_time[2]=present_time[2]-1;
                                        present_time[2]=59;
                                        change_data(1);
                                if(tiaozheng==4)
                                        if(kaideng[0]>=1)
                                        kaideng[0]=kaideng[0]-1;
                                        kaideng[0]=23;
                                        change_data(2);
                                if(tiaozheng==5)
                                        if(kaideng[1]>=1)
                                        kaideng[1]=kaideng[1]-1;
                                        kaideng[1]=59;
                                        change_data(2);
                                if(tiaozheng==6)
                                        if(kaideng[2]>=1)
                                        kaideng[2]=kaideng[2]-1;
                                        kaideng[2]=59;
                                        change_data(2);
                                if(tiaozheng==7)
                                        if(guandeng[0]>=1)
                                        guandeng[0]=guandeng[0]-1;
                                        guandeng[0]=23;
                                        change_data(3);
                                if(tiaozheng==8)
                                        if(guandeng[1]>=1)
                                        guandeng[1]=guandeng[1]-1;
                                        guandeng[1]=59;
                                        change_data(3);
                                if(tiaozheng==9)
                                        if(guandeng[2]>=1)
                                        guandeng[2]=guandeng[2]-1;
                                        guandeng[2]=59;
                                        change_data(3);
仿真图
仿真图
