查看: 3411|回复: 4
stc89c52单片机eeprom问题
ID:358460 发表于 2020-8-19 17:13 | 显示全部楼层 |阅读模式
近期制作了一个计数器,想增加eeprom来掉电存储。但是发现数码管数字增加一次就不再增加(从512跳到2),不知是何故,求指教
#include <reg52.h>
#include <intrins.h>
float c=2;
uchar duan[]={
          0x3f,  /*0*/
      0x06,  /*1*/
      0x5b,  /*2*/
      0x4f,  /*3*/
      0x66,  /*4*/
      0x6d,  /*5*/
      0x7d,  /*6*/
      0x07,  /*7*/
      0x7f,  /*8*/
      0x6f,   /*9*/
          0x00    //ximie
sbit key=P3^2;//霍尔传感器
sbit nnn=P1^7;//小数点dp控制位
unsigned long jishu=4294967295;
double meterd;
unsigned long meter;<font color="#ff0000">//在此以上是原来的,无误</font>
/*eeprom<font color="#ff0000">(这些是复制的stc示例程序)</font>*/
/*Declare SFR associated with the IAP */
sfr IAP_DATA    =   0xE2;           //Flash data register
sfr IAP_ADDRH   =   0xE3;           //Flash address HIGH
sfr IAP_ADDRL   =   0xE4;           //Flash address LOW
sfr IAP_CMD     =   0xE5;           //Flash command register
sfr IAP_TRIG    =   0xE6;           //Flash command trigger
sfr IAP_CONTR   =   0xE7;           //Flash control register
/*Define ISP/IAP/EEPROM command*/
#define CMD_IDLE    0               //Stand-By
#define CMD_READ    1               //Byte-Read
#define CMD_PROGRAM 2               //Byte-Program
#define CMD_ERASE   3               //Sector-Erase
/*Define ISP/IAP/EEPROM operation const for IAP_CONTR*/
#define ENABLE_IAP   0x81           //if SYSCLK<20MHz
//Start address for STC89C58xx EEPROM
#define IAP_ADDRESS 0x2000<font color="#ff0000">//这里已经改成89c52的eeprom地址</font>
/*MCU初始设置<font color="#ff0000">(开中断)</font>*/
void init_MCU(void)
         EX0=1;
         IT0=1;
         EA=1;
/*1ms delay*/
void delayms(uint xms)
uint timems;
for(;xms>0;xms--)
        for(timems=115;timems>0;timems--);
/*显示*/
void display(uint dat)
uchar ge,shi,bai,qian;
ge=dat%1000%100%10;
shi=dat%1000%100/10;
bai=dat%1000/100;
qian=dat/1000;
P2=0XF7;//个位
P1=duan[ge];
delayms(3);
P2=0XFB;//十位
P1=duan[shi];
delayms(3);
P2=0XFD;//百位
P1=duan[bai];
delayms(3);
P2=0XFE;//千位
P1=duan[qian];
delayms(3);
/*eeprom(<font color="#ff0000">也是示例程序</font>)*/
Disable ISP/IAP/EEPROM function
Make MCU in a safe state
void IapIdle()
    IAP_CONTR = 0;                  //Close IAP function
    IAP_CMD = 0;                    //Clear command to standby
    IAP_TRIG = 0;                   //Clear trigger register
    IAP_ADDRH = 0x80;               //Data ptr point to non-EEPROM area
    IAP_ADDRL = 0;                  //Clear IAP address to prevent misuse
Read one byte from ISP/IAP/EEPROM area
Input: addr (ISP/IAP/EEPROM address)
Output:Flash data
uchar IapReadByte(uint addr)
    uchar dat;                       //Data buffer
    IAP_CONTR = ENABLE_IAP;         //Open IAP function, and set wait time
    IAP_CMD = CMD_READ;             //Set ISP/IAP/EEPROM READ command
    IAP_ADDRL = addr;               //Set ISP/IAP/EEPROM address low
    IAP_ADDRH = addr >> 8;          //Set ISP/IAP/EEPROM address high
    IAP_TRIG = 0x46;                //Send trigger command1 (0x46)
    IAP_TRIG = 0xb9;                //Send trigger command2 (0xb9)
    _nop_();                        //MCU will hold here until ISP/IAP/EEPROM operation complete
    dat = IAP_DATA;                 //Read ISP/IAP/EEPROM data
    IapIdle();                      //Close ISP/IAP/EEPROM function
    return dat;                     //Return Flash data
Program one byte to ISP/IAP/EEPROM area
       dat (ISP/IAP/EEPROM data)
Output:-
void IapProgramByte(uint addr, uchar dat)
    IAP_CMD = CMD_PROGRAM;          //Set ISP/IAP/EEPROM PROGRAM command
    IAP_DATA = dat;                 //Write ISP/IAP/EEPROM data
    IapIdle();
Erase one sector area
Output:-
void IapEraseSector(uint addr)
    IAP_CMD = CMD_ERASE;            //Set ISP/IAP/EEPROM ERASE command
    IapIdle();
/*主程序(和原来一样)*/
uint i;
init_MCU();
meterd=jishu*c;
meter=meterd;
if (meter<10000)
P1=0X00;
P2=0XFE;
nnn=1;
delayms(3);
P2=0XFF;
display (meter);
P1=0X00;
P2=0XFD;
nnn=1;
delayms(3);
P2=0XFF;
display(meter/10);
void Int0() interrupt 0<font color="#ff0000">//这里面改了
delayms(50);
if(key==0)
jishu=IapReadByte(IAP_ADDRESS);
jishu++;
    IapProgramByte(IAP_ADDRESS,jishu);
ID:213173 发表于 2020-8-19 21:10 | 显示全部楼层
stc单片机的eeprom哪怕只写1个字节也得先把整个扇区擦除才能正常写入。如果只改写某一个或多个字节就得把有效地址的数据全部读出来保存,改变其中一个或多个数据后再将整个扇区擦除,把改变后的和原样的数据一道按原地址写回去。
        delayms(50);
        if(key==0)
                jishu++;
                IapEraseSector(IAP_ADDRESS);//擦除扇区
ID:71233 发表于 2020-8-20 07:58 | 显示全部楼层
wulin 发表于 2020-8-19 21:10
stc单片机的eeprom哪怕只写1个字节也得先把整个扇区擦除才能正常写入。如果只改写某一个或多个字节就得把有 ...
没错,读写STC内部eeprom麻烦变麻烦在这里
ID:213173 发表于 2020-8-20 10:05 | 显示全部楼层
这是由于硬件材料的物理特性所致,Data Flash只能写0不能写1,只有全部擦除后全部都为1。
ID:358460 发表于 2020-8-21 13:24 来自触屏版 | 显示全部楼层
谢谢大家的帮助。问题现在已经解决了,一个是大家所说的问题.需要先把整个扇区给擦掉才能写。第二点是对eeprom操作时候要关掉系统的总中断,我的程序是在中断里边儿直接就把中断给关了,还没有写入进去,中断就跳出。
