查看: 3096|回复: 5
这个咋错了啊C(4): error C129: missing ';' before 'keydown'
ID:815452 发表于 2020-8-21 21:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include"LCD.h"
uchar keydown()
        uchar i = 0;
        uchar key = P2 & 0x0f;
        if((P2&0x0f) != 0x0f)
                delayMs(10);
                        key = P2 & 0x0f;
                        while((P2&0x0f) != 0x0f);
                        switch(key);
                                //Key1~4 接P2.4~7
                                case 0x0e: return 1;
                                case 0x0d: return 2;
                                case 0x0b: return 3;
                                case 0x07: return 4;
        return 0;
显示时钟
void showClock()
        uchar  i = 0;
        LCDclear();
        for(; i<6; i++)
                displayField(i);
        displaySpan('-', ':');
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
中断加时间
void time0() interrupt 1;
        TL1=(65536-50000)%256;
        countTimer ++;
        if(countTimer == 20)
                countTimer = 0;
                autoAdd1Sec();
void showLogo(uchar logo[])
        LCDclear();
        displayStr(logo,0,0);
void refreshPage()
        if(g_year != g_LCDyear)
                g_LCDyear = g_year;
                displayField(e_year);
        if(g_mon != g_LCDmon)
                g_LCDmon = g_mon;
                displayField(e_mon);
        if(g_day != g_LCDday)
                g_LCDday = g_day;
                displayField(e_day);
        if(g_hou != g_LCDhou)
                g_LCDhou = g_hou;
                displayField(e_hou);
        if(g_min != g_LCDmin)
                g_LCDmin = g_min;
                displayField(e_min);
        if(g_sec != g_LCDsec)
                g_LCDsec = g_sec;
                displayField(e_sec);
void changeClock();
        uchar count = 0;
        uchar key;
        TR0 = 0;
        initCousorXY();
                refreshPage();
                key = 0;
                writeCmd(0x0E);//显示,开光标并闪烁
                moveCousor(g_cousorx[count],g_cousory[count]);
                key = keydown();
                if(key == 2)
                        count ++;
                if(key == 3)
                        addClkField(count);
                if(key == 4)
                        subClkField(count);
                writeCmd(0x0c);//关光标
                if(count >= 6)
                        break;
        TR0 = 1;
        uchar mode = 0;//0:显示Logo,1:显示时间
        uchar i = 0;
        uchar movelen;
        uchar logo[] = "    welcome!";
        uchar move[] = "Tt could be better,but I'm busy."; //貌似最长只能40字节
        //uchar move[] = "(*^_^*)";
        movelen = sizeof(move)-1;
        setDateTime(2013,9,12,18,23,14);
        LCDinit();
        LCDclear();
        showLogo(logo);
                switch(keydown();)
                        case 1: mode = ! mode;
                                        if(mode == 1)
                                                showClock();
                                                showLogo(logo);
                                        break;
                        case 2:        if(mode == 1)
                                                changeClock();
                                        break;
                        default: break;
                if(mode == 1)
                        refreshPage();
                        displayStr(move,1,15-i);
                        displayStr(" ",1,15+movelen-i);
                i++;
                i = i%(15+movelen+1);
                delayMs(200);
ID:155507 发表于 2020-8-21 21:30 | 只看该作者
少了这个
ID:815452 发表于 2020-8-21 23:27 | 只看该作者
angmall 发表于 2020-8-21 21:30
少了这个
加了这个一堆错呀
1.c(3): warning C318: can't open file 'LCD.h'
1.C(6): error C141: syntax error near '{'
1.C(8): error C247: non-address/-constant initializer
1.C(9): error C141: syntax error near 'if'
1.C(9): error C141: syntax error near '&', expected ')'
1.C(11): error C141: syntax error near '10'
1.C(12): error C141: syntax error near 'if'
1.C(12): error C141: syntax error near '&', expected ')'
1.C(14): error C279: 'key': multiple initialization
1.C(14): error C231: 'key': redefinition
1.C(14): error C247: non-address/-constant initializer
1.C(15): error C141: syntax error near 'while'
1.C(15): error C141: syntax error near '&', expected ')'
1.C(17): error C141: syntax error near '{'
1.c - 13 Error(s), 1 Warning(s).
ID:213173 发表于 2020-8-22 05:39 | 只看该作者
123456qwerty1 发表于 2020-8-21 23:27
加了这个一堆错呀
1.C(6): error C141: syntax error  ...
要加载LCD.h和LCD.c。
ID:466505 发表于 2020-8-22 08:50 | 只看该作者
switch(keydown();)这句是错的吧,多了个;
ID:833190 发表于 2020-10-23 17:14 | 只看该作者
主函数里的switch(keydown();),后面的;不要
