查看: 3061|回复: 2
单片机写数据到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM源程序
ID:171036 发表于 2020-8-27 11:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include <reg52.h>
  3. #define uint unsigned int
  4. #define LCD12864Data P2//LCD12864点阵型液晶显示器输入输出数据/命令端口
  5. sbit LCD12864_RS=P0^7;//LCD12864点阵型液晶显示器数据/命令选择端
  6. sbit LCD12864_RW=P0^6;//LCD12864点阵型液晶显示器读/写端
  7. sbit LCD12864_EN=P0^5;//LCD12864点阵型液晶显示器使能端
  8. //太阳
  9. uchar code sun[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x40,0x08,0x10,0x00,0x00,0x10,0x08,0x00,0x00,0x10,0x08,0x00,0x00,0x08,0x10,0x02,0x40,0x00,0x00,0x00,0x00,0x00,0x00};
  10. //月亮
  11. uchar code moon[]={0x00,0x00,0x00,0x00,0x03,0x80,0x02,0x40,0x02,0x20,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x20,0x02,0x40,0x03,0x80,0x00,0x00,0x00,0x00};
  12. //星星
  13. uchar code star[]={0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x02,0x80,0x00,0x00,0x54,0x54,0x20,0x08,0x08,0x20,0x02,0x80,0x12,0x90,0x08,0x20,0x20,0x08,0x00,0x00,0x00,0x00};
  14. //人
  15. uchar code robot[]={0x07,0xE0,0x08,0x10,0x12,0x48,0x10,0x08,0x1F,0xF8,0x10,0x08,0x30,0x0C,0x50,0x0A,0x50,0x0A,0x50,0x0A,0x50,0x0A,0x5F,0xFA,0x04,0x20,0x04,0x20,0x04,0x20,0x0E,0x70};
  16.   void Delay(uint i)
  17. {
  18.    while(--i);
  19. }
  20.   void ReadBuzy()//读忙函数
  21. {
  22.    P2=0x00;
  23.    LCD12864_RS=0;
  24.    LCD12864_RW=1;
  25.    LCD12864_EN=1;
  26.    while(P2 & 0x80);
  27.    LCD12864_EN=0;
  28. }
  29.   void LCD12864WriteCommand(uchar command)//写指令函数
  30. {
  31.    ReadBuzy();//读忙
  32.    LCD12864_RS=0;
  33.    LCD12864_RW=0;
  34.    LCD12864_EN=1;
  35.    LCD12864Data=command;
  36.    Delay(100);
  37.    LCD12864_EN=0;
  38. }
  39.   void LCD12864WriteData(uchar value)//写数据函数
  40. {
  41.    ReadBuzy();//读忙
  42.    LCD12864_RS=1;
  43.    LCD12864_RW=0;
  44.    LCD12864_EN=1;
  45.    LCD12864Data=value;
  46.    Delay(100);
  47.    LCD12864_EN=0;
  48. }
  49.   void LCD12864Init()//LCD12864点阵型液晶显示器初始化函数
  50. {
  51.    ReadBuzy();//读忙
  52.    Delay(4000);
  53.    LCD12864WriteCommand(0x30);//8位数据端口传输,且设置为基本指令集动作。
  54.    Delay(100);
  55.    LCD12864WriteCommand(0x30);//8位数据端口传输,且设置为基本指令集动作。
  56.    Delay(37);
  57.    LCD12864WriteCommand(0x0c);//设置整体显示,光标、闪烁全关,不反白。
  58.    Delay(100);
  59.    LCD12864WriteCommand(0x01);//清屏,并且DDRAM数据指针清零。
  60.    Delay(10000);
  61.    LCD12864WriteCommand(0x06);//进入点设定模式,设置地址指针自动加1。
  62. }
  63.   void CGRAM()//写自定义字符函数
  64. {
  65.    uchar i;
  66.    LCD12864WriteCommand(0x30);//设置LCD12864点阵型液晶显示器数据端口D0-D7为8位控制接口,且这8位控制接口接收基本指令操作。
  67.    LCD12864WriteCommand(0x40);//写自定义字符到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM第1个内存地址
  68.           for(i=0;i<16;i++)//一个完整自定义字符占用LCD12864点阵型液晶显示器16(行)x16(列)显示界面,每一行占用2个字节(即16列)才显示该行某点字符,因单片机写数据是以写2个字节为一次写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,且一个完整自定义字符占用32个字节,那么要写完一个完整自定义字符占用的32个字节,必须分16次来写,这就是循环16次的原由。
  69.   {
  70.      LCD12864WriteData(sun[i*2]);//把第一个字节的自定义字符写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,供LCD12864点阵型液晶显示器读取显示。
  71.      LCD12864WriteData(sun[i*2+1]);//把第二个字节的自定义字符写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,供LCD12864点阵型液晶显示器读取显示。为什么乘以2?由于单片机写数据是以写2个字节为一次写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,所以要乘以2。
  72.     }
  73.    LCD12864WriteCommand(0x50);//写自定义字符到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM第2个内存地址
  74.    for(i=0;i<16;i++)//一个完整自定义字符占用LCD12864点阵型液晶显示器16(行)x16(列)显示界面,每一行占用2个字节(即16列)才显示该行某点字符,因单片机写数据是以写2个字节为一次写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,且一个完整自定义字符占用32个字节,那么要写完一个完整自定义字符占用的32个字节,必须分16次来写,这就是循环16次的原由。
  75. {
  76.     LCD12864WriteData(moon[i*2]);//把第一个字节的自定义字符写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,供LCD12864点阵型液晶显示器读取显示。
  77.     LCD12864WriteData(moon[i*2+1]);//把第二个字节的自定义字符写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,供LCD12864点阵型液晶显示器读取显示。为什么乘以2?由于单片机写数据是以写2个字节为一次写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,所以要乘以2。
  78.    }
  79.    LCD12864WriteCommand(0x60);//写自定义字符到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM第3个内存地址
  80.    for(i=0;i<16;i++)//一个完整自定义字符占用LCD12864点阵型液晶显示器16(行)x16(列)显示界面,每一行占用2个字节(即16列)才显示该行某点字符,因单片机写数据是以写2个字节为一次写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,且一个完整自定义字符占用32个字节,那么要写完一个完整自定义字符占用的32个字节,必须分16次来写,这就是循环16次的原由。
  81. {
  82.     LCD12864WriteData(star[i*2]);//把第一个字节的自定义字符写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,供LCD12864点阵型液晶显示器读取显示。
  83.     LCD12864WriteData(star[i*2+1]);//把第二个字节的自定义字符写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,供LCD12864点阵型液晶显示器读取显示。为什么乘以2?由于单片机写数据是以写2个字节为一次写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,所以要乘以2。
  84.    }
  85.    LCD12864WriteCommand(0x70);//写自定义字符到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM第4个内存地址
  86.    for(i=0;i<16;i++)//一个完整自定义字符占用LCD12864点阵型液晶显器16(示行)x16(列)显示界面,每一行占用2个字节(即16列)才显示该行某点字符,因单片机写数据是以写2个字节为一次写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,且一个完整自定义字符占用32个字节,那么要写完一个完整自定义字符占用的32个字节,必须分16次来写,这就是循环16次的原由。
  87. {
  88.     LCD12864WriteData(robot[i*2]);//把第一个字节的自定义字符写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,供LCD12864点阵型液晶显示器读取显示。
  89.     LCD12864WriteData(robot[i*2+1]);//把第二个字节的自定义字符写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,供LCD12864点阵型液晶显示器读取显示。为什么乘以2?由于单片机写数据是以写2个字节为一次写到LCD12864点阵型液晶显示器内部ST7920芯片的CGRAM内存地址上,所以要乘以2。
  90.    }
  91. }
  92.   void main()//主函数
  93. {
  94.    LCD12864Init();//LCD12864点阵型液晶显示器初始化函数
  95.    CGRAM();//写自定义字符函数
  96.    LCD12864WriteCommand(0x98);//LCD12864点阵型液晶显示器下半屏第二行第1个显示位置
  97.    LCD12864WriteData(0x00);//清空DRAM内存地址上的内容
  98.    LCD12864WriteData(0x00);//把自定义字符写进DDRAM内存地址0x00,供LCD12864点阵型液晶显示器读取显示。
  99.    LCD12864WriteCommand(0x99);//LCD12864点阵型液晶显示器下半屏第二行第2个显示位置
  100.    LCD12864WriteData(0x00);//清空DRAM内存地址上的内容
  101.    LCD12864WriteData(0x02);//把自定义字符写进DDRAM内存地址0x02,供LCD12864点阵型液晶显示器读取显示。
  102.    LCD12864WriteCommand(0x9A);//LCD12864点阵型液晶显示器下半屏第二行第3个显示位置
  103.    LCD12864WriteData(0x00);//清空DRAM内存地址上的内容
  104.    LCD12864WriteData(0x04);//把自定义字符写进DDRAM内存地址0x04,供LCD12864点阵型液晶显示器读取显示。
  105.    LCD12864WriteCommand(0x9B);//LCD12864点阵型液晶显示器下半屏第二行第4个显示位置
  106.    LCD12864WriteData(0x00);//清空DRAM内存地址上的内容
  107.    LCD12864WriteData(0x06);//把自定义字符写进DDRAM内存地址0x06,供LCD12864点阵型液晶显示器读取显示。
  108.    while(1);//固定循环
  109. }
收藏收藏2 分享淘帖 顶 踩
ID:815648 发表于 2020-8-30 10:35 | 只看该作者
写的真详细,感谢作者的分享
ID:121859 发表于 2020-9-1 08:48 | 只看该作者
额,作者注释详细的有点过了,重复部分没必要如此注解。
