查看: 3411|回复: 0
Single Chip U-art simple string通讯
ID:51472 发表于 2013-7-9 14:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
        #include<reg52.h>
typedef unsigned char uint8;
typedef unsigned int  uint16;
uint8 STR[]="hello world!\n";
void uart_init()
        SCON=0x50;
        TMOD=0x20;
        TH1=0xfd;
        TL1=0xfd;
        TR1=1;
void delay(uint16 timer)
        while(timer--);
void uart_send_byte(uint8 dat)
                SBUF=dat;
                while(!TI);
                TI=0;
void uart_send_string(uint8 *pointer)
        while(*pointer!='\0')
                uart_send_byte(*pointer++);
main()
        uart_init();
        uart_send_string(STR);
        delay(30000);
