查看: 2208|回复: 3
怎么把这段程序转换为串口读写
ID:817135 发表于 2020-9-7 16:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1黑币
void FPGA_read(void)
        Uint16_t countnum, *FpgaRxaddr, Rx[32];
        if (g_commflagcount.FpgaReadFlag)
                g_commflagcount.FpgaReadFlag = 0;
                //读操作
                FpgaRxaddr = (Uint16_t *) FPGA_READ_ADDR;
                for(countnum=0; countnum<32; countnum++)
                        Rx[countnum] = *(FpgaRxaddr);
                        FpgaRxaddr = FpgaRxaddr + 2;
                if ((Rx[0]&0x00FF) == 0x7E)
                        stCommErrCode.nFuse = 0;
                        FpgaReadBuf = *((FPGA_READ_BUF *)(&Rx[0]));
                        stCommErrCode.nFuse =1;
//                volatile Uint32_t temp;
//                temp = (FpgaReadBuf.head & 0xFF00)>>8;
//                extern Uint32_t addr1;
//                RamWriteFourByte(addr1, (void*)&temp); //for test80300000
//                addr1 += 2;
                stEncodeSolveData.nAi_200hz = stEncodeSolveData.nAi;
                stEncodeSolveData.nEi_200hz = stEncodeSolveData.nEi;
                stCommSolveData.nMissAi = FpgaReadBuf.nAi - stEncodeSolveData.nAi;
                stCommSolveData.nMissEi = FpgaReadBuf.nEi - stEncodeSolveData.nEi;
                if (stCommSolveData.nMissAi > 9320675)
                        stCommSolveData.nMissAi -= 0x1000000;
                else if(stCommSolveData.nMissAi < -9320675)
                        stCommSolveData.nMissAi += 0x1000000;
                if (stCommSolveData.nMissEi > 9320675)
                        stCommSolveData.nMissEi -= 0x1000000;
                else if(stCommSolveData.nMissEi < -9320675)
                        stCommSolveData.nMissEi += 0x1000000;
//                                if (g_commflagcount.ButtonState == SLAVEMODE && g_configPM.g_state.Astart)
//                                        RamWriteFourByte(addr1, (void*)&FpgaReadBuf.nAi); //for test80300000
//                                        addr1 += 2;
//                                        RamWriteFourByte(addr3, (void*)&stCommSolveData.nMissAi); //for test80500000
//                                        addr3 += 2;
//                                        RamWriteFourByte(addr4, (void*)&stEncodeSolveData.nAi); //for test80600000
//                                        addr4 += 2;
// FPGA_write: return DSP data to fuse PC through FPGA  -by:fyb
void FPGA_write(void)
        Uint16_t button, FpgaTx[32], countnumWR, *FpgaTxaddr;
        Int32_t StickVelA, StickVelE;
        static Uint16_t CycleCode;
        if (g_commflagcount.FpgaWriteFlag)
                g_commflagcount.FpgaWriteFlag = 0;
                CycleCode ++;
                if (CycleCode > 199)
                        CycleCode = 0;
                switch (g_commflagcount.ButtonState)
                case STICKMODE://单杆
                        button = 0x0080;
                        break;
                case SLAVEMODE://数引
                        button = 0x0040;
                        break;
                case INFRAREDMODE://中波红外
                        button = 0x0020;
                        break;
                case LONGFOCUSMODE://可见
                        button = 0x0010;
                        break;
                case FUSE://融合
                        button = 0x00A0;
                        break;
                case COLORLIVEMODE://彩色实况
                        button = 0x00C0;
                        break;
                case SHORTNFRAREDMODE://短波
                        button = 0x00E0;
                        break;
                case SPACETARGETMODE: //空间目标    后加0409
                        button = 0x00B0;
                        break;
                case SPACESEARCHMODE: //空间搜索    后加0409
                        button = 0x00D0;
                        break;
                default:
                        break;
                if (g_configPM.g_state.Astart)
                        button = button | 0x0002;
                        button = button & 0xFFFD;
                if (g_configPM.g_state.Estart)
                        button = button | 0x0001;
                        button = button & 0xFFFE;
                if (g_configPM.PWMwarning_A)
                        button = button | 0x0004;
                        button = button & 0xFFFB;
                if (g_configPM.PWMwarning_E)
                        button = button | 0x0008;
                        button = button & 0xFFF7;
                if (g_configPM.Elimit_0)//第4个字节第1位,1=限位,0=正常
                        button = button | 0x0100;
                        button = button & 0xFEFF;
                if (g_configPM.Elimit_180)
                        button = button | 0x0200;
                        button = button & 0xFDFF;
                if (g_configPM.manual)
                        button = button | 0x0400;
                        button = button & 0xFBFF;
                if (stCommErrCount.nEncode > 5) // if the count of err-code occur over 5 times, disable PWM
                        button = button | 0x0800; // tell FPGA its not safe to output PWM
                        button = button & 0xF7FF; // tell FPGA its safe to output PWM
                StickVelA = ((Int32_t)stStickValue.dbStick1A - stEncodeSolveData.nAa) * g_configPM.Encode_SampleHz;
                StickVelE = ((Int32_t)stStickValue.dbStick1E - stEncodeSolveData.nEe) * g_configPM.Encode_SampleHz;
                FpgaTx[0] = (CycleCode << 8) | 0x007E;
                FpgaTx[1] = button;
                FpgaTx[2] = (Uint16_t)((Int32_t)stStickValue.dbStick1A & 0x0000FFFF);
                FpgaTx[3] = (Uint16_t)((Int32_t)stStickValue.dbStick1A >> 16);
                FpgaTx[4] = (Uint16_t)((Int32_t)stStickValue.dbStick1E & 0x0000FFFF);
                FpgaTx[5] = (Uint16_t)((Int32_t)stStickValue.dbStick1E >> 16);
                FpgaTx[6] = (Uint16_t)(stCommSolveData.nMissAi & 0x0000FFFF);
                FpgaTx[7] = (Uint16_t)(stCommSolveData.nMissAi >> 16);
                FpgaTx[8] = (Uint16_t)(stCommSolveData.nMissEi & 0x0000FFFF);
                FpgaTx[9] = (Uint16_t)(stCommSolveData.nMissEi >> 16);
                FpgaTx[10] = (Uint16_t)(StickVelA & 0x0000FFFF);
                FpgaTx[11] = (Uint16_t)(StickVelA >> 16);
                FpgaTx[12] = (Uint16_t)(StickVelE & 0x0000FFFF);
                FpgaTx[13] = (Uint16_t)(StickVelE >> 16);
                FpgaTx[14] = (Uint16_t)(stEncodeSolveData.nAi_3 & 0x0000FFFF);
                FpgaTx[15] = (Uint16_t)(stEncodeSolveData.nAi_3 >> 16);
                FpgaTx[16] = (Uint16_t)(stEncodeSolveData.nEi_3 & 0x0000FFFF);
                FpgaTx[17] = (Uint16_t)(stEncodeSolveData.nEi_3 >> 16);
                FpgaTx[18] = (Uint16_t)(stEncodeSolveData.nAi_2 & 0x0000FFFF);
                FpgaTx[19] = (Uint16_t)(stEncodeSolveData.nAi_2 >> 16);
                FpgaTx[20] = (Uint16_t)(encoderSyncInterval[4]);
                FpgaTx[21] = (Uint16_t)(encoderSyncInterval[3]);
                FpgaTx[22] = (Uint16_t)(encoderSyncInterval[2]);
                FpgaTx[23] = (Uint16_t)(encoderSyncInterval[1]);
                FpgaTx[24] = (Uint16_t)(encoderSyncInterval[0]);
                FpgaTx[25] = (Uint16_t)(fuseRxSyncInterval);
                FpgaTx[26] = (Uint16_t)(stEncodeSolveData.nAi & 0x0000FFFF);
                FpgaTx[27] = (Uint16_t)(stEncodeSolveData.nAi >> 16);
                FpgaTx[28] = (Uint16_t)(stEncodeSolveData.nEi & 0x0000FFFF);
                FpgaTx[29] = (Uint16_t)(stEncodeSolveData.nEi >> 16);
                FpgaTx[30] = FpgaReadBuf.head & 0xFF00;
                FpgaTx[31] = 0xE700;
//                extern Uint32_t addr2;
//                RamWriteFourByte(addr2, (void*)&button); //for test
//                addr2 = addr2 + 2;
                FpgaTxaddr = (Uint16_t *) FPGA_WRITE_ADDR;
                //写操作,写之后给个上升沿
                GPIO_WritePin(19, 0);//写之前拉低
                for(countnumWR=0; countnumWR<32; countnumWR++)
                        *FpgaTxaddr = FpgaTx[countnumWR];
                        FpgaTxaddr = FpgaTxaddr + 2;
                GPIO_WritePin(19, 1);//写之后拉高
                *((Uint16_t *)FPGA_HANDLE_ADDR) = 0x0066;
                *((Uint16_t *)(FPGA_HANDLE_ADDR + 2)) = 0x0077;
                GPIO_WritePin(19, 1);//写之前拉低8
ID:328014 发表于 2020-9-7 17:25 | 只看该作者
这个是什么芯片的程序?STM32吗?
ID:817135 发表于 2020-9-8 08:26 | 只看该作者
51hei团团 发表于 2020-9-7 17:25
这个是什么芯片的程序?STM32吗?
芯片DSP的F28377
ID:123289 发表于 2020-9-8 16:39 | 只看该作者
不一定能,这需要看两的硬件是否允许。
