查看: 1846|回复: 0
单片机抢答器源程序
ID:297382 发表于 2020-9-9 08:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
uchar code1[]={~0x3F,~0x06,~0x5B,~0x4F,~0x66,~0x6D,~0x7D,~0x07,~0x7F};
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
void delay(uint t)
uint j;
for(;t>0;t--)
for(j=19;j>0;j--);
void display(uchar i)
switch(i)
  case 0:P2=code1[0];break;
  case 1:P2=code1[1];break;
  case 2:P2=code1[2];break;
void key()
uchar i;
if(key1==1)
  delay(10);
  if(key1==1)
   delay(10);
   i=0;
   display(i);
  while(key1!=1);
  delay(10);
  if(key2==1)
  delay(10);
  if(key2==1)
   delay(10);
   i=1;
   display(i);
  while(key2!=1);
  delay(10);
  if(key3==1)
  delay(10);
  if(key3==1)
   delay(10);
   i=2;
   display(i);
  while(key3!=1);
  delay(10);
  while(1);
  key();
