查看: 5484|回复: 1
Arduino 1602时钟计数器程序+接线照片
ID:313638 发表于 2020-9-9 22:59 | 显示全部楼层 |阅读模式
1602时钟计数器接线照片见附件。程序代码:在Mixly1.1.5软件编译通过。
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
volatile int hour;
volatile int min2;
volatile int second;
String number;
LiquidCrystal_I2C mylcd(0x27,16,2);
String conversion(int x) {
  number = x;
  if (x < 10) {
    number = String("0") + String(x);
  return number;
void setup(){
  hour = 0;
  min2 = 0;
  second = 0;
  number = "";
  mylcd.init();
  mylcd.backlight();
void loop(){
  delay(1000);
  second = second + 1;
  if (second == 60) {
    min2 = min2 + 1;
    second = 0;
  if (min2 == 60) {
    hour = hour + 1;
    min2 = 0;
  if (hour == 24) {
    hour = 0;
    min2 = 0;
    second = 0;
  mylcd.setCursor(0, 0);
  mylcd.print("CLOCK :");
  mylcd.setCursor(0, 1);
  mylcd.print(String(String((conversion(hour))) + String(":")) + String(String((conversion(min2))) + String(":")) + String(conversion(second)));
ID:138707 发表于 2023-7-30 12:36 | 显示全部楼层
喜欢算法,做实验验证
